Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Apr 18, 2022 at 4:30 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    I’ve never had an inspector require 4’ of copper pipe. What code is that?
    6 gearT444E and wilcam47 like this.
  2. Apr 18, 2022 at 4:43 PM
    E-Paz 732NJ
    E-Paz 732NJ Well-Known Member
    Eric
    NJ
    2015 Tacoma TRD-OR
  3. Apr 18, 2022 at 4:56 PM
    TwistedTLM4
    TwistedTLM4 Unknown Member
    Philadelphia, PA
    '05 DCSB TRD Sport
    WeatherTech Floor Mats, WeatherTech Bug Shield and Vent Visors, Audio Upgrade, RaamAudio RaamMat & Ensolite, Mr. Marv's Custom 10" Sub Enclosure, Pop N Lock Electronic Tailgate Lock, mattgecko's Bedlights, Demello Offroad Single Hoop Bumper, Marathon Seat Covers, Leer Topper, OME885s on 5100s, @Blackout14 HD Leaf Pack
    Philadelphia Plumbing Code:
    P-503.3 Materials
    All water heaters and water heating equipment shall have a minimum of 4 feet (1219 mm) of developed length of copper tubing or similar metallic piping material connecting directly to the inlet and outlet of the unit.
    Uniform Plumbing Code also requires 18":
    604.11.2 Water Heater Connections. PEX shall not be installed within the first 18 inches (457 mm) of piping connected to a water heater.
  4. Apr 18, 2022 at 5:24 PM
    Toyko Joe
    I understand the UPC 604.11.2. It’s the Philly code that seems odd. What happened in Philly that made the code be 4’ exceeding the UPC?
    TwistedTLM4[QUOTED] and wilcam47 like this.
  5. Apr 18, 2022 at 5:31 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Bread absolutely works. They also make Jet Swets that work better. If your a DIY plumber I wouldn't expect you to pony up for the Jet Swets. They are awesome though.
    Pro TIp: If you use bread be prepared to clean all the faucet screens upstream of that repair. Other then that make sure it's fresh squishy bread and your golden.
    tacofish, Slashaar, Drainbung and 3 others like this.
  6. Apr 18, 2022 at 5:34 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Crap, now you got me thinking to get some 18" copper connectors and cutting that bottom section out. I should be good for a week till I can get to it...
  7. Apr 18, 2022 at 5:38 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    $255 for a set, wowzers!
    Might have to try the bread trick next time. There's gonna be more plumbing on this house for sure!
  8. Apr 18, 2022 at 5:38 PM
    Toyko Joe
    TwistedTLM4 and Delta09[QUOTED] like this.
  9. Apr 18, 2022 at 5:54 PM
    TwistedTLM4
    Philadelphia, PA
    '05 DCSB TRD Sport
    Not sure what caused the change. I believe it was 3 feet last edition of the code.
  10. Apr 18, 2022 at 5:57 PM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Might want to put a disconnect for the power while securing it unless the circuit breaker is within eyesight
    Midwest U065P Disconnect Switch, A/C, Pull Out, 60A, 1P, 240VAC, Metal, NEMA 3R https://smile.amazon.com/dp/B000B83Z1M
    Sealproof Power Whip Assembly, 1/2-Inch x 6 Ft Nonmetallic Liquid Tight Flexible Electrical Conduit and 10 Gauge Wire Single Phase Preassembled A/C Hook-up Whip Kit, 1/2" https://smile.amazon.com/dp/B0756N989G
  11. Apr 18, 2022 at 5:59 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Very good thinking! I'm fortunate that my WH is about 15 feet from the panel. :thumbsup:
  12. Apr 18, 2022 at 8:36 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    We had our saddle valve removed and a nice valve put in its place for our fridge line. Before you could never truly turn it off, and at full open it was a trickle. Now the new fridge has plenty of clean water.
  13. Apr 18, 2022 at 8:55 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    looks good. Go with uponor pex if you want to keep standard size pipe and reduce pressure loss. Not a huge fan of the crimp fittings, either the copper/SS rings or uponor expansion fittings. I don’t buy the 4’ of copper, smells like some building inspector got picky, 18” is even overkill. I like to leave a small stub out of copper so you have a handle to carry the old one out when it breaks lol.
    truchador and Delta09[QUOTED] like this.
  14. Apr 18, 2022 at 9:00 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Inspector only looked at outside. Signed off and left.
  15. Apr 18, 2022 at 10:19 PM
    MGMDesertTaco
    Look into a solar roof mounted attic fan. I one installed about a year ago and it made a world of difference pulling hot air out of the attic and keeping the house a bit cooler during the hot AZ summers. :bananadead:
    Drainbung and wilcam47 like this.
  16. Apr 19, 2022 at 7:39 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    I gave up.
    Trying to run a 12/2 cable through a 6X6 POST into a hollow blind corner, make the corner, then through a 2x6 stud..........holes drilled which was a complete bitch. 3 drills (including my 90° DeWalt, which did fine........but with a 30" bit got a little vigorous and drilled out..........through the siding! Shit.
    Fished and fished. Tapes. Strings. Wires.
    I gave up.
    Then I looked upto the heavens - my path was clear. I can go up and over the beam pocket! I will just add an outlet in the corner. I have a brand new old box of 100ft 12/2.
    Thank you Jesus. I am sorry about swearing to you. I needed to add a couple circuits anyway.
    Need QP breakers and few odds and ends.........headed out
    truchador, Delta09, Drainbung and 3 others like this.
  17. Apr 19, 2022 at 8:05 AM
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    the ones with the floodlights? no i didnt. not really needed, i dont have a large area of land and dont want to blind the neighbors lol
  18. Apr 19, 2022 at 8:26 AM
    My Name is Rahl
    Yeah, I have been wanting some input on the ones with floodlights. I want to put one on the front of my garage, but don't want to spend the money if it's pretty well useless.
  19. Apr 19, 2022 at 8:36 AM
    Toyko Joe
    @Not a golfer
    I scrubbed all the walls with TSP, and triple washed and scraped any loose pain. After using Zinsser Oil-based primer, the paint is now easily pealing off the walls, where it was not before. I have not had this happen in the past when using these products, could it be that the brick wall was holding some moisture that caused a 'freeing' of the primer and existing paint after the Zinsser was applied?
    I am at a loss and now have to re-do a bunch of work where I though I was done. :frusty:
  20. Apr 19, 2022 at 9:01 AM
    My Name is Rahl
    I had that happen when I went to repaint the house we just bought. I too am interested in an explanation.
