Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Apr 26, 2021 at 10:58 AM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    I have the expand it 40v string trimmer, and its pretty great. I was able to clear a large swath of tall weed without any issues. If/when I need any of the other tools, I'll definitely stick to that platform. I also have the 40v blower and lawn mower, and have been using them for a few months and am happy with them so far.
    Roll_Terps likes this.
  2. Apr 26, 2021 at 11:09 AM
    Roll_Terps
    Roll_Terps Well-Known Member
    Maryland
    2017 SR DCSB White
    I found one comment online that Ryobi's expand-it attachments are compatible with Dewalt's platform, and theres a youtube video of a guy with a poulan pro pole saw attachment on it, so it seems like brands are cross-compatible to an extent. I'm newly invested in Dewalt's battery platform, so building on that would be preferred.
    DarthPow likes this.
  3. Apr 26, 2021 at 1:33 PM
    rageman
    rageman Well-Known Member
    Keith
    2018 Barcelona Red Tacoma TRD Off-Road
    False hope is better than no hope...:p
    I don't think it will be a problem, but it's obviously untested. Google tells me that it's nothing new. Take your time and think like water. Seal it up everywhere you can.
    PackCon likes this.
  4. Apr 26, 2021 at 2:00 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Works great and saved a lot of money!
    Fargo Taco likes this.
  5. Apr 26, 2021 at 2:17 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Same.
    My mom just had a house build 2 years ago. At the 1 year inspection she had them come out and fix a bunch of screw pops from under the drywall mud. Never seen that many pop after a year.
    I was there when the guy came over to fix them and he said they were nails. He said no one uses screws anymore.
    ????? Wut?!?
    wilcam47 likes this.
  6. Apr 26, 2021 at 4:06 PM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    The hardware Mr Jay Bates is using in this picture are called Z-clips. You can make something similar out of wood if you want to go down that route but since you're a self proclaimed novice, I would go the z-clip route. Wood will expand along the grain so you'll want to put the clips on the long end. Hope that helps.
    -J
    Slashaar[QUOTED] likes this.
  7. Apr 26, 2021 at 4:11 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Close to wrapping up my portion of the work on this airbnb. Installed the 2 stair/step units (I had finished them a while back but needed the RAM board pulled up before installing) and built/trimmed out this small door to access the well pump (it's in a BR). Still need a small latch.
    Was hoping to route the top sides of the treads... but they're freakin' veneer.
    So much crappy work has been done to this place over the years. Not much is plumb/level/even.
  8. Apr 26, 2021 at 4:30 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Perfect!
  9. Apr 27, 2021 at 5:27 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Yesterday I fixed the door opener on one of my bay doors. Took awhile to trouble shoot - well first I figured out how it works (20V) - then found the wire to the second eye sensor had broken internally, then rewired and soldered the terminations rather than 20g to 22g twisted with wire nuts. Works like a champ and I was feeling cocky until we went out and bought a 60" TV and mount. That thing kicked my a$$. OK the TV was a good deal but mounting it and lifting in place..............took awhile..............That cubby is deep and I should have followed my crude instincts and mounted 2x8's or 2x6's flat across the studs to give the extended mount just that 1"+ extra boost...of course studs never in the right place..........end up too high the first shot even with the TV mount portion all the "down". Uggggg took the lag bolts out and lowered it 4"! But that worked (and I can adjust up if I want, but no need)........wife who is a strong sexy sinewy Asian at 115 pounds had to heft the other end.............yikes...........all the work I was either in the cubby or on my handy short ladder on the hearth and bridged 6x6 blocks for the other two legs...................fack..............sits just perfect..........ignore the greasy Italian fingerprints.
    Charlie Too and Babybluetaco like this.
  10. Apr 27, 2021 at 7:19 AM
    cafereef
    cafereef Well-Known Member
    2017 MGM Tacoma TRD Sport
    TRD Sport Exahust, OEM roof Rack, Predator Pro side steps.
    Yes this is true, there are a number of cross-platform products. There is a chart for what brands work with which I cant find the best one but here is an example.
    Slashaar and Charlie Too like this.
