Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. May 15, 2022 at 1:06 PM
    MGMDesertTaco
    Looks like Sikaflex self leveling sealant. I need to do the end of my driveway.
  2. May 15, 2022 at 1:17 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Installed the garage door opener today!
    What a frustrating mess! Install was somewhat frustrating, but the open/close programming was ridiculous! As I was about to give up I pressed the button again and it started working as intended. :notsure:
    Also decided to put in the lights. Grabbed a new 250 roll of 14/2 and slid my fatass into the attic...
    Yes, I used cut in boxes. It was the easiest way for me to do it. Didn't feel like fooling with cutting lumber and setting metal boxes...
  3. May 15, 2022 at 1:36 PM
    Cozza
    Cozza Hi
    Corey
    Denver area, CO
    GX
    Looks great! What lights are those?
    Pablo8 and Delta09[QUOTED] like this.
  4. May 15, 2022 at 1:41 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Just some inexpensive LED units from Lowe's (P/N 1479187). They come in a 2 pack for about $25. Gives a little bit of modern flare to the old house. Doesn't throw off a massive amount of light, but the one at the side door has been plenty to see going in the door.
  5. May 15, 2022 at 2:22 PM
    Cozza
    Cozza Hi
    Corey
    Denver area, CO
    GX
    Exactly what I've been after!!
    Delta09[QUOTED] and wilcam47 like this.
  6. May 15, 2022 at 3:37 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    AD073DDD-296D-437B-8F30-378A0687D2E5.jpg 608D623C-7FEC-46C7-A6F5-62C46BD6F2F5.jpg
  7. May 15, 2022 at 4:14 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    What is this access box in series with your downspout plumbing? Only guesses are a K&N cold-intake filter or a mailbox that has complimentary water flow. Never seen such a thing...?
    907rx7, Pablo8 and Delta09[QUOTED] like this.
  8. May 15, 2022 at 4:16 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    It has a piece of screen in it to "filter" water going into the cistern. I have not only a well, but a cistern to feed the outside spigots. Water from all the the gutters goes in the cistern. If it gets full I can direct flow outside.
  9. May 16, 2022 at 5:04 AM
    JEP
    JEP Resident Lurker
    Madison
    15 DBL V6 4WD
    N-fabs, BakFlip VP, power tailgate lock, bed lights, "raptor" grill lights. Standard mall crawler stuff.
    Does that opener force the door closed to squish the bottom seal? I've been looking at that type of opener but questioned if it had down pressure. My concrete is not flat and I use the opener to apply pressure so the seal contacts the whole width of the door.
    Delta09[QUOTED] likes this.
  10. May 16, 2022 at 5:28 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Like any garage door opener you can set/adjust the limits
    Delta09 likes this.
  11. May 16, 2022 at 5:43 AM
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    Is that the motor on the right? Does that take away the need for the traditional bar that runs down the center of the ceiling? Just curious because I want more garage overhead room and that bar is getting in my way! lol
  12. May 16, 2022 at 5:49 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yea, it has enough for to compress the seal. My garage concrete is also not level. There's still one spot that daylight shines through, but that was like that before. I got to get a bigger seal.
    Yup, it attaches to the torsion spring rod rather the middle of the door. If you have the traditional two springs on the side it won't work. I have no overhead clearance so it was my only choice, albeit an expensive one...
  13. May 16, 2022 at 6:19 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Cool. Thanks. I used a DAP product that was supposed to be Gray. Straight up white. Ugg.
    308savage[QUOTED] likes this.
  14. May 16, 2022 at 6:28 AM
    308savage
    Adam
    East Tennessee
    I think I have used that before, but this flows so much easier. And looks better.
    shakerhood and Pablo8[QUOTED] like this.
  15. May 16, 2022 at 6:43 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Luckily it was between a post and a walkway and it sunk in.......I will dig and rough it up a bit and fill level with that when the weather warms and dries out. Thanks
  16. May 16, 2022 at 9:18 AM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    That machine is almost bigger than my backyard!
    wilcam47 and Blue92[QUOTED] like this.
  17. May 16, 2022 at 9:19 AM
    ScrippsRanch67
    Bob
    Fiberglass shell
    That's somewhere on my "to do" list. Looks good!
  18. May 16, 2022 at 9:21 AM
    ScrippsRanch67
    Bob
    Fiberglass shell
    What material did you use for filling in the gap?
  19. May 16, 2022 at 9:23 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Yeah its been on the want list since I closed on the house last year. Yard is too big to push mow, almost feels too small now that Ive got this thing haha.
  20. May 16, 2022 at 11:02 AM
    308savage
    Adam
    East Tennessee
