Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 8, 2022 at 7:39 AM
    Denk
    Denk Well-Known Member
    PNW
    '13 Spruce TRD Sport DCSB
    My FIL is looking for a battery chainsaw. What you got?
  2. Mar 8, 2022 at 7:45 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Greenworks Pro
    Denk[QUOTED] likes this.
  3. Mar 8, 2022 at 12:35 PM
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
    Not much, but added some more storage space in the attic. Since we only have one sheet of decking, storage is limited. Had to take out a bunch of stuff so the alarm guy could run wire for a heat sensor so I made use of the access I had. Used scrap 3/4 ply and 2x
  4. Mar 8, 2022 at 2:12 PM
    ty.s07
    ty.s07 Well-Known Member
    Alabama
    I need to do this before the summer.
    Key-Rei and trdNick[QUOTED] like this.
  5. Mar 8, 2022 at 2:58 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Yup, summer is coming, it's project time while it's cool!
    At least fear of Florida sun is what's motivating me!
    My Name is Rahl and trdNick like this.
  6. Mar 8, 2022 at 4:21 PM
    My Name is Rahl
    Don't forget to condition the chalkboard paint, if you don't know that already.
    X2!
  7. Mar 8, 2022 at 8:21 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    My hot water heater started to leak today. It has a 10 year limited warranty. Gotta hand it to their engineers.
  8. Mar 8, 2022 at 8:24 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    Liked but hated.
  9. Mar 8, 2022 at 8:31 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
  10. Mar 8, 2022 at 8:33 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    wouldn't that be 10 years from date of service?
    but wow
  11. Mar 8, 2022 at 9:35 PM
    jsi
    jsi Well-Known Member
    native earthling
    In the summer my attic gets center of the sun hot. Doesn't your stuff get cooked, or do you just store stuff that isn't sensitive to heat?
    truchador likes this.
  12. Mar 8, 2022 at 10:36 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    Yep, their instructions stress the "break in" in bold print!
    Link to door stoppy & holdy openers:
    https://www.amazon.com/dp/B08371Z58N?_encoding=UTF8
    Slashaar and Key-Rei like this.
  13. Mar 8, 2022 at 11:50 PM
    Key-Rei
    Key
    Florida
    Engineered obsolescence/failure.
    If you make it last forever they'll never need to buy another one!
    :smack:
    Cudgel[QUOTED] and Slashaar like this.
  14. Mar 9, 2022 at 12:34 AM
    Key-Rei
    Key
    Florida
    Wow does this home improvement crap take time I figured I'd be enjoying my room all set up to the nines by now.
    I ain't even got paint up.
    I will be ready for paint tomorrow for sure!
    J̶u̶s̶t̶ ̶l̶i̶k̶e̶ ̶I̶ ̶t̶h̶o̶u̶g̶h̶t̶ ̶t̶h̶e̶ ̶l̶a̶s̶t̶ ̶6̶ ̶t̶i̶m̶e̶s̶ ̶b̶e̶f̶o̶r̶e̶ ̶I̶ ̶r̶e̶a̶l̶i̶z̶e̶d̶ ̶I̶ ̶h̶a̶d̶ ̶m̶o̶r̶e̶ ̶t̶o̶ ̶d̶o̶.̶
    Got the quarter round up all around for the indirect LED lighting strips.
    Waiting for the hardware store to open to pickup more spackling to fill the nail and screw holes.
    Learned some interesting things about the house.
    Interior walls are studs 24" on center exterior walls are studs 16" on center with no studs above the windows or doors, figured they would be framed out above too but no, had to get pretty liberal with drywall anchors here and there was hoping to do all with nails so much smaller and minimal holes to patch.
    I did pick up some KILZ PVA for everything.
    First I rough measured and hung with gaff tape.
    Then I made myself a speed block to ditch the finicky tape measure.
    Discovering there's no studs above the window...
    All done with the trim, I ran a 5' straight edge level around everything it's an optical illusion that the spacing looks off on the left side in the photo it looks perfect to the eye in person but looking at the picture wigged me out thought I somehow screwed up big time.
    My joints came out okay but not as tight as I would have wanted, need a miter saw for better work there but nothing spackling can't fix.
    Next time I will 45° overlap my mid seams, didn't think about that until I was already done with it and noticed this in the hall.
    :facepalm:
  15. Mar 9, 2022 at 12:57 AM
    Key-Rei
    Key
    Florida
    This outlet was showing a bad ground, killed the breaker pulled it out discovered the twisted pair was covered in paint and loose; separated them, a little quick brillo wheel Dremel work, some pliers and a good twist and we're all green.
    Electrical work is not my strong suit and frankly makes me a little nervous most of the time but not burning my house down is definitely worth looking into.
  16. Mar 9, 2022 at 5:07 AM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    Understood. Remarkable how well they pulled it off.
    Key-Rei[QUOTED] likes this.
  17. Mar 9, 2022 at 5:21 AM
    Key-Rei
    Key
    Florida
    To the freaking day, that is impressive and sad.
    I had a car battery die within warranty, and the lady running the counter didn't want to warranty it because I only had three days left she said I may as well just buy a new one since there won't be a warranty I said I'd rather not shell off 300 bucks for something I can get for free.
    Honestly with as close as it is I would fight with the warranty department, just because you noticed it leaking when you did doesn't mean it hadn't failed prior to that at least that's the argument I would bring up.
    wilcam47 and Toyko Joe like this.
  18. Mar 9, 2022 at 5:35 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    We had the same thing happen, warranty was out by about a month. Simple phone call and we had it pro-rated. About a $100 refund on a water heater that was 6 years old and $300 when new.
    Key-Rei likes this.
  19. Mar 9, 2022 at 5:35 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    :eek: A battery they didn’t want to warranty because you only had days left of a warranty? Come on that’s absurd.
    Our Subaru went through 4 batteries in 4 years, every single one of them was within a month or two of the warranty. We had a nice long paper trail of them being replaced and noting their leaks. Car batteries when replaced, their warranty window is by the battery not the car’s warranty.
  20. Mar 9, 2022 at 6:22 AM
    FortuneFavorstheBruin
    FortuneFavorstheBruin Well-Known Member
    Zack
    Austin, Texas
    2018 Tacoma Off-Road
    Can somebody point me to a good guide as to how to re-wire these 3 light switches into a single combined unit? I can't believe this was wired into 3 separate switches, the house is only 5 years old.
    Top controls outdoor flood lights
    Middle controls patio fan
    Bottom controls patio central lighting
    What i'd like to do is turn it into something like this: https://www.homedepot.com/p/Leviton...bination-Switch-White-R62-01755-0WS/100356847
    dmurph1996 and wilcam47 like this.
