Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 6, 2022 at 11:19 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Alright, I'll pick up some Kilz primer/sealer then, add another day to the project I guess...
    :bananadead:
    I really want to start moving into there and start setting everything up but do it right the first time instead of again later after being annoyed long term.
    Much easier now before everything is mounted to walls and such right?
    I did mask off the window and put joint compound to fill the gouges from popcorn removal, need to sand it smooth then two coats of kilz drywall primer/sealer all around then I can go blackout?
    Not a golfer[QUOTED] likes this.
  2. Mar 6, 2022 at 11:22 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I did 2 on mine. 1 heavy coat may do it, the joint compound sucks it up more than the drywall so go until you cant see the white spots anymore.
    Key-Rei[QUOTED] likes this.
  3. Mar 6, 2022 at 11:56 AM
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    Sorry didn't want to add to your work load
    Best to do it right the first time
    Yes sand the drywall compound
    Apply the primer/sealer
    Lightly sand walls/ceiling after primer
    Apply finish coats
    A tip
    First coat
    Roll first on surfaces (get close to corners as possible)
    Then cut in with brush
    Second
    Cut first then roll
    Helps save time
  4. Mar 6, 2022 at 12:05 PM
    Key-Rei
    Key
    Florida
    Nah I want to do it as best as I can; this is going to be a studio of sorts I will spend a lot of time in and hopefully can make some money with it needs to be done as professionally as possible if that means a little more work so be it, still saving lots of money doing it myself.
  5. Mar 6, 2022 at 12:08 PM
    Key-Rei
    Key
    Florida
    Sanding this afternoon, may put up the quarter round for the lighting too, probably best to do so before painting as it needs painted as well.
    Got to paint the furniture too.
    Supposed to rain hard all this week starting tomorrow.
  6. Mar 6, 2022 at 12:20 PM
    Not a golfer
    Calgary, Alberta
    Got your work cut out
    Go at your own speed
    Do it right
    Show off your hard work after
    With much bragging of course
  7. Mar 6, 2022 at 12:25 PM
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
    Plumbed and mounted my car wash station today. Gotta keep the taco clean!
  8. Mar 6, 2022 at 1:34 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Don't do it nice because you do it twice .....
    Slashaar likes this.
  9. Mar 6, 2022 at 3:06 PM
    Key-Rei
    Key
    Florida
    Running back to the depot to pick up this stage of things, when you say lightly sand would that be about 200 grit? Or just minimal passes with like 120?
    KILZ2 should be enough?
    Think I'll do one coat on the walls and two coats on the ceiling, should I sand the existing paint on the walls? I cleaned them real good with diluted APC and a magic eraser then wiped them down further with a damp rag.
    Somebody said something about spray bombing with kilz, I thought it rolled on like paint? I'm not set up to spray it. I might be able to borrow a spray rig from my uncle, should I wait and do that or can I just roll it?
  10. Mar 6, 2022 at 3:11 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Im rolling on some Kilz 2 this afternoon. Does great on a roller, 3/8 nap is what Ive got. 2 coats should work for you, Im doing 3 since Im hiding some super dark paint.
    I highly recommend Kilz PVA for the new drywall. Kilz 2 will work, but you'll need a lot of coats.
  11. Mar 6, 2022 at 3:13 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    The 'spray bomb' may have been a reference to the oil based Kilz primer spray can. The oil based sticks/blocks better but stinks more. Small spray areas for stains with this don't stink as bad as doing the whole room with oil based.
    Not a golfer likes this.
  12. Mar 6, 2022 at 3:14 PM
    Key-Rei
    Key
    Florida
    I don't know if it matters or not, but it's not really new drywall, I'd assume it's from 1995 like the rest of the house, I just stripped it down bare because I couldn't stand the popcorn ceiling in the room I'm going to be spending my most time in.
  13. Mar 6, 2022 at 3:25 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Id still probably do PVA primer on it. You stripped it down to bare paper. The PVA (poly vinyl acetate) is essentially a layer of plastic/rubber that seals all the pores on the gypsum. Its like painting with glue, but anything else will just soak in and require more coats than you wanna do to cover it.
    Not a golfer and Key-Rei[QUOTED] like this.
  14. Mar 6, 2022 at 3:56 PM
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    For sandpaper
    Start with 100 or 120 and then move to a finer grit like 220 or 440. The courser sand paper will take the bulk material. The higher grit will smooth everything out.
  15. Mar 7, 2022 at 6:46 AM
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
    2018 Tacoma TRD Offroad
    love love love. Clean and organized! Well done
    Slashaar and FLAK-TAC[QUOTED] like this.
  16. Mar 7, 2022 at 10:02 AM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    Filled /sanded / painted the baseboards where I removed the door stoppers (boooiiiiinnnnggggg). Came out good enough that I'll be the only one to know what was where. Replaced them with these magnetic popup thingys. Like them so far, needed the "hold open" feature as the wind blows the bedroom door closed. With these new solid core doors that slam was big! Need to scrape the over spray off the floors but it's behind a bookshelf so *shrug*
    Got the 1st coat of chalkboard paint put on the coat closet door. Will need a 2nd coat but I'm looking forward to the results.
  17. Mar 7, 2022 at 2:29 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    That's slick!
  18. Mar 7, 2022 at 5:40 PM
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    Nice clean set-up. Pun intended. :D
  19. Mar 8, 2022 at 6:30 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Link for door stop thingie?
    My Name is Rahl likes this.
  20. Mar 8, 2022 at 6:34 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Yesterday I sawed the base of a stump that was around 18" with my 80V chainsaw. The chain got VERY hot, but still did fine. This is with the 6AH battery, then II popped the battery out, put it my stick blower (I have the backpack blower as well) - I then used the blower as a bellows for my huge wettish burn pile. Made an induction hole, locked in the blower a a medium low blow, set it down and tended the fire while I tilled my garden plots. The heat was INTENSE in the glory hole. Glassified the dirt in any sod clods. Blower ran a LONG time (over and hour), then I swapped in a 2A, and so on. Nothing left of burn pile and hardly much smoke. Winning.
    Tilled the main garden plot and the flower garden plot with my Troy Built horse bought new in the 1980's. Well maintained, ran perfectly!
