Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Feb 11, 2022 at 4:59 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Waiting on structural engineer buy-off
  2. Feb 11, 2022 at 5:13 AM
    ty.s07
    ty.s07 Well-Known Member
    Alabama
    That looks good! Hopefully the engineer approves!
    wilcam47 and Pablo8[QUOTED] like this.
  3. Feb 11, 2022 at 5:17 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    The only thing I see is that the spanning load has no where to sit above the door header. They might have to use exterior uprights to hold the load. I am not an architect but that’s what I see.
    treyus30 and Pablo8[QUOTED] like this.
  4. Feb 11, 2022 at 5:40 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Yes, well there will be 3 beams and 6 posts. Inside the 2x6 walls probably will triple up. Shop has insulation and reflective cover, so easy. Garage has drywall so I will need to tear that out. Plus the middle beam will need access from master closet upstairs. Fun!
    wilcam47 and Toyko Joe[QUOTED] like this.
  5. Feb 11, 2022 at 5:46 AM
    Toyko Joe
    I am in the process of buying two fixer uppers and I don’t know if I’m ready to go through this whole process again, after my last three were sold I thought I was done with flips and rentals. I guess it just feeds my tool addiction so…
  6. Feb 11, 2022 at 9:37 AM
    MGMDesertTaco
    House window tint installation scheduled for this Presidents Day. :kona::tumbleweed:
  7. Feb 11, 2022 at 9:38 AM
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    how old are your windows you need tint? i thought you had a newer house? Newer windows should have Argon gas in between the glass that dont transfer heat/ cold
    MGMDesertTaco[QUOTED] likes this.
  8. Feb 11, 2022 at 9:46 AM
    Toyko Joe
    Argon just slows the heat/cold transfer. Films add to the reflective properties of windows rejecting a higher percent of infrared and ultraviolet.
    IPNPULZ and MGMDesertTaco like this.
  9. Feb 11, 2022 at 9:54 AM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    I think the wood was so chewed up from so many attempts to get a screw to bite that none of the things I inserted would "grab" with just friction alone. The 5/8 x 48 dowel was $1.50 and I was at the store getting glue anyway, so it wasn't worth my time to keep trying random stuff. I drilled out 5 of the 6 holes, backfilled them with glue & tapped in about 4" of dowel per hole (;))
    It's been about 2 days drying now so it should be good to go once I have some time to revisit the project. It's been close to 90° here in SoCal so I need to use this weather & get to painting ASAP.
  10. Feb 11, 2022 at 11:11 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I'd have just routed the hinges another 3/4" or so and made new screw holes
  11. Feb 11, 2022 at 12:48 PM
    OffroadJet
    Sebastian, FL
    hmmmm idk maybe the higher end windows have a a tinting as well. I need to check mine out then lol
    MGMDesertTaco likes this.
  12. Feb 11, 2022 at 12:53 PM
    4ast4orward
    4ast4orward Well-Known Member
    WA
    2014 Tacoma DCSB 4x4
    Did something similar to this today but used wooden tooth picks and wood glue too fix my stripped out holes on my front screen door.
  13. Feb 11, 2022 at 12:58 PM
    Toyko Joe
    High end windows usually have additional layers applied during the glass lamination process so most should not need tinting.
    Tint is obviously acceptable and beneficial and probably a good added value over full replacement if your windows are newer. (For my home the Previous Owner and builder chose 100 series windows and it shows! Tinting should bring me up to a 300-500 series window class as far as bypass and through heating are concerned.
  14. Feb 11, 2022 at 2:52 PM
    dumontrider
    La Habra, CA
    14 GX460
    But then I'd have to do the same to the doors, and that's a lot of Bondo/sanding to do after they were already morticed in the original spots. Had I noticed the frame holes were no good before I morticed the door hinges well then I could've done things differently :bananadead:
  15. Feb 11, 2022 at 3:12 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Possible to angle the screws at like 30deg as well, but sounds like you got it figured out lol
    dumontrider[QUOTED] likes this.
  16. Feb 11, 2022 at 6:12 PM
    MGMDesertTaco
    Kind of and yes.
    House was built in 1996 and I bought it from the original owner in 2016. It's practically new, because it's been remodeled floor to ceiling and throughout the entire outside property as well. You name it it's probably been redone.
    Previous owner replaced all the windows with low e models from IWC about 10 years ago. Also, turns out they never were tinted, but they have the appearance of tint. (greenish tinted appearance) Tint guy said over time the argon gas will dissipate and that's why they've faded slightly over the last three years. I'm sure the 110-115 degree summers have accelerated that.
    Nevertheless, they're getting tinted this Presidents Day and I can't wait for the added uv protection, shade, privacy and aesthetic upgrade.
  17. Feb 11, 2022 at 6:59 PM
    Toyko Joe
    Anyone use this? Right angle drill, is this just for fastening or does it work for actual drilling?
  18. Feb 11, 2022 at 7:12 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    I'm interested in where you live now. My house was built in 1999 and I'm the one currently renovating it. Been working on it basically since I moved in a little over 3 years ago. I'm right on the border of Mesa and Apache Junction
  19. Feb 11, 2022 at 7:57 PM
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
    Working on shelves for the nursery closet. Got the cleats up today. Gonna have to break out the cardboard and hot glue for a template for the shelves because of course nothing is square. Why would it be :rolleyes:
    7B7030E7-74BC-47B8-8CB3-EA165B9689A1.jpg C004AC61-B9F0-4813-837C-8F88C4F5D258.jpg DC5D587D-AE6D-4742-B281-78D8C5C024B7.jpg
  20. Feb 11, 2022 at 8:08 PM
    MGMDesertTaco
    Phoenix, but wishing I was out in the sticks on an acre or two in Carefree or north east Snobsdale.:rofl::tumbleweed: It's crazy how expensive real estate has gotten and increased in the last 3-4 years here in AZ.
    treyus30[QUOTED] likes this.
