Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 22, 2022 at 12:28 PM
    la0d0g
    running for the hills
    For crawling not hauling
    That's a nice way for a shitty situation to play out!
    Mad German[QUOTED] likes this.
  2. Mar 22, 2022 at 12:28 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Could be a GFI breaker too. If its a relatively new house you wont see the standard push button receps were used to seeing.
    916carl[QUOTED] likes this.
  3. Mar 22, 2022 at 12:29 PM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I believe a GFCI breaker on that/those circuits would satisfy the code requirements.
  4. Mar 22, 2022 at 12:32 PM
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    Required or not having garage plugs GFCI protected is wise.
  5. Mar 22, 2022 at 12:45 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    The whole house is on GFCI breakers. So basically everything in the house is on GFCI. And the breakers are pricy
    truchador and 916carl[QUOTED] like this.
  6. Mar 22, 2022 at 12:47 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I take them out of garage. The small time woodworking equipment i run kicks breakers
    308savage and TomTwo like this.
  7. Mar 22, 2022 at 3:24 PM
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    I'm still trying to figure out if a split phase 220v (240v) garage circuit requires a GFI of some sort. I've been told both yes and no.
    It will be two 20amp breakers (tied together so if 1 trips the other will as well), 12/3 run to the 20 amp recep. The power cord to the motor is 12/4 SJOOW, so it will have 2 legs of 110v each.
  8. Mar 22, 2022 at 3:39 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Well, since everybody is painting, I figured I better get started. Caulked everything yesterday so it had overnight to dry/cure. I couldn't find my normal oil based exterior primer so I tried something new...
    I actually really liked how it went down. Covered up and soaked into the treated 1x's really good!
    Course, for the topcoat I went with the old standby...
    One coat of primer and two coats paint later...
    Once I got some paint on the 1x's I realized how crappy the lumber is. A couple bottom 1x6 are twisted and the two 1x4 around the door shrunk pretty bad. I'll eventually replace them, but I have other pressing issues. Still deciding on color for the siding. Probably gonna get a color to match the shed.
  9. Mar 22, 2022 at 4:06 PM
    My Name is Rahl
    I'm sure they have more now...:boink:
    TomTwo[QUOTED] likes this.
  10. Mar 22, 2022 at 4:12 PM
    TomTwo
    Bill
    I-85 Southbound
    It sure bothers people more than it does me that’s fo sho o_O :rofl:
  11. Mar 22, 2022 at 4:14 PM
    My Name is Rahl
    Also, the face plate screws need to be vertical.
    wilcam47 and TomTwo[QUOTED] like this.
  12. Mar 22, 2022 at 4:27 PM
    TomTwo
    Bill
    I-85 Southbound
    Your killing me :thumbsup:. We could be real good friends
  13. Mar 22, 2022 at 4:28 PM
    My Name is Rahl
    :rofl: Just messin!
  14. Mar 22, 2022 at 4:47 PM
    wilcam47
    Will
    Bourbon state
    see above...:rofl::yes::fistbump:
  15. Mar 22, 2022 at 4:54 PM
    TomTwo
    Bill
    I-85 Southbound
    I actually told the electrician when they were wiring my house that all the faceplate screws needed to be vertical
  16. Mar 22, 2022 at 5:00 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    It's amazing how split finish guys are on this. Me. Always mitering. My boss. Always coping. I've done both but find mitering faster and just as good if your saw is accurate. It's a far away shot but this is a kitchen I installed last week. 5" 52 degree spring angle stain grade crown. Let's just say the painter won't be needing any putty. lol
  17. Mar 22, 2022 at 7:55 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Looks great! I do miter angles less than 90.
  18. Mar 23, 2022 at 4:19 AM
    DirtyTerp
    DirtyTerp Well-Known Member
    Randy
    Freeland, MD
    '14 DCSB MGM
    Knotty alder cabinets?
  19. Mar 23, 2022 at 4:31 AM
    4x4spiegel
    4x4spiegel Well-Known Member
    looks great! are those manufactored cabinets (who) or stick built ?
  20. Mar 23, 2022 at 6:31 AM
    theesotericone
    Bishop CA
    Hickory. They do look a lot like alder though.
    KraftMaid, aka Home Depot. Not the greatest as far as hardware but not the worse.
    DirtyTerp[QUOTED] and Sig45 like this.
