Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Feb 28, 2022 at 9:10 AM
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    I usually pre-twist them a half turn or so with pliers first. Don't know if that is the right way but it seems to help :notsure:
    truchador and tacoma_ca like this.
  2. Feb 28, 2022 at 10:09 AM
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    Got some pallets for free at a Chrysler dealer. Going to separate them and start the prep work for my dartboard. Also i bought an "vintage" Craftsman miter box without a saw a couple months ago at a thrift shop. I just got a saw at HD just to have it. it will work well for the pallets.
  3. Feb 28, 2022 at 11:51 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Grab a pair of linemans pliers and pre twist a few turns, I go until the insulation starts to form a nice looking braid. Then use a good wire nut. I like the Ideal Twister or Wing Twist ones from Lowes. The cheapo store brand Home Depot/Lowes wire nuts are the type that I do not trust. They just dont seem to bite into the wire as much.
    truchador and Drainbung like this.
  4. Feb 28, 2022 at 12:24 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    You’ll see when you get them but there shouldn’t be any problems with them staying down. Especially in a residential application, where there is no movement or vibrations. However if you feel more comfortable using tape, it won’t hurt.
    Never had any problems on machines with vibrations and moving parts. We have some Apexer machines that have a heater on a blade. The blade is on a cylinder so it moves in to make a cut. And the whole assembly also moves and has a bunch of moving parts. Long story short, there isn’t a junction box or panel mounted there close enough to the heater. The wires coming off the heater are only like 1ft in length, and you need some slack for movement. Wire nuts would hold a little better but I don’t recall any time where a wire pulled out. The Wagos are great for hot swaps. No need to kill the circuit or power to the machine. Saves in time too vs wire nuts, especially since it’s tight with all the guards because of the moving parts.
  5. Feb 28, 2022 at 2:16 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    I think once you handle them you wont bother with electrical tap. Theres actually a decent amount of force required to open/close them. Not a ton but more than you think.
    Pre twist them for sure. They way I was shown is pretty much to twist them with linesmen pliers (or whatever pliers you have), the wires should basically stay together pretty well even without the wire nut on and that "joint" shouldnt just fall apart even with moving it around a bit. Then add the wire nut. Takes some practice to get used to when you only do it every so often.
  6. Feb 28, 2022 at 2:18 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I like Wagos in industrial control cabs (only when needed) especially when theyve got an extra slot open to stick a meter lead into easily. Hard to do that with a wire nut thats all goobered up in electrical tape.
    mbarbay and Lawfarin[QUOTED] like this.
  7. Feb 28, 2022 at 2:26 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    No Balvenie?
  8. Feb 28, 2022 at 2:46 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Getting in to the final stages. Got siding put up today, was definitely a struggle putting it up by myself, but got it done. Ain't the prettiest, but some trim, paint, and caulk will fix it all up!
    Started some of the 1x work around the bottom, but didn't go too far. Still need to get the door in.
    Siding sits about 1/2" off the concrete to prevent rot issues, even though the siding is called "treated." I wanted to go with a better siding, but due to price and availability I had to go with 3/8" LP SmartSide engineered (OSB type). Was easy to cut and nail up though. I went around with my 16ga air finish gun to hang it, but will physically nail it tomorrow.
    Also was concerned about the height of the header for the garage door opening, which would be about exactly the height where the garage door open rest. Seems I have room to spare and the Tacoma fits in it all nicely. (Yes, it's filthy, don't remind me. Haven't been able to wash it for a month due to moving and weather...)
    Gonna try and get a door, put it in, and do the rest of the 1x4 done tomorrow if possible.
  9. Feb 28, 2022 at 4:03 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    I can't remember the last time I saw a TV antenna on top of a house!
    Pablo8 and Delta09 like this.
  10. Feb 28, 2022 at 4:11 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    It's actually at the back of it.
    Still gotta figure out how to get that big bastard down and out of here. Probably gonna have to pay someone as I don't get on roof height...
    4x4Taco2012, Sig45 and Pablo8 like this.
  11. Feb 28, 2022 at 5:45 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Leave it and put your Starlink internet dish on top of it.
  12. Feb 28, 2022 at 5:47 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    o_O
    Even though I'm considered out in the country, since I'm on a main road I'm fortunate to get cable. That was one of the selling features of this house. I won't fool with any other internet sources around here.
  13. Feb 28, 2022 at 5:50 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    HF radio antenna? My dad would be ecstatic to have that on the property.
  14. Feb 28, 2022 at 5:57 PM
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    If you weren't so far, I'd come and take it down to reuse for my GMRS base antenna!
    TwistedTLM4 and Delta09[QUOTED] like this.
  15. Feb 28, 2022 at 6:02 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    It would be a crime to paint those white.
  16. Feb 28, 2022 at 6:12 PM
    Key-Rei
    Key
    Florida
    Could someone recommend me a "smart" thermostat to replace this ancient relic of a bygone era?
    Doesn't have to connect to the internet, in fact I would much prefer if it didn't, but something I could set up to run on a schedule?
    My Name is Rahl likes this.
  17. Feb 28, 2022 at 6:28 PM
    Toyko Joe
    Toyko Joe Here for the pictures
  18. Feb 28, 2022 at 6:33 PM
    907rx7
    James
    Made a little progress on standardizing and sorting things in the garage.
  19. Feb 28, 2022 at 6:35 PM
    My Name is Rahl
    I paid $18 for a Honeywell thing at Menards. It has a 2 way schedule.
    Key-Rei[QUOTED] and SRH like this.
  20. Feb 28, 2022 at 6:36 PM
    SRH
    SRH My horns hold up my halo
    Shauna
    2018 Sport
    Ummmm thought you were going to bed, young man!:D
