Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jun 9, 2022 at 2:41 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Doest look difficult...
    Slashaar[QUOTED] likes this.
  2. Jun 9, 2022 at 2:46 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    But I'm also king of thinking something looks easy and it turning into 4 times longer job than it should've been.
    wilcam47[QUOTED] likes this.
  3. Jun 9, 2022 at 3:07 PM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    I have mostly the old Adams to. I still have the original VRT, Eco wheel cleaner, All purpose cleaner, Car wash soap.
    I have a few of P&S Detail products, Brake Buster, express interior cleaner, Bead Maker.
    Others brands I have are Meguiars, Nextzett, Sonax, GTechniq,
    I still like Optimum car wash soap for the smell.
  4. Jun 9, 2022 at 3:17 PM
    Venom
    Kevin
    Massachusetts
    With the pool PH strip I hot 8.5. I don't know what it is today. Probably not any better.
    I can't see buying all the water softeners for this area. My friend had to replace his water filter every 2 to 3 weeks. The filter was white new, after a week it was brown. Pretty nasty. I had to use a oil filter wrench to remove the filter housing.
    I had to help once. It was awkward, heavy to line up everything. I went to the garage, got the car hand jack and crank it up in place. It was so much easier. I was soaked wet when I did the wiring.
  5. Jun 9, 2022 at 3:49 PM
    MGMDesertTaco
    Was there a lot of iron or sediment in the water? City or well water? What did the setup consist of? A single wall mounted filter isn't going to do much. My PH and total dissolved solids vary month to month depending on how bad the city water is.
    Do you follow Matt from Obsessed Garage? I've been watching his YouTube channel and enjoying his house hunting adventures in North Georgia. He's does a ton of product testing on auto and home stuff.
    R.O. faucet on the right for reference. I wish my refrigerator wasn't on the other wall. I could plumb the R.O. to the ice maker. :facepalm:
    dumontrider and la0d0g[QUOTED] like this.
  6. Jun 9, 2022 at 4:06 PM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Like a 2 out of 10 to hang it, 3 out of 10 to do it right and 4 out of 10 to do it right and fast lol
    unless you’re afraid of heights
    a good set of scaffolding makes a big difference as far as speed is concerned
    watch some YouTube :)
  7. Jun 9, 2022 at 4:08 PM
    Slashaar
    Josh
    Kansas City, MO
    Soffits too? I need to replace my eave boards too, should I get that tackled before having the gutters installed?
  8. Jun 9, 2022 at 4:11 PM
    Venom
    Kevin
    Massachusetts
    I don't know about iron. Washing cars the water will leave calcium deposit. White spots everywhere that etch.
    Years ago the city sent out a letter, don't drink the water until further notice.
    My friend's house, the city water lines was rotted out. Pure rusty water.
    After complaining, and the neighbor getting lawyers, the city replace the water lines.
    I don't follow but sometime watch his videos. I seen the video where he tested car wash shampoos, PH levels.
  9. Jun 9, 2022 at 4:13 PM
    truchador
    Otto
    WV
    15 DC OR
    Gutters are last lol, especially if you have to replace the boards (fascia) they are screwed to
    vinyl soffit material is easy to install. Read up on f-channel and j channel. Usually there is a metal fascia cover/shroud that sits between the gutter and fascia/eve board and catches and covers the outside cut edge of the soffit pieces
  10. Jun 9, 2022 at 5:02 PM
    MGMDesertTaco
    Sounds like a few different issues. If all of the defective pipes have been replaced a proper filtration system should clean up whatever remains. The previous owners of this place never utilized a softener or whole house filter despite having the closed loop plumbed and it took a long while before the pipes stopped flushing sediment out and destroying valves.
    A deionized water rinse system will absorb all the calcium and magnesium for car washing, but with the water quality you're describing a large sediment and whole house filter plumbed before the DI rinse would be needed to prolong the life of the DI resin. Otherwise that resin will wear out quick.
    Ironically I've joked about a class action suit against the city water department for all the damage they've caused. Even consulted with an attorney who said "I wasn't the first to raise the issue," but also said "it would be very difficult to prove and get them to pay out." :rolleyes:
    Heck, the city's 3 years behind on paving our street, yet they keep raising property taxes. :angrygirl:
    Venom[QUOTED] likes this.
  11. Jun 9, 2022 at 5:15 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Well window went it today after 8 months of waiting
  12. Jun 9, 2022 at 5:17 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    5 guys should be able to handle that haha
  13. Jun 9, 2022 at 5:19 PM
    IPNPULZ
    going to be fun!
    Lol…. I’m trying to finger out if their going to not shim up the bottom again……
    Toyko Joe likes this.
  14. Jun 9, 2022 at 5:28 PM
    Venom
    Kevin
    Massachusetts
    After the pipes were replace it took about 6 months for the repairs and rust to flush out. Now the water is clear.
    This is the filter type my friend uses.
    It's not much but it helps with the rust at that time. At the rate these filter was getting replace these fit the bill.
    The water pressure sucks. Most people can urinate with more pressure.
    I read, to filter the whole is going to be expensive from constantly replacing the resin, cartridge, etc. I have to choose what is more important to be filtered. Eventually I going to have the water tested before any filtration system is installed.
    Due to how bad the water is the neighborhood elders were getting sick. Testing done prove it was from the water.
  15. Jun 9, 2022 at 5:31 PM
    Venom
    Kevin
    Massachusetts
    Five guys plus one holding the camera :D
  16. Jun 9, 2022 at 5:31 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    LMAO. I was just about to post the same thing. What you think. 4'0" x 5'0"? I'm basing that off 8 foot ceilings so I could be off. lol
  17. Jun 9, 2022 at 5:41 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    One Hardhat, one straw hat, one ballcap...
  18. Jun 9, 2022 at 5:43 PM
    Venom
    Kevin
    Massachusetts
    One holding the nail, while one hitting it. o_O
    Drainbung[QUOTED] likes this.
  19. Jun 9, 2022 at 5:44 PM
    theesotericone
    Bishop CA
    Holy shit, I didn't even notice the hard hat. The best part is he's inside. Here's a pro-tip. Windows can't fall inward unless you REALLY fucked up the rough opening. lol
  20. Jun 9, 2022 at 5:58 PM
    MGMDesertTaco
    What you're using won't remove much other than sediment. You need Carbon/KDF for cleaning/purification.
    You could do a couple inline sediment filters like what you're using plumbed before a Fortitude. If you keep up on the sediment filter changes it will last a long time. The upfront cost would be there, but the ongoing costs for sediment filters would be low.
    This one's good for 1.5 million gallons before it needs to be replaced. Figure out how many gallons of water you average a month and pick one accordingly.
    https://aquasureusa.com/collections...ystem-1-500-000-gallon?variant=31777983070267
    Plus free shipping, no sales tax and they have 10% off sales all the time during holidays or 5% off for new customers. :notsure:
