Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 1, 2022 at 2:32 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Door and trim installed today. Gonna take some work to get the 1x's looking good. I picked out the best treated boards I could find. Didn't need treated on all of it, but the boards looked better than the pine 1x4's. I wasn't splurging on the pre-primed. Those don't seem to hold up outside anyways. So, once they dry out I'll get a good coat of primer on them and fill/caulk as needed.
  2. Mar 1, 2022 at 2:44 PM
    My Name is Rahl
    If your dining room baseboard has an ogee, then yes, a tiny miter instead of a boxed end would look better.
    truchador and wilcam47 like this.
  3. Mar 1, 2022 at 2:49 PM
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Okay, but if we use flat baseboards, then it would be okay to just keep it boxed? We're not a fan of baseboards with profile; it doesn't really match the house very well or our furniture choices.
  4. Mar 1, 2022 at 2:52 PM
    My Name is Rahl
    What is your baseboard material? Are you ok with seeing end grain? How exactly "polished" do you want it to look? Do you want to go through all of the trouble to fix all that and then leave off one little detail?
    truchador and kmorgan3[QUOTED] like this.
  5. Mar 1, 2022 at 3:21 PM
    kmorgan3
    Kyle
    PNW
    All good things to consider! The baseboards are going to be painted a fairly dark gray (hints of blue), so any grain that would be exposed I guess would be completely covered. MDF seems like a logical choice since the wood won't be visible. With that in mind, I guess the question is whether a flat edge would be polished "enough" (no end grain showing) or if I should try to make a little self-return on a miter. I just don't want it to look like an afterthought if I lop the edge and leave it.
  6. Mar 1, 2022 at 3:21 PM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Garage looks good, may it stay forever clutter free lol
    I know it’s sorta too late, you already installed the bottom trim like it was interior baseboard, but………
    you need to bend up or purchase https://www.homedepot.com/p/Gibralt...derized-Steel-Z-Bar-Flashing-SZB34B/202092871 some metal to flash the top edge of that trim then figure out a way to tuck it 3-4” up behind the siding. Unfortunately this is likely going to mean pulling the trim and cutting (then paint) the siding 3/8” above it’s top edge. Water’s gonna get in there for sure and have a hard time drying out the way you have it and rot/capillary spread moisture will occur, engineered wood or not.
  7. Mar 1, 2022 at 3:26 PM
    My Name is Rahl
    Sounds like you answered your own question.
  8. Mar 1, 2022 at 3:33 PM
    truchador
    Otto
    WV
    15 DC OR
    I vote miter
    My Name is Rahl likes this.
  9. Mar 1, 2022 at 3:42 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yea, that was a pretty big oversight by me, you're absolutely correct. I (well at the time hired out, was young and didn't know how to do anything) enclosed my carport at my old house in Mississippi the same way. It seemed to hold up pretty well. I did keep on top of the caulking and paint though. Got about the same amount of rain as we do here. When prices come down I want to change the siding out anyways to a cement ship lap style. This is a quick budget minded job.
  10. Mar 1, 2022 at 3:51 PM
    truchador
    Otto
    WV
    15 DC OR
    Sounds good :)
    I went with the LP lap siding over the hardi/cement option
    Everything about it is easier to work with and if you install it right with good drainage/drying pathways there should be no difference in longevity
    Delta09[QUOTED] likes this.
  11. Mar 1, 2022 at 3:56 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    For the time being I'll be using Dynaflex 230 to seal everything up. It holds up a lot better than your typical painters caulk. Gotta give the treated wood about a month to dry out before I sand, oil prime, caulk, and paint everything. Unfortunately there will be bouts of rain till then, but it is what it is...
    Sig45 and truchador[QUOTED] like this.
  12. Mar 1, 2022 at 6:57 PM
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    Made a little more progress today trying to decide if I need one more row of the clear bins before I do one for parts/fastener organizers
    Bagman, Slashaar, ColoradoTJ and 6 others like this.
  13. Mar 2, 2022 at 3:30 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Miter that corner.
    truchador likes this.
  14. Mar 2, 2022 at 6:18 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Not much compared to some of y'all but I completed my very first home improvement project on my very first house, replaced the busted screen door handles so they don't creak and slam in the breeze and wake me up.
    PXL_20220302_040305650.jpg PXL_20220302_040259122.jpg PXL_20220302_134947523.jpg PXL_20220302_135022014.jpg
  15. Mar 2, 2022 at 8:23 AM
    kmorgan3
    Kyle
    PNW
    :rofl: Okay I'll make a little self-return on there. I agree it would be cleaner. Give me a couple of weeks and we should be done. Thanks!
  16. Mar 2, 2022 at 8:52 AM
    TinoTaco
    TinoTaco Well-Known Member
    Nanaimo
    2017 TRD DCSB Off-Road - White
    It might be nothing, but with that being an outside corner and especially by some steps that I assume would be somewhat high traffic, how resilient do y'all feel mdf trim would be to dings/kicks?
    I'm a klutz that smacks into corners with my feet almost daily, and my kids have seemingly picked up that gene (yippee!), I just think that a solid wood baseboard would hold up a bit better. Even if it was just for that run, and ya switched back to MDF for the rest of the run, primed and painted should blend well.
    That said, I 'assumed' in my thinking, so you know what that means...:notsure:
    TwistedTLM4 likes this.
  17. Mar 2, 2022 at 8:58 AM
    kmorgan3
    Kyle
    PNW
    That’s a good point! I don’t think it’ll be too big of an issue in that specific corner. There’s a pretty wide gap where the flow of traffic should go between my table and the kitchen entrance.
    I think the biggest threat to that corner is the dog who’s bowls those are :rofl:
    The riser board should be solid wood, though, for sure.
    Slashaar and TinoTaco[QUOTED] like this.
  18. Mar 2, 2022 at 9:09 AM
    TinoTaco
    Nanaimo
    haha awesome! Ya the previous pic made it look like it was a lot narrower. Somehow with a 6 or 8ft wide opening, I would still find a way to stub my pinky toe on that corner every other day... Anyone sell steel toed slippers?
    kmorgan3[QUOTED] likes this.
  19. Mar 2, 2022 at 9:10 AM
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    Can't go wrong with Dynaflex 230
    May I suggest using Arborcoat Stain or Superdeck Solid color stain for your trim unless you want a higher sheen than flat. Both will save you the priming step, easy to use/clean up and because it's deck rated it stands up very well on trim.
    https://www.benjaminmoore.com/en-ca...atalog/bmaes/arborcoat-premium-exterior-stain
    https://www.sherwin-williams.com/homeowners/products/superdeck-solid-color-stain-250-voc
    Great job on your garage
    tacoma_ca and Delta09[QUOTED] like this.
  20. Mar 2, 2022 at 10:58 AM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    Does anyone have suggestion for storage/organization totes or boxes for garage/basement use?
    I'm going to put some garage shelving in my small basement, and I want to put stuff in some kind of box or tote, to protect all the stuff from getting dirty and dusty. It'll be mostly stuff I don't need very often. It's currently taking up space in a bedroom that needs to become a nursery.
    wilcam47 likes this.
