Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 15, 2022 at 3:08 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    I hate painting.
  2. Mar 15, 2022 at 3:13 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Same:fistbump:
    Not a golfer, truchador and Drainbung like this.
  3. Mar 15, 2022 at 4:09 PM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    :rasta: + music allegedly helps to make painting less awful
    within reason of course
  4. Mar 15, 2022 at 4:22 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    The Graco power roller (on a HF Krause & Becker pump) was a bit much of an uncontrolled mess (priming etc.) for interiors so I recently got the Wagner Sidekick for a couple rooms. It cleans up easily (just put in garage sink and let it run water for a bit) and saves time, but most importantly it is a lot less annoying when you don't have to keep refreshing the roller. It 'just pumps' when you hit the button on the roller and doesn't need (possibly messy) priming like a real sprayer. I felt like it paid for itself the first time I tried it.
  5. Mar 15, 2022 at 5:10 PM
    My Name is Rahl
  6. Mar 15, 2022 at 5:47 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I have 1 organizer that was given to me
  7. Mar 15, 2022 at 6:21 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Today I learned that slab hollow core doors are 1/4" wider than a normal prehung door.
    :bananadead:
    Guess tomorrow Ill be ripping 1/4" off the side of this thing.
    Slashaar, truchador and wilcam47 like this.
  8. Mar 15, 2022 at 6:43 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    Planer?
  9. Mar 15, 2022 at 6:48 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    All I got is a skilsaw and a fence. Gonna make it work. The rest of the doors Ill be going with prehung units.
    wilcam47 likes this.
  10. Mar 15, 2022 at 6:59 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    Did that x6 over the last 6 weeks. Things learned:
    • Use a nice blade, 60+ tooth thin kerf crosscut
    • Score the cut line with a blade
    • Use a guide, don't try to free hand 7' of cut!
    • Masking tape on the topside of the cut
    • Cut 1/8 and test fit it. I thought I needed 1/4 off but that first door now has a nice gap of daylight.
    • Good luck!
    Today I threw a 2nd coat of chalkboard paint on the pantry door & peeled off the masking tape. Not at all happy with the edges...maybe because I didn't pay the FrogTape tax? Regular Scotch blue tape....paint bled all under it, but randomly, like every couple feet there's a "vein" of paint that made its way up. And then because the 1st coat dried on top of the tape I had it peeling paint away in spots as I removed it. Maybe I should've scored it with a blade prior to peeling it? I'm thinking about getting a hobby brush and cleaning up the edges. Here's a pic, I won't zoom in on the edges for you critical animals to pick me apart!
    Slashaar, Delta09, Sig45 and 5 others like this.
  11. Mar 15, 2022 at 7:30 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Slashaar and dumontrider like this.
  12. Mar 15, 2022 at 8:59 PM
    la0d0g
    running for the hills
    For crawling not hauling
    You look so professional!
    Slashaar, truchador and Drainbung like this.
  13. Mar 15, 2022 at 9:32 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Pee outdoors
    Slashaar and Key-Rei like this.
  14. Mar 15, 2022 at 9:36 PM
    Key-Rei
    Key
    Florida
    Slashaar likes this.
  15. Mar 15, 2022 at 9:37 PM
    ScrippsRanch67
    Bob
    Fiberglass shell
    Nothing like fresh air....
    Slashaar and Key-Rei[QUOTED] like this.
  16. Mar 15, 2022 at 11:14 PM
    tacoma_ca
    LOL just for full disclosure that pic is from their website and my house still reps the 70's for better or worse, including some popcorn ceilings still.
  17. Mar 16, 2022 at 2:49 AM
    Key-Rei
    Key
    Florida
    Good lord do I hate popcorn ceilings.
  18. Mar 16, 2022 at 5:31 AM
    My Name is Rahl
    Try peeling the tape maybe 10-15 minutes after applying the paint and before it dries completely. That will help with the paint peeling away in spots.
    The other thing is either paying for higher quality tape, or making sure the edges are pressed down tight.
  19. Mar 16, 2022 at 5:35 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    You can also caulk the tape edge. Smear it along the seam nicely and wipe off excess. Leaves a very clean line.
  20. Mar 16, 2022 at 5:45 AM
    la0d0g
    Great tip!
    Sig45[QUOTED] likes this.
