Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Feb 12, 2022 at 5:59 PM
    MGMDesertTaco
    What kind of bird/parrot do you have? I used to have Cockatiels years ago and one of family members has an adopted African Grey Parrot. It's very smart, but unfortunately whoever had it before taught it just about every bad word. It's always talking in the background during phone calls. :rolleyes::D
    dumontrider likes this.
  2. Feb 12, 2022 at 6:01 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    It's my gf's haha; it's a cockatiel. She's a girl though so doesn't really repeat things as much as the males unfortunately
    MGMDesertTaco[QUOTED] likes this.
  3. Feb 12, 2022 at 6:07 PM
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
    Got mine finished today and working like a charm. I had portable room units in the past and they work OK, but it seems they only really affect the room they are in. This 500M was $139 off Amazon and had it in 2 days. Then you need a few pieces of 6" duct, some 1/2" clear drain hose, hose clamp, sheet metal screws, 1/4" soft copper tubing, duct sealant, and thermostat wire. Now it is permanent, don't have to fill a water tank every day, and is feeding the entire house evenly. They say it takes a few days to stable out due to all the furniture and carpet in the house being dry.
  4. Feb 13, 2022 at 7:09 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    You're most likely not going to get one coat coverage (even with primer) with Ben, Regal Select maybe. Ben is just a hyped up UltraSpec. I sold Benjamin Moore for years and was around when they switched to all the new Gennex tint paints. What I would recommend is the paint store tint a primer, just the UltraSpec 500 primer tinted will suffice in this case. Any person that mixes paint that tells you it can't be done, hasn't done it for long. We would shake up the primer and dip out the amount of primer that was needing to be tinted. Then we fooled the computer by scanning the actual paint product, but dispensed it in the primer can. Works well.
    I'll be using the UltraSpec paint in my new home. We don't have high traffic of kids around, so it's perfect and affordable.
    Aura is friggin' awesome! However, have you tried Advance for trim? I have grown to love it just the little I've used it. I have an entire house worth of trim I have to prime and paint. Advance is definitely gonna be my topcoat.
  5. Feb 13, 2022 at 8:57 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Starting cutting wood for shelves in my shed. Using brackets and old 1x4's and 2x4's.
  6. Feb 13, 2022 at 9:33 AM
    4x4Taco2012
    4x4Taco2012 Well-Known Member
    Tim
    Huntingdon Valley, PA
    2022 DCSB Limited 4x4
    TRD lift, TRD SEMA wheels, TRD skid plate, TRD Pro fog lights, TRD Heritage Grill, OEM bed cover, LT275/70/17 Falken Wildpeak AT3Ws, OEM bed lights, OEM all weather floor mats, OEM door skid plates, OEM mud guards, OEM bed mat, Black lug nuts
    Our contractor started finishing about 1400 sq ft in our basement this week. Our house is a ranch so if you split the basement down the middle where the main support beam runs we'll have two bedrooms and a large unfinished space on the back side of the house and the front half of the house will be wide open...will be a large family room and rec room and a small utility closet in a corner that houses the electric panel and sewer clean-out. Also insulating the ceiling for noise reduction. Won't be soundproof but it should help cut down some noise from my 15 year old son and his friends.
  7. Feb 13, 2022 at 10:00 AM
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    On my next house sound reduction is definitely something I'm keeping in mind. Seems mass loaded vinyl is really good for under floors and walls, I think it would a lot of work to do a ceiling though. Looks like your contractors are doing a good job! appreciate the cleanliness.
    Slashaar and 4x4Taco2012[QUOTED] like this.
  8. Feb 13, 2022 at 10:24 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Problem is MLV is probably more costly than just increasing your stud cavity fill by 2" and using mineral wool
    907rx7[QUOTED] likes this.
  9. Feb 13, 2022 at 10:53 AM
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    I'm a licensed painter with over 35 years of experience.
    Paint is manufactured to be applied at a specific thickness providing maximum protection to the substrate it's applied on. Please never plan on applying only one coat of finish paint it will not achieve maximum protection for the substrate. If you're changing color, you may need to apply more than two coats to cover the old color. I always advise customers is use the best product you can afford and apply it properly for the best result. You're taking time, money to improve the most expensive thing you'll own (Your home), do it right the first time and you'll benefit in the long haul.
    In my opinion any B&M paint product is the go to for quality results.
  10. Feb 13, 2022 at 12:11 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    rez bar prior to drywall on the ceiling will also help
    4x4Taco2012[QUOTED] likes this.
  11. Feb 13, 2022 at 12:31 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    On today's episode of nasty things in Delta's "new" house, the filter for the cistern...
    This is supposed to be white... The smell was awesome as well.
    Only flushed 5 gallons through it as it's cold outside, but there's some nasty funk still in the system. The filter is already catching crap in just 5 gallons.
    I will say the pressure is excellent on this system, even with an external pump and small pressure tank. Should handle my small pressure washer fine.
    4x4Taco2012, jsi, dumontrider and 4 others like this.
  12. Feb 13, 2022 at 12:40 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  13. Feb 13, 2022 at 1:48 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Ready for drywall next week.
    truchador, Slashaar, treyus30 and 6 others like this.
  14. Feb 13, 2022 at 8:31 PM
    jsi
    jsi Well-Known Member
    native earthling
    ^this - tint the primer for the win!^
    A contractor friend taught me this one. Have the store tint the primer at 75% of what the finished color will be. Then when you put the top coat on you can see what you've missed and the tinted primer goes a long way to covering the previous color.
  15. Feb 13, 2022 at 8:39 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I love the parrot already.
  16. Feb 13, 2022 at 8:41 PM
    Key-Rei
    Key
    Florida
    What's the stainless basin in the wall there?
  17. Feb 13, 2022 at 8:43 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    for the dryer vent, so the flex attachment doesn't get kinked
    being that high I'm assuming a stacked set
    Pablo8 and Key-Rei[QUOTED] like this.
  18. Feb 13, 2022 at 8:47 PM
    Key-Rei
    Key
    Florida
    Okay. That's kinda what I was thinking what with the taps to the right but the space looked to tight for both but stacked set makes more sense.
  19. Feb 13, 2022 at 9:59 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Urinal.
    Lol. Recessed dryer vent. And yes, its stacked.
  20. Feb 13, 2022 at 10:14 PM
    Key-Rei
    Key
    Florida
    That was actually the other guess. :anonymous:
    Slashaar, wilcam47 and photogr4x4 like this.