  11. Apr 27, 2021 at 10:00 AM
    cafereef
    It took 10 days of work, but my wife and I finally finished putting in our new LVP floors. 3 days were dedicated to removing vinyl floors and the underlayment that they were attached too. That underlayment was glued and stapled to roughly every 6 inches....I want to murder my builder. But it's done, my hands feel like I have horrific hands arthritis. 1700 square feet of flooring installed, I still have yet to put in quarter round, caulk along the shower/tub edges where the floor meets up and put in closet door guides. I also bought a CNC and will be making custom floor registers. More to come on that.
    FD76D121-15BB-4207-9023-597F4843D537.jpg BAD3644F-27E8-4946-8E05-C17772096869.jpg A58A267A-88AD-4178-AAC0-AA32D81B03F0.jpg 32B5BA1E-30AC-42A5-97DF-BBDC93ABB97E.jpg 3C71792A-3C68-44A7-A24F-14C774289218.jpg 730288E9-DB5C-4480-80BE-789F7E58E1A2.jpg 7ED3EDCE-6218-4873-B86D-B752727C2F95.jpg 96B6A0DB-F230-4589-A395-086847F370EC.jpg D2328BB3-436C-402F-8C99-DDAAE73FB2A8.jpg F4B36E02-6724-4AC7-A001-2C24402AECC7.jpg 2654F57F-BAAD-4828-BF04-8A8C8F95FAE3.jpg 6BFE6AD3-147D-48DA-A935-0197F25FA5EE.jpg 684B158F-7940-426A-AC9A-CEB00BD89ECD.jpg
  12. Apr 27, 2021 at 10:04 AM
    ralfnjan
    ralfnjan Well-Known Member
    Can't remember if it was on this thread, but I put new screen and lattice around my screened porch. Back and hip flexors were f-ed up for a day. I've decided never to work on projects closer to the ground than 4 feet anymore. Or at least try not to.
    Oh, and my radon remediation trick worked. Covered the sump pump pit and put a 4 inch mjffin fan on it, vented outside. Went from 600+Bequrels per cubic meter down to under 18. 600 is 3x the level that Health Canada says "DO SOMETHING!"
  13. Apr 27, 2021 at 11:35 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    I thought underlayment is supposed to be stapled that close. Cant remember what i looked up
    Im still not a real believer in radon...but we have it done.
  14. Apr 27, 2021 at 12:01 PM
    Championsumo
    Championsumo Well-Known Member
    Tulsa, OK
    2015 DCSB 4X4 TRD Sport
    Just started on a 1200 sq ft job myself. And I totally hear you on the hand issues. Mine hurt so bad they have been waking me up at night!
    cafereef[QUOTED] and Slashaar like this.
  15. Apr 27, 2021 at 1:55 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Sheet vinyl underlayment is supposed to be fastened like that , U-Lay even comes with little dots on a 6" grid to show you where to fasten it
    Rockslide, truchador and Charlie Too like this.
  16. Apr 27, 2021 at 2:20 PM
    cafereef
    that's exactly how it was... I know it's how it's supposed to be...but damn my hands hate the design haha. on a positive note I am certain it could withstand an F5 tornado
  17. Apr 27, 2021 at 3:21 PM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    I believe I would have installed the LVP over the underlayment rather than dealing with that lol
    PackCon likes this.
  18. Apr 27, 2021 at 8:18 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Today, I mowed the backyard.
    Yesterday, I cleaned and troubleshot my pool cover pump. The GFCI outlet is dead. There's also ants all in the outlet box which is new.
    Sunday, I spread 20 lb of ant killer around the property, bug sprayed the shop, and put plywood liners on some wire shelves.
  19. Apr 27, 2021 at 10:04 PM
    OZ-T
    Peter North
    British Columbia
    ULINE black wire shelves ?
  20. Apr 27, 2021 at 10:59 PM
    CR2014Sport
    CR2014Sport Well-Known Member
    Craig
    SoCal
    2014 Sport
    Stuff... Need more stuff
    Moving on to the next room... Found this lovely wallpaper under the wood paneling I took down.
    450CDC0E-688F-403D-A93A-89D55028C1DD.jpg 2C5E1F22-BCEF-4B7A-A052-F913C4A345BF.jpg 81F70053-3391-4334-B818-A74B4F6FD9E2.jpg 603BA495-C377-4E99-AAF8-F8970A026AD3.jpg
