Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 24, 2022 at 9:20 AM
    Toyko Joe
    Toyko Joe Here for the pictures
  2. Mar 24, 2022 at 9:22 AM
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    We have this in common. The older craftsmen that taught me were the same, hated it at the time (young buck) but now I'm thankful for their willingness to teach me (old as dirt now). DO IT ONCE, DO IT RIGHT! And yes good reputation keeps you working (I don't advertise all word of mouth)
  3. Mar 24, 2022 at 10:26 AM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    The homeowner was unsure of what stone work they're going to use. They are also unsure of how big of an overhang they actually want on the countertop and the countertop material for that matter. With those facts we agreed to leave it as is until I have the info I need.
    But basically they'll be a small pony wall built up under there with 1/2-in hardy backer on both sides.
    Drainbung and Toyko Joe[QUOTED] like this.
  4. Mar 24, 2022 at 10:54 AM
    My Name is Rahl
    based on the lightest color the steel is there, it got up to 590-600ºF at one point.
    Slashaar and wilcam47 like this.
  5. Mar 24, 2022 at 11:06 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Delta09, Slashaar and Drainbung like this.
  6. Mar 24, 2022 at 2:48 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    It'll keep your tootsies warm when you sit at the bar.
    truchador and wilcam47 like this.
  7. Mar 27, 2022 at 6:41 AM
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    FINALLY done. came out great IMO.
    I started nailing planks on then realized it would be better to stain the base plywood so you wouldnt see the gaps as easy. adjusted the board and played a game. im very happy with it.
    I MAY add trim around the boarder but other than that im done
  8. Mar 27, 2022 at 6:57 AM
    wilcam47
    Will
    Bourbon state
    Looks nice!
  9. Mar 27, 2022 at 7:07 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Looks great! :cheers:
    I considered using different colors of stain for my theater room but opted for just one.
  10. Mar 27, 2022 at 4:53 PM
    jjones.yota
    jjones.yota Well-Known Member
    Jack
    Hi thread I have a couple of questions.
    I’m redoing my master suite, with all new bathroom and closet and all.
    one question, is there an insulation you’d recommend for soundproofing that isn’t too much more expensive than standard fiberglass? Older home so it’s not very sound proof but I’d like to help that out when I can.
    next question a bit more in depth. When I’m doing the new shower I want to do at least 2 shower heads, perhaps 3. One will be a rainfall. Are there any tips or tricks I need to know to make sure if multiple heads are running I’m not gonna lose pressure at the other? And any plumbing don’t do’s when doing multiple heads?
    thanks in advance.
  11. Mar 27, 2022 at 4:58 PM
    Virginian
    Virginian Well-Known Member
    Raleigh, NC
    2017 Tacoma Double Cab TRD Off Road
    I've used this before and it reduces sound very well.rockwool-mineral-wool-insulation-rxss31525-64_400.jpg
    truchador, jjones.yota and wilcam47 like this.
  12. Mar 27, 2022 at 4:58 PM
    jjones.yota
    Jack
    Good to know. Does it go up like standard insulation?
  13. Mar 27, 2022 at 5:02 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Yes, rockwool is what is recommended for sound insulation. And it goes up just like normal pink stuff.
    jjones.yota[QUOTED] likes this.
  14. Mar 27, 2022 at 5:02 PM
    Virginian
    Raleigh, NC
    Yes, but even easier in my opinion. While your wife isn't looking, steal the big bread knife out of the kitchen to use to cut it!
    la0d0g, jjones.yota and wilcam47 like this.
  15. Mar 27, 2022 at 5:23 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    Rockwool is kind of the standard sound proofing insulation for home theater rooms so it should serve you well.
    Disclaimer - I'm not a plumber.
    My shower has a wand shower head and also a fixed head that surrounds the wand. There are also two body jets. When all of them are running, there is absolutely a drop in pressure. Short of plumbing them individually and having to deal with multiple mixing valves, I don't know how you'd avoid that. I hope you find a solution.
  16. Mar 27, 2022 at 5:29 PM
    jjones.yota
    Jack
    Yeah we’ve had one before like that and lost pressure. That was in a different house that a flush of the toilet would affect the shower too haha. This house we haven’t noticed that kind of stuff happen but I don’t know why not. It is a much larger house so maybe they do things differently but idk.
    I just know when the wife and I shower together I’m gonna want a rain shower head on as well as one wall head but if that wall head has no pressure that will be no bueno.
    Fargo Taco[QUOTED] likes this.
  17. Mar 27, 2022 at 5:41 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    Do you have a sketch of how you want the shower laid out? It's sounding like it might be easier to run two dedicated setups so when you shower together everything would work independently.
    wilcam47 likes this.
  18. Mar 27, 2022 at 5:53 PM
    jjones.yota
    Jack
    No sketch, could put one together. But draw a rectangle with one wall shower head on both narrower sides, and a rain head right in the top middle.
    like i said could go with one wall shower head and the rain head too. Just depends.
  19. Mar 27, 2022 at 5:53 PM
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    Last remodel I worked on, the owners wanted similar set up. Everything was dedicated and plumbed to maintain pressure. Problem the owners didn’t foresee was that their current water heating system couldn’t keep up with the flow. We ended up upgrading to a new system to accommodate their love of long showers. All that to say, make sure you have enough hot water to support multiple heads.
  20. Mar 27, 2022 at 5:55 PM
    jjones.yota
    Jack
    Definitely good on hot water. House has 3 water heaters and a solar system for 300 gallons of preheated hot water. Solar system isn’t currently operable but my wife takes long ass showers now and we don’t run out of hot water.
