Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 2, 2022 at 11:25 AM
    My Name is Rahl
  2. Mar 2, 2022 at 11:27 AM
    98tacoma27
    Ben
    Not Beech Creek
    We use those totes as well. You can get them at any box store but we have found Sam's to be the cheapest.
  3. Mar 2, 2022 at 1:35 PM
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    Yep, I got those at Costco they are greenmade brand made in the USA. Slightly thicker plastic than the Lowe's and HD alternatives. The clear bin stack are Buckle up storage bins, 4 packs at Costco also made in the USA.
  4. Mar 2, 2022 at 2:06 PM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    yea, those seem to the be the go to, but if theres something that doesn't have a taper toward the bottom, so there isn't any wasted space between each tote (they'll be arranged side by side), that'd be ideal.
  5. Mar 2, 2022 at 2:12 PM
    98tacoma27
    Ben
    Not Beech Creek
    They all have a slight taper to them. That's for the molding process
    DarthPow[QUOTED] likes this.
  6. Mar 2, 2022 at 2:54 PM
    907rx7
    James
    Keep in mind these are fairly small the larger the totes, the less space wasted.
  7. Mar 2, 2022 at 3:02 PM
    DarthPow
    oh i figured the taper was for stacking during shipping/storage in the store.
    yea, i guess that's true.
    98tacoma27[QUOTED] likes this.
  8. Mar 2, 2022 at 3:03 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    My trim, eaves, planter boxes, and garage door are all Arborcoat solid color in Oxford Brown. The quality, toughness, and look are totally worth the cost and it sprays well without dilution.
    These eaves were trashed before sanding and a single heavy spray coat around 3 years ago and the finish is essentially indestructible. Arborcoat is really solid paint. Color is more dark dark brown than the pic which seems more pinkish on the monitor.
  9. Mar 2, 2022 at 4:22 PM
    907rx7
    James
    These are what I had before, went smaller because with these I was letting them get too heavy.
  10. Mar 2, 2022 at 6:45 PM
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    Costco or Sams have Collapsible Crates that I use a lot. The are more expensive but have no taper and are stackable. Here is a couple of pics. I use them in the garage or in my office/spare room. I fill them up with tools, clothes, food, camping, fishing, and/or shooting supplies and then load them up in my truck platform drawer system according to my need/destination. They have a small lip so I’m sure you could design a rack to hold them. Mine just sit on my gorilla racks. Right now they are about $12 but Costco will put them on sale for $8 every now and then. That’s when I buy them.
  11. Mar 2, 2022 at 9:17 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Been working on a laundry room remodel over the last month or so. Decided to do a butcher block counter top, with a table to go over the washer dryer. We wanted something that we could slide out to access the water shutoffs.
    Holes drilled, welding completed and butcher block mounted. It test fit good, so need to stain the block and paint the legs. Also waiting on some tubing caps/plugs for the feet. Happy with the way that it turned out.
    la0d0g, dumontrider, Bagman and 17 others like this.
  12. Mar 2, 2022 at 11:01 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Hey 1995?
    Yeah 2022 called, it said "Fuck your popcorn ceilings."
    :bananadead:
    Pro tip:
    Do this on a cool day and open the windows then put a carpet fan at the crack of the closed door to create positive pressure keeping the dust out of the rest of the house and at a minimum in the room.
    I still strongly recommend a mask though.
    I've always disliked popcorn ceilings but now I have a new HATRED and many sore spots about it.
    There's got to be a be a better way than a 4" paint scraper and elbow grease.
    It's especially difficult around the mudded areas and seams for whatever reason.
    I still need to sand those spots and address the gouges as well as fill in a few holes in the walls before paint.
    What's the best way to do that?
    Yup, that's black, stay tuned.
  13. Mar 3, 2022 at 3:15 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Nice job. Next time, use a pump sprayer and soak that ceiling good with water, it'll come/peel off dust free.
  14. Mar 3, 2022 at 3:24 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Its called hang new drywall over top of them. Adds a little extra insulation too.
    Key-Rei[QUOTED] and OZ-T like this.
  15. Mar 3, 2022 at 5:57 AM
    98tacoma27
    Ben
    Not Beech Creek
    That too!
  16. Mar 3, 2022 at 6:33 AM
    My Name is Rahl
    More expensive that way, but sure.
    Sig45 and wilcam47 like this.
  17. Mar 3, 2022 at 6:40 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    If you’re gonna spend the time to add drywall over top of existing drywall, IMO you’re better off just pulling the old stuff down and doing it proper.
    SRH, la0d0g, Slashaar and 5 others like this.
  18. Mar 3, 2022 at 7:25 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    That's a very good suggestion! However the 1x4's need a good bit of sanding and filling, end even then might not look good staining (even solid color). I have a good bit of Sherwin Williams A100 Satin in white to use up, and it should match the house better. The siding I'm debating going a dark brown to match the brick mortar, or maybe a burgundy to match the brick. Not sure.
    Sig45 and My Name is Rahl like this.
  19. Mar 3, 2022 at 7:33 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    this
    Clark27 and Blue92[QUOTED] like this.
  20. Mar 3, 2022 at 8:05 AM
    DarthPow
    this looks like exactly what I'm looking for, I'll check out costco and try to find them. if you have a link, I'd appreciate it!
