Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Apr 24, 2022 at 7:17 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Thanks for all the details! Appreciate the insight.
  2. Apr 24, 2022 at 8:31 AM
    Denk
    Denk Well-Known Member
    PNW
    '13 Spruce TRD Sport DCSB
    Underlayment? What's that? My tile roof is just tile on battens. Freaked me out when we bought the house.
    wilcam47 likes this.
  3. Apr 24, 2022 at 9:45 AM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    Underlayment is something to protect from element from rain, snow, etc.. which is sitting between plywood and shingles/tiles.
    Just like this: (When you build new house)
    Place truss on top of house
    Place plywood on roof
    Place underlayment on plywood starting from bottom to top.
    Place shingles/tiles starting from bottom to top.
    If you have chimney, then check for flash to make sure no damage or leak for old houses If new house, then new flash around the chimney.
    Same flash method for skylights if available on roof.
    Done... You have nice roof up there.
    Underlayment can be done for flooring as well if you plan to have hardwood flooring. For carpet, underlayment (or pad depends how soft you want.)
    theesotericone likes this.
  4. Apr 24, 2022 at 10:16 AM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Trusses? I swear sometimes I think I'm the last guy left that knows how to cut and stack a roof. lol
    TAZMINATOR[QUOTED] likes this.
  5. Apr 24, 2022 at 10:46 AM
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    You're not
    Around here people don't know what trusses are
    95% of new houses are hand framed
  6. Apr 24, 2022 at 11:50 AM
    TAZMINATOR
    2017 Tacoma
    I used to work for a company when I was younger. We built trusses and placed them on semi trailers (flat bed) so the drivers deliver them to the new home sites.
    Some say trusses, some say rafters.
    I know what you meant.... some people do frame them by hand and some houses have already made and put on there by crane.
    Around here, trusses are usually being delivered to new home sites and they use crane.
    Depends on builder office that they decide to use trusses or have builders/framers build trusses by hand.
  7. Apr 24, 2022 at 1:31 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Quick little project today. Finally moved the dryer beside the washer. Put the receptacle in a metal handybox that looks better IMO. Still need to move the cistern pressure tank over a little bit, but it all still works for now. Also seem to have misplaced my clamps to better secure the wire. I'll get some of those tomorrow.
    Before:
    After:
  8. Apr 24, 2022 at 2:19 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    more sheet rock for the basement. Im not a sheet rock guy so low expectations is the key.
  9. Apr 24, 2022 at 5:00 PM
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    That is great looking! We had someone install chain link. He did it for appx $500 more than I could, and it was done when we got home from a trip. I added 5 & 6 foot wooden fence on the other side after we had our barn done.
  10. Apr 24, 2022 at 6:04 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    My washer and dryer are plugged into the same outlet in the laundry room. Twice now while both are running, they tripped the 20A breaker. There's nothing else on the circuit and the plugs are seated all the way in. Is there anything else I should check before calling in an electrician?
  11. Apr 24, 2022 at 6:09 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Prob pulling too much amps. Is there only one plug in there? Ours has 2 one for washer and one for dryer.
    la0d0g and Kremtok[QUOTED] like this.
  12. Apr 24, 2022 at 6:10 PM
    My Name is Rahl
    This is what my A/C looked like an hour ago. Anyone in here know how this happens and how to keep it from happening again?
    Obviously, I shut off the A/C immediately so it could thaw out.
    Slashaar likes this.
  13. Apr 24, 2022 at 6:16 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    @Sperrunner
  14. Apr 24, 2022 at 6:18 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Low on Freon and or dirty filter would be my guess
  15. Apr 24, 2022 at 6:28 PM
    My Name is Rahl
    I change the filter once a month on the first of the month.
    I don't know when the last time it was serviced, and it's an '02 model
  16. Apr 24, 2022 at 6:30 PM
    IPNPULZ
    going to be fun!
    Bad evaporator fan motor could be an issue as well….
  17. Apr 24, 2022 at 6:39 PM
    My Name is Rahl
    Is that the one outside?
  18. Apr 24, 2022 at 6:42 PM
    IPNPULZ
    going to be fun!
    Inside the outdoor one is the condenser
  19. Apr 24, 2022 at 6:43 PM
    My Name is Rahl
    Oh, no. The squirrel cage fan is working fine.
  20. Apr 24, 2022 at 6:45 PM
    IPNPULZ
    going to be fun!
    Okay that’s a plus I say it’s low on Freon
