Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 18, 2022 at 11:40 AM
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    Two coats in my opinion is best
    Ben's Ultra 500 line is good and still better than other manufacturers (again IMO)
    Ultra is more wallet friendly for B&M
    Blue92[QUOTED] likes this.
  2. Mar 18, 2022 at 11:41 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    https://www.commercialmatsandrubber.com/anti-fatigue-mats/interlocking-anti-fatigue-mats/
  3. Mar 18, 2022 at 11:41 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Would this work? edit: just read “something similar to horse stall mat”, this ain’t gonna work!
  4. Mar 18, 2022 at 11:51 AM
    jsi
    jsi Well-Known Member
    native earthling
    My son built a basement gym and went with wall to wall horse stall mat. It turned out kind of nice and the stuff is indestructible. There was a strong rubber smell that eventually dissipated. I wouldn't call it soft and plush, but you can drop weights on it without a mark.
  5. Mar 18, 2022 at 11:55 AM
    jsi
    native earthling
    I had those in my basement and they're junk. The best soft pads I've seen are at the ones at restaurant supply places. Cushy and durable for cooks that have to stand on hard floors all day.
    Key-Rei likes this.
  6. Mar 18, 2022 at 12:09 PM
    Not a golfer
    Calgary, Alberta
    So I'm going to poke the bear cause I know ceiling painting isn't fun
    If you have a water stain on your unpainted ceiling texture (popcorn AKA snow tex, orange peel or knock down) your new home is likely orange peel
    Take a spray bottle mix 50/50 bleach/water lightly spray stain (it may take a few spray times). Don't over apply mixture on the texture just dampen
    In most cases it will remove the water stain without painting
    Painting popcorn ceilings for the first time by hand or by spray you need to be careful
    The texture is water based so if you use water based paint and over work or spray to heavy
    It's like mixing the texture up from powered stage again
    The more contact/paint applied on the texture more likely it will start releasing from the drywall
    I'll use a split foam roller and oil based paint when the ceiling hasn't been painted before if I choose not to spray (occupied home)
    No matter what, if you paint a popcorn ceiling by hand YUP that sh!t is messy
    I do spray ceilings only if I can cover surfaces to protect from overspray/paint dust (dryfall)
    tacoma_ca and Key-Rei like this.
  7. Mar 18, 2022 at 12:16 PM
    Not a golfer
    Calgary, Alberta
    LOOK AT YOU
    That paint looks great. You may want to leave door open a crack to allow moisture to escape
    Some kind of gym mat I would think would help (my knees aren't great, should have worn my knee pads more when working)
    Key-Rei[QUOTED] likes this.
  8. Mar 18, 2022 at 12:20 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I had the HVAC fan on (without A/C cool enough to not need it) and there's nearly an inch gap under the door pretty good "positive pressure" in there lots of flow out from under the door plus I won't be in there for a few days at least to do anything more.
    I wanted it to dry real slow as I put the last coat on pretty thick and didn't want it to peel.
    But I'll keep the door open if you think that's better.
    Pretty spooky in there with the lights off. :anonymous:
  9. Mar 18, 2022 at 12:22 PM
    Not a golfer
    Calgary, Alberta
    Spraying ceilings is not fun and hard on the neck
    Plus like you said APITA
    Most important thing cover everything when spraying
    Overspray and dust gets into places you wouldn't expect
    Key-Rei likes this.
  10. Mar 18, 2022 at 12:27 PM
    Not a golfer
    Calgary, Alberta
    Giving it a cracked door won't hurt
    I'm hiding under the bed writing this
    Cause it's really SPOOKY
  11. Mar 18, 2022 at 12:30 PM
    Toyko Joe
    Very spooky!
  12. Mar 18, 2022 at 12:33 PM
    Key-Rei
    Key
    Florida
    Bruh.
    I had the door closed cause I don't wanna walk past that black hole with the lights of on my way to the bedroom.
    I am a grown ass adult I swear.
  13. Mar 18, 2022 at 1:00 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Water stain is in her town house. Didn’t really look at the new house but it seems more like the orange peel then popcorn from pictures. We don’t have our final walk through for a couple of more weeks. I don’t think we will need to paint the ceilings in the new house. Does the orange peel texture hold up better than the popcorn? If not at some point I might just remove it all.
  14. Mar 18, 2022 at 1:20 PM
    jsi
    native earthling
    Orange peel is typically just thinned drywall mud splattered on the surface. Short of a leak is should last forever, and if you want to paint is no big deal.
  15. Mar 18, 2022 at 1:28 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Perfect. It’ll paint over a lot better than freaking popcorn
    Not a golfer likes this.
  16. Mar 18, 2022 at 1:43 PM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Have you thought about the rubber tiles that are designed for a garage floor? Not sure if they are the same as ones previously mentioned or not. I wonder if they would have enough cushion for a person (as opposed to a car.)
    I'm about to do some flooring in part of my basement, and have been considering these. I'd like to see what you end up with.
  17. Mar 18, 2022 at 2:17 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    https://www.rubberflooringinc.com/interlocking-tile/foam/soft-rubber.html
  18. Mar 18, 2022 at 2:37 PM
    Key-Rei
    Key
    Florida
    Yeah I've looked at the interlocking sections and home gym floor solution type stuff a bit, most seem to be more for absorbing drop weights shock rather than knee cushion and I suspect are too high a durometer my bigger worry with them is either corners peeling or drink spills getting between the cracks.
    A local flooring shop had a setup I'm considering of a closed cell neoprene foam 1/4" as underlayment then recommend a tight low nap carpet.
    For now just going to go with painted black floor and a fatigue mat in my VR area till I decide or find something I really like.
    Slashaar[QUOTED] likes this.
  19. Mar 18, 2022 at 3:47 PM
    Scott B.
    Scott
    Georgia
    I've been looking at these: https://www.rubberflooringinc.com/interlocking-tile/38-sport-lock-tiles.html
    They are kind of in between - not too hard.
  20. Mar 18, 2022 at 4:02 PM
    Slashaar
    Josh
    Kansas City, MO
    Those aren't for heavy weights, those are cushiony.
    Highlights
    • New and improved recycled rubber top surface and EVA foam backing.
    • Provides excellent cushioning and anti slip protection.
    • Detachable edge pieces allow each tile to be either a center, corner, or border tile.
    • Sound absorbent and shock resistant.
    • Not recommended for use in areas where heavy free weights and weight equipment will be used.
