Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 17, 2022 at 2:52 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    One coat hide my ass.
    A little doodle I did planning something else was still somewhat wet when I painted over it and you can still see it coming through, glad I did two coats of primer, and got enough paint for two coats too.
    Took me about 2 gallons to do the walls ceiling and the desks on top of the Kilz.
    Coat 1 done.
    They ain't kidding it makes the room feel smaller.
    Very cozy I like it.
    Aforementioned doodle.
    I also lost a bet to 7th grade me and had to slap up one of these bad boys too.
    Can't see that one covered up but irregardless everything definitely needs a 2nd coat even if it already looks great.
    So thanks @Not a golfer and whomever else steered me in the right direction of "one coat" being marketing wank.
    Before painting I knew I would be replacing the outlets and switches so I found the best ones in the room and swapped then out for the worst ones else where in the house so I could just paint over ones I was cool with throwing away as they keep the wires free of paint.
    Keeping my brushes and tray wet for tomorrow's second coat.
    And accelerating drying with clean air circulation!
    Little spooky in there right now with the lights off, it's like turning the room off too.
    :anonymous:
  2. Mar 17, 2022 at 3:01 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    What’s with all the black?
    wilcam47 likes this.
  3. Mar 17, 2022 at 4:03 AM
    Key-Rei
    Key
    Florida
    Reduces IR reflections for VR.
    Slashaar likes this.
  4. Mar 17, 2022 at 6:50 AM
    My Name is Rahl
    Gaming?
  5. Mar 17, 2022 at 6:57 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I hope...;)
  6. Mar 17, 2022 at 9:36 AM
    TinoTaco
    TinoTaco Well-Known Member
    Nanaimo
    2017 TRD DCSB Off-Road - White
    if his next question is about weight rating of swing hangers in the ceiling, i'm not sure if I stay away from the thread for a week or two, or log in twice as much....:popcorn:
  7. Mar 17, 2022 at 9:45 AM
    wilcam47
    Will
    Bourbon state
    And black lights...im out
  8. Mar 17, 2022 at 10:19 AM
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    Well you've been busy. It's going to look great when you're all done. I see you've got a few tricks up your sleeve! keeping paint tools wrapped for over night (I do this for short periods time). After you've covered tray keep it in a cool area it's also helps. I usually wrap my paint sleeve still on the paint cage in a plastic bag and I clean my brush for over night (I use Purdy brushes and like to take extra care so they keep their shape). You can place the sleeve in the fridge (never the freezer) just take it out before to warm it up before usage. Using a fan for air movement in a closed off room helps with dry time.
    You'd make a great apprentice!
    LMAO at your comment about one coat coverage (Yeah I'm never a fan of using only one coat!)
    Thank you for mentioning me and others.
    Always glad to share my painting advise for you or anyone else who asks.
    Key-Rei[QUOTED] likes this.
  9. Mar 17, 2022 at 10:22 AM
    My Name is Rahl
    FTFY
  10. Mar 17, 2022 at 10:29 AM
    TinoTaco
    Nanaimo
    Oops my bad, ignorant assumption there
  11. Mar 17, 2022 at 10:33 AM
    Not a golfer
    Calgary, Alberta
    Never been a fan of power rollers
    But it really doesn't matter how you get there
    Main goal is to have the finish coat look good in the end
  12. Mar 17, 2022 at 10:47 AM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    Saves a lot of time/frustration which in my case pushes the project motivation enough that I am finally getting it done.
    Downside is I think 1/4" nap power roller covers are not available so am using 3/8". It comes out fine with the 3/8" so I decided to roll with it.
  13. Mar 17, 2022 at 10:57 AM
    Not a golfer
    Calgary, Alberta
    You didn't go wrong with the tape
    Scribe the tape with a putty knife to make sure it's completely flat at edge
    Never use tape as a slop guard
    Brush up to the tape using it as a guide
    When I want a super crisp edge. I'll seal the tape with the color of what I'm painting over. Let it dry than do my finish color.
    Yes scoring the tape before removing is wise
    Don't pull the tape straight up. Carefully pull off to the side making a cutting affect with the tape away from the fresh paint
    So if you got black on the white. You can clean it off with Goof Off. Dampen a rag place rag on small putty knife and gently rub the black off. Be careful because you can remove the white if you get to aggressive. Work up and down the surface not to much in one area at a time because that's when the Goof Off can soften the white.
    After cleaning up the edge retape. Using my taping and painting suggestion carefully redo the edge only with a small brush (like 1" brush). I think it should blend in without having to roll out the area again.
    dumontrider[QUOTED] and Key-Rei like this.
  14. Mar 17, 2022 at 11:02 AM
    Not a golfer
    Calgary, Alberta
    I always use a 1/2" or 3/4" rolling walls. You get more mileage out of a roller full and sometimes lite orange peel from a heavier roller is your best friend (it helps hind wall imperfections)
    Key-Rei likes this.
  15. Mar 17, 2022 at 11:05 AM
    Key-Rei
    Key
    Florida
  16. Mar 17, 2022 at 11:27 AM
    Key-Rei
    Key
    Florida
    You can use a hollowed out smoke alarm to...
    Or so I've heard.
    :anonymous:
  17. Mar 17, 2022 at 11:43 AM
    My Name is Rahl
    I didn't realize IR reflections in VR gaming was an issue?
    I think I saw a TikTok about that yesterday...
  18. Mar 17, 2022 at 11:58 AM
    Key-Rei
    Key
    Florida
    When doing full body tracking especially; glass top desks, shiny screens, even glossy or bright paint can induce duplicate false tracking points hopefully this eliminates that.
    Plus as this room will be a gaming/theater room having it be dark with indirect mood lighting should really concentrate immersion.
    I do believe their algorithm suggests videos based on your interests...
    :rofl:
  19. Mar 17, 2022 at 12:08 PM
    My Name is Rahl
    Full body what now?
    Also, :anonymous:
  20. Mar 17, 2022 at 12:10 PM
    Key-Rei
    Key
    Florida
    Full body tracking:
