Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jan 17, 2022 at 9:32 AM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    does anyone here have a specific product recommendation for gap filler/expanding foam to seal up a gap between wood and concrete?
    the door to my basement was lazily put together by the previous owners, there is a gap between the broken and worn down concrete and the wood frame. now during heavy rains, some water and dirt is getting down into the basement between this gap. Its not enough to damage or worry about, but I just want to avoid the potential for problems down the road.
    I can get a pic of it in a little while, if that would help anyone.
    wilcam47 likes this.
  2. Jan 17, 2022 at 9:45 AM
    My Name is Rahl
    Great Stuff is basically all you'll find for DIY types. They do have several different types for different applications. Any big box store should have it.
    I would probably recommend a low expansion foam, so you don't push your door frame out of square. Also, expanding foam isn't going to fix the whole issue, you need to waterproof the outside.
  3. Jan 17, 2022 at 10:05 AM
    DarthPow
    thanks for the reply! I'm waiting on a pic of it when someone gets to the house today. My plan is to fill the gap, and then use some kind of weatherstripping on the door. I know it won't be perfect, but I'm in southern california, so i figure it'll stand up to 99% of the weather we get here. If you have other suggestions, I'd appreciate hearing them!
  4. Jan 17, 2022 at 10:22 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Maybe some clear silicone on the top part in the corners. You should be able to take the trim pieces off where the big screws are and apply foam or sealant under the door sill.20220117_131815.jpg
    la0d0g likes this.
  5. Jan 17, 2022 at 10:29 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    This is all I use now. Amazing stuff.
    https://www.sashco.com/products/big-stretch/
    MGMDesertTaco, Drainbung and wilcam47 like this.
  6. Jan 17, 2022 at 10:40 AM
    DarthPow
    oh I see, so its not that kind of door. its an outside, flat door, that opens up, on top of a staircase that leads down to the basement. I'll be sure to post a pic when I get it, so it makes sense.
    wilcam47[QUOTED] likes this.
  7. Jan 17, 2022 at 11:01 AM
    ty.s07
    ty.s07 Well-Known Member
    Alabama
    Sig45[QUOTED] and wilcam47 like this.
  8. Jan 17, 2022 at 11:07 AM
    Sig45
    Mark
    Maine
    I'm not sure as I buy it at a local lumber/building supply store.
  9. Jan 17, 2022 at 11:09 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    The upper right corner of his link has a "where to buy" box click on thing.
    theredofshaw and wilcam47 like this.
  10. Jan 17, 2022 at 11:23 AM
    MGMDesertTaco
    Home Depot and Lowes sometimes have it. Otherwise, Amazon does. Sashco makes some good stuff.
    https://www.amazon.com/Sashco-Stret...d=1642446945&sprefix=sashco+bi,aps,138&sr=8-1
    I used Sashco's MorFlexx Stucco caulking when I repainted my house last year. It worked really well. I had a bazillion fine stucco cracks and filled every stinking one of em with Morflexx and Sika stucco patch. :bananadead:
    https://www.amazon.com/Sashco-15010...locphy=9061147&hvtargid=pla-306495717833&th=1
    Sig45 and Drainbung like this.
  11. Jan 17, 2022 at 11:26 AM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    Not sure if it counts as home improvement but we had some gnarly winds come through and power surges last night. Heard a pop and I guess we op checked our surge protector for the downstairs TV/entertainment system. Glad to say the protector did its job and smelled terrible afterwards. She definitely got toasted :eek:
    ended up replacing with same brand and more outlets.
  12. Jan 17, 2022 at 11:37 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    That happened to us a couple years ago. Company was cutting trees and one fell on the lines. You could hear it happen even though it was MILES away. It fried like 4 or 5 of mine. They fried so hard it tripped the circuit breakers that were feeding those circuits. Took out a couple things in the garage that wasn't on surge protectors.
    Fargo Taco and Sig45 like this.
  13. Jan 17, 2022 at 11:57 AM
    Sig45
    Mark
    Maine
    @Delta09
    Adam - what's up with the new house?
    Fargo Taco likes this.
  14. Jan 17, 2022 at 12:09 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Tentatively closing this Friday. Got a reservation for a UHaul trailer with gate so I can load up the mowers, my toolbox, and other shit. Gotta pull carpet and run cable this weekend. Following weekend we should be moving in. I've done little to no packing; pretty much just gonna shove stuff in the truck :rofl:
  15. Jan 17, 2022 at 12:11 PM
    Sig45
    Mark
    Maine
    :fingerscrossed:
    Fargo Taco and Delta09[QUOTED] like this.
  16. Jan 17, 2022 at 12:14 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Ok lots a pictures but finally wrapping up basement bathroom install... did everything besides concrete work, and I also had someone make the cabinet doors for me. First big project like this that kind of included a little of everything... framing, electrical, plumbing, drywall, flooring, tiling, cabinet making, etc etc still have a couple details to finish up, mainly caulking, final paint touch up and backsplash for sink. Just happy the bulk of it is over:bananadead:
  17. Jan 17, 2022 at 12:15 PM
    Sig45
    Mark
    Maine
    Well done!
  18. Jan 17, 2022 at 12:16 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Damn, dude! Looks great!
  19. Jan 17, 2022 at 12:23 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    WOW HUGE added space. NICE WORK. Some of it even looks like fun work!!
    Drainbung, Fargo Taco and excorcist like this.
  20. Jan 17, 2022 at 12:28 PM
    wilcam47
    Will
    Bourbon state
    Nice
    Drainbung and excorcist[QUOTED] like this.
