Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Aug 21, 2014 at 11:16 AM
    #2741
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    Great job on those skirt boards. I know how much skill it takes to pull that off.. I definitely couldn't do that!
  2. Aug 21, 2014 at 12:15 PM
    #2742
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Thanks for the kind words
    #4 fitted
  3. Aug 21, 2014 at 4:30 PM
    #2743
    OZ-T
    Peter North
    British Columbia
    Next up ;
    Make and install the 2 element curved baseboard
  4. Aug 21, 2014 at 4:49 PM
    #2744
    OZ-T
    Peter North
    British Columbia
    I was cursing myself today for not making the baseboard trims when I bent the window trims
  5. Aug 21, 2014 at 5:18 PM
    #2745
    OZ-T
    Peter North
    British Columbia
    No steaming
  6. Aug 21, 2014 at 6:44 PM
    #2746
    OZ-T
    Peter North
    British Columbia
    Yes , laminations
  7. Aug 22, 2014 at 7:54 AM
    #2747
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    I know that feeling installed a "antique" window customer found had to build casing a trim for it later.
  8. Aug 22, 2014 at 8:03 AM
    #2748
    joshua721
    16 f150 xlt v6
    Customer was trimming everything. We were finishing up for an event in 2 weeks. Comes to me and asks me to trim the kitchen windows so the can use and show it the next day... It was 4pm on a Friday... Who puts fluted trim in a commercial kitchen...
  9. Aug 22, 2014 at 10:25 AM
    #2749
    OZ-T
    Peter North
    British Columbia
    Nice work
  10. Aug 22, 2014 at 10:25 AM
    #2750
    OZ-T
    Peter North
    British Columbia
    Yesterday's effort didn't pan out as well as I had hoped due to limited backing in the wall meaning my clamps were too far apart to close up the laminations , so this is version 2.0 with more clamping effort
  11. Aug 22, 2014 at 10:34 AM
    #2751
    joshua721
    16 f150 xlt v6
    If that doesn't get pressure where you need it you could hot glue blocks to the tile for support.
  12. Aug 22, 2014 at 10:38 AM
    #2752
    OZ-T
    Peter North
    British Columbia
    I think this is going to do the trick , I got good glue squeeze out along all the seams and the laminations are tight to each other and the wall
  13. Aug 22, 2014 at 11:33 AM
    #2753
    Lespaulkid01
    Lespaulkid01 I prefer the term "beer researcher".
    MoCo, Maryland
    2013 Double Cab TRD Sport, Pyrite Mica
    tool chest, vent visors, tuffy bed box, scangauge, Bilstein 5100's, OME 885x springs, Wheeler's HD AAL, LED map, dome, and reverse lights, Bestop Supertop.
    That should work pretty well. It's the same thing as a go-bar deck.. bracing is typically glued to the top and back of a guitar body the same way, and they're under constant 120-200 pounds of pressure from the strings.
  14. Aug 22, 2014 at 12:35 PM
    #2754
    joshua721
    16 f150 xlt v6
    Is that your set up? How does that compare to a vacuum press set up?
    Also all the talk of nail guns and compressors the other day anyone want a nailgun 101?
  15. Aug 22, 2014 at 12:42 PM
    #2755
    OZ-T
    Peter North
    British Columbia
    Yes , lets discuss nailers
  16. Aug 22, 2014 at 12:52 PM
    #2756
    medic2230
    Murph
    Bama! Roll Tide
    X2
  17. Aug 22, 2014 at 1:01 PM
    #2757
    Lespaulkid01
    MoCo, Maryland
    Not mine, just a photo I got offline. A friend (who is an actual luthier) has a similar set up though, just he uses strips of pine instead of fiberglass bars. For this application though, I think either way works. Vacuum presses are nice but super expensive so you don't see them much unless its a large company or a luthier with a high profit margin or so. Go-bar decks are much cheaper (most of the ones I know of are home made for pretty cheap) and do the same quality work IMO.
  18. Aug 22, 2014 at 1:32 PM
    #2758
    joshua721
    16 f150 xlt v6
    Not nailers but how to use them and get the most out of them.
    Some of you may have learned that you can eliminate almost 99% of fish hooking of the nails just by how you hold the gun in relation to what you are nailing. Trim nails are not round or pointed. The ends are cut like a wedge. This wedge will take the easy path if it hits an imperfection or an area of higher density. So knowing how the nails are shaped allows you to insure that if it does hook it won't blow out the side. If you hold the nailer parallel to your work piece and nail the edge you are setting the wedge up to go through the side of your work. If you hold it perpendicular the nail can hook and stay inside of the work.
  19. Aug 22, 2014 at 1:39 PM
    #2759
    medic2230
    Murph
    Bama! Roll Tide
    Good thing to know. I just read an article in Fine Homebuilding about the new 18ga brad nailers that can shoot up to a 2 1/8" nails. A good deal has changed since my last purchase. I believe mine will shoot up to 1 5/8" (Bostich).
  20. Aug 22, 2014 at 1:46 PM
    #2760
    joshua721
    16 f150 xlt v6
    The wedge on the nails
    Blowout couldn't make one hook in the oak
    Improper method
    Correct
