Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jun 5, 2021 at 8:41 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    as a contractor, i get really tired hunting for house addresses anywhere but brand new sub divisions. the numbers are either missing, faded, or small.
    so i fixed my house address. the little vertical numbers are the originals--leaving them up because they're covering the faded vinyl that i'm trying to ignore fixing for later.
    i also welded a flower together. i'm hoping i can keep this one alive this time.
  2. Jun 5, 2021 at 9:09 PM
    Denk
    Denk Well-Known Member
    PNW
    '13 Spruce TRD Sport DCSB
    So I bought my house a few years ago now, and after we got used to the place and checked out all the little nooks and crannies, I came across a white pvc pipe-end sticking up out of the ground on the side of the house. Never thought anything of it. Also found several lengths of rebar sticking up out of the ground around the house. I eventually pulled one out and dug down to see if maybe it was marking something. What I found was a white pvc pipe running, what appears to be, around the house.
    Looking at your pics, maybe what I have is a perimeter drain pipe. What exactly does this do? And why does it stick up out of the ground at one spot?
    MGMDesertTaco and Fargo Taco like this.
  3. Jun 5, 2021 at 9:52 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The function of the perimeter drain is to drain away any water that accumulates at the base of the foundation . In my pics , the vertical pipes will be clean outs so that it is possible to maintain the drainage pipe with cameras / power washing snakes to remove any debris or roots . The vertical pipes in my pics are not the final product , we just used some scraps of pipe in our T's to keep any drain rock out of the perimeter drain pipe while the machine dropped the drain rock into place , when we are done the vertical pipes will extend to grade with a screw in PVC inspection cap
  4. Jun 6, 2021 at 5:05 PM
    DirtyTerp
    DirtyTerp Well-Known Member
    Randy
    Freeland, MD
    '14 DCSB MGM
    Still need to caulk the edges but we’re pretty much done. @Jonas
    jsi, SH7mi, TinoTaco and 11 others like this.
  5. Jun 7, 2021 at 2:44 AM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    make sure the end sticking out of the ground has a cap on it, that’s your inspection/ cleanout access
    wilcam47 likes this.
  6. Jun 7, 2021 at 7:38 AM
    Championsumo
    Championsumo Well-Known Member
    Tulsa, OK
    2015 DCSB 4X4 TRD Sport
    Pics of the finished product?
  7. Jun 7, 2021 at 8:42 AM
    Denk
    PNW
    The end actually has a vent cap on it. Although, it looks more like its meant to channel water.
  8. Jun 7, 2021 at 8:52 AM
    truchador
    Otto
    WV
    15 DC OR
    Wow that don’t look right
    unless it’s s an overflow from a pond lol
    I’d pull it off then cut it off even with the grade and install a threaded cap like oz- t mentioned
    MGMDesertTaco likes this.
  9. Jun 7, 2021 at 8:56 AM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    Coming...
    Championsumo[QUOTED] likes this.
  10. Jun 7, 2021 at 10:23 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 Tundra TRD OR inferno
    Got rid of the drafty door and broken storm window and put french doors in. Still have to piddle away at the trim but the shitty parts are done.
    E202C2B2-E5B4-4750-8BA1-A9709B572CFB.jpg B507CA43-05D3-4D89-82B2-10E12455B93B.jpg 16766E4E-C6D2-4F98-845C-66CEA1FFAF7C.jpg
  11. Jun 7, 2021 at 2:03 PM
    OZ-T
    Peter North
    British Columbia
    I don't want to be 'that guy' , but what's holding up the header from the original door or is that a non-load bearing wall ?
    TinoTaco and jsi like this.
  12. Jun 7, 2021 at 2:21 PM
    SH7mi
    Kevin
    West Grove, Pa.
    I was thinking (maybe) one header covered the span of original door and window.
  13. Jun 7, 2021 at 2:31 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Looks to me like the header over the old door was taken out and a new one spanning the double door was put in. Looks like there's a Jack stud on the right side.
    FlyingWolfe likes this.
  14. Jun 7, 2021 at 2:49 PM
    Denk
    PNW
    Thanks for the confirmation. I'll do that.
  15. Jun 7, 2021 at 3:53 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    It has a PLed and GRKed doubled up full span header on jacks with kings.
    I was gonna follow up with a smartassed comment but.. meh.
    23Skidoo, FastEddy59, OZ-T and 2 others like this.
  16. Jun 7, 2021 at 6:23 PM
    OZ-T
    Peter North
    British Columbia
    :thumbsup:
  17. Jun 8, 2021 at 3:38 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    ....and no rubbin’ too, I’ll bet. :)
    FlyingWolfe[QUOTED] likes this.
  18. Jun 8, 2021 at 4:02 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    You mean for me or the framing? :rofl:
    FastEddy59[QUOTED] likes this.
  19. Jun 9, 2021 at 7:47 AM
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    Finally installed my Nest Thermostat. I still need to fill the holes/ touch up paint but works very well. IMG_7045.HEIC.jpg
  20. Jun 9, 2021 at 9:14 PM
    OZ-T
    Peter North
    British Columbia
    Got our perimeter drains inspected Monday then we started our infill
    8" lift of drain rock on bottom covered in heavy filter fabric to create a drainage bed for any water wicking up from below
    I ran all of our electrical and low voltage conduit , plus waterlines and a condensation drain line to the future mechanical room and then we carried on infilling with granular fill compacted with a 500lb compacter in 8" lifts
    Pipes hanging on exterior are tight pipe for the gutter downspouts
    we'll finish fine tuning interior grade tomorrow morning , then finish up backfilling to exterior grades
