Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jun 4, 2022 at 5:45 AM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    The first step off the doorway on the landing has to be 7", by code. I have to figure out what to use under the door, and length of the porch. If snow sits there for awhile.
    The frost guard is it the same as roofing ice membrane?
    truchador[QUOTED] likes this.
  2. Jun 4, 2022 at 5:53 AM
    My Name is Rahl
    That works. I assume from the pictures this is a smaller porch like 4'x4'?
    Eh...not sure about that.
    truchador and Venom[QUOTED] like this.
  3. Jun 4, 2022 at 6:02 AM
    Venom
    Kevin
    Massachusetts
    The length is 7ft and the depth is about 4ft. With 3 steps.
    The 1st masonry contractor told me since it's a step it's has to be 7"
    If it's true I don't know, but if it snows it will take 7" before it hit the door opening.
    The old porch has 7 1/2" height stairs and from the landing to the door is 8" before sagging. Going by the vinyl cut out.
  4. Jun 4, 2022 at 6:05 AM
    Venom
    Kevin
    Massachusetts
    If it's clog, how would you clean it out?
    Would you use a pressure washer, or plumbing snake?
    wilcam47 likes this.
  5. Jun 4, 2022 at 6:08 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    My plan all along was to take it apart in a couple minutes and clean it manually. Caulk joints that I can, etc.
    My question was not specific enough.
    IS there an alternative to shitty bellows/flex? (I bet that has holes too)
  6. Jun 4, 2022 at 6:10 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    I had one house like that. Stupid terrible practice - dunno about code. I had to re-engineer and redo. PITA
    Venom[QUOTED] likes this.
  7. Jun 4, 2022 at 6:12 AM
    My Name is Rahl
    Ah, that makes more sense.
    Normal downspout elbows won't work?
    Venom[QUOTED] and wilcam47 like this.
  8. Jun 4, 2022 at 6:13 AM
    Venom
    Kevin
    Massachusetts
    If the clog isn't in reach, then how would you clean it?
    My friend had a clog pipe, couldn't figure it out. We then decided to dig it up. There was a tree root growing through the pipe.
  9. Jun 4, 2022 at 6:14 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    I am going to find out. MAYBE.
  10. Jun 4, 2022 at 6:15 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Need to find the "root" cause first..........hose works for gutter drains, most of the time............
  11. Jun 4, 2022 at 6:18 AM
    Venom
    Kevin
    Massachusetts
    The 2nd masonry contractor says it in good shape. He wants to brace back into place. I don't think this is a good idea. There no concrete slab under the porch. The ground is not stable. I think it will be a nightmare to lift back into position.
  12. Jun 4, 2022 at 6:21 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Some might use that spray foam they inject to lift side walks and such
  13. Jun 4, 2022 at 6:27 AM
    Venom
    Kevin
    Massachusetts
    We had no idea how the root of that size got there considering there no trees around. If it was a tree there before the house was built over 100 years ago, it amazes him how the root was still in good shape, all these years.
    Pablo8[QUOTED] and wilcam47 like this.
  14. Jun 4, 2022 at 6:30 AM
    Venom
    Kevin
    Massachusetts
    He did mentioned something about foam. I just didn't know how it works.
    Someone mention a bobcat to lift and push back.
    Without lifting the whole porch, How can it be brace from underneath?
    wilcam47[QUOTED] likes this.
  15. Jun 4, 2022 at 6:32 AM
    wilcam47
    Will
    Bourbon state
    They drill holes in the concrete and calculate how much they need to lift it. Not sure on the longevity of it. But its becoming more common
  16. Jun 4, 2022 at 6:34 AM
    SRH
    SRH My horns hold up my halo
    Shauna
    2018 Sport
    We doweled into the concrete foundation with rebar. The rebar stuck out at the mortar level, then poured concrete into the cores. Again, I’m in Illinois.
  17. Jun 4, 2022 at 6:37 AM
    Venom
    Kevin
    Massachusetts
    I used to see the guy down the street use a hydraulic car jack to jack his porch, then brace it. He has to jack the porch every coupe of years. Then he got sick of jacking the porch up, and jackhammer the porch and installed a wood porch. A decision he never look back on. Beside clearing the snow off.
  18. Jun 4, 2022 at 6:41 AM
    Venom
    Kevin
    Massachusetts
    The 2nd contractor suggest drilling the foundation, install Rebar then pour the concrete pad. He also suggest a pre-cast porch. I figure the cinder block porch will be lighter, and less weight to prevent shifting.
  19. Jun 4, 2022 at 6:43 AM
    wilcam47
    Will
    Bourbon state
    Sometimes easier to rip it all out and start over
    truchador, Pablo8 and Venom[QUOTED] like this.
  20. Jun 4, 2022 at 6:49 AM
    My Name is Rahl
    If weight because of soft substrate is your main concern, why not fix the rot issue on your house and put a wood deck back instead of concrete?
