Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jun 28, 2022 at 1:21 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Nice neat job as expected, you do nice work. :thumbsup:
    :101010:
    Delta09[QUOTED] and wilcam47 like this.
  2. Jun 28, 2022 at 1:25 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    That saggy conduit is not quite as bad as my sloped conduit :boink::thumbsup::rain:
    Delta09[QUOTED] likes this.
  3. Jun 28, 2022 at 1:32 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Best part is it isn't conduit. It's just 100 amp aluminum SE cable. :laugh:
    Pablo8[QUOTED] likes this.
  4. Jun 28, 2022 at 1:37 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Thanks Rusty! I really have all those hand me down tools to credit everything. The table saw and miter saw are hand me downs from my late grandfather. Although the Delta saw is worn slap out and not cutting right. Bearings in the motor are worn and the clutch brake are shot. It's remodeled lots of homes over the years so it's expected.
  5. Jun 28, 2022 at 3:37 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Ha, Thought it was PVC on a 147°F day.
    Carry on.
  6. Jun 28, 2022 at 5:13 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Picked up a Kill-a-Watt P3 at Harbor Freight and got a plug-in to medium twist base adapter from Home Depot and went a little test happy checking out the draws of all of the lights in my house.
    (Yes terrible picture due to the bright GE LED security bulb murdering levels)
    Work lamp .37amp 47.7 watts
    Warm round .28amp 23.6 watts
    Chandelier .25amp 30.5 watts
    Security .14amp 15.1 watts
    Tic-tak .12amp 15.0 watts
    Satellight: .72amp 56.8 watts
    Incanedison: .49amp 62.2watts
    LED strip 12" auto .30amp 35.7 watts
    Hall bulb: .16amp 17.0 watts
    Twist sticks .05amp 5.0 watts
    Point sticks .05amp 5.9 watt
    Bath bulbs .06amp 4.9 watts
    Wake up 0.04amp 3.8 watts
    Kitchen strip
    Low 0.06amp 7.2 watts
    High 0.13amp 16.3 watts
    Standard vanity .34amp 44.3 watts
    Bug bulb .06 amp 5.1 watts
    Zapper .48amp 30.3 watts
    What does this do for me?
    Uh...
    Helps improve my efficiency and make more conscientious decisions?
    I'll get back to y'all on that one...
    But I think it's pretty cool, going to be testing my appliances and what not next.
    It's a really cool tool to play with, supposedly you can enter your price per kilowatt from your power bill and get a better figure of how much any particular device is costing you per month.
    The amp draw indicator is also pretty neat because you can get an idea of how much load there is on a particular circuit by adding up all the amp draws.
    More and more I'm finding out that stuff doesn't draw anywhere near as much power as I thought it did.
    Though I do find it interesting that the dimmest bulb I have (which is an Edison type incandescent bulb) is still my most power hungry light, even more so than my almost too bright LED work lamps.
    mbarbay, dumontrider, Delta09 and 2 others like this.
  7. Jun 28, 2022 at 5:27 PM
    My Name is Rahl
    Unless I missed it, how did your all black gaming/VR room turn out?
    wilcam47 likes this.
  8. Jun 28, 2022 at 5:41 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Don't sell your skills short. I'm hard pressed to make a straight cut on any piece of wood it seems -- don't like working with wood (or on houses) much either. :mad:
    Most of that older equipment is designed so the bearings can be replaced. A little cash for bearings and an hour work might have it cutting like new.
  9. Jun 28, 2022 at 6:02 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Probably not a bad idea. I got alot of quarter round to cut and install in the house when I paint it in the winter. Might as well get a parts diagram now and order the parts I need now so they might be in by then. Ahhh, gotta love the supply chain...
    Although it could be something as simple as needing a new blade. The blade has probably been on there since 2012 and it was a used, but sharpened blade that a customer never picked up at my old work :anonymous:
    I have several new blades, but in the move I think I misplaced them as a quick 5 minute check I didn't find them. Guess I'll need to look harder...
    RustyGreen[QUOTED] and 308savage like this.
  10. Jun 28, 2022 at 6:04 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Incandescent bulbs are really good heaters that give off some visible light as a by product. :laugh:
    That said time is the biggest factor impacting your electric bill.
    You are billed by the killowatt hour = 1000 watts consumed for 1 hour
    Examples:
    1000 watt heater x 1 hour = 1 kwh
    100 watt bulb x 10 hours = 1 kwh
    10 watt bulb x 100 hours = 1 kwh
    Be aware of electricity thieves, anything that is warm all the time and stealthy about consumption like routers, cable boxes or the Satellite:
    57 watts x 24 hours per day x 30 days = 41040 watts consumed = 41 kwh
    Compare to the typical dryer that has a high profile for energy use but is really only consuming electricity when it is actually working for you.
    Dryer:
    3000 watts x 1 hour use x 10 loads per month = 30000 watts consumed = 30 kwh
  11. Jun 28, 2022 at 6:05 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Fuck that. I'll give up my washer and dryer WAY before I give up my internet. lol
  12. Jun 28, 2022 at 6:12 PM
    Key-Rei
    Key
    Florida
    Like the truck it's always going to be a "work in progress" but I'd say pretty awesome.
  13. Jun 28, 2022 at 6:13 PM
    Key-Rei
    Key
    Florida
    It is a good point though, I might get another digital timer like the one I use for my wake up lights to turn my router off when I'm away.
  14. Jun 28, 2022 at 6:16 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    These work good for filling nail holes on trim
    https://www.amazon.com/Minwax-11008...locphy=1026034&hvtargid=pla-392710146881&th=1
    RustyGreen and Delta09[QUOTED] like this.
  15. Jun 28, 2022 at 6:32 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :rofl::rofl:
  16. Jun 28, 2022 at 7:20 PM
    My Name is Rahl
    Nice. I'd love a photo with all the lights on. :rolleyes:
    :D
  17. Jun 28, 2022 at 8:32 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Every year my metal mailbox pole jacks up multiple cars front ends in the winter. They almost always knock on the door and apologize lol
  18. Jun 29, 2022 at 7:41 AM
    My Name is Rahl
    I have a smaller air compressor that I want to wire into my garage. I have the 12 gauge wire for it, but I am unsure of the breaker I will need.
    This is on the motor, can I assume that I need a 15a breaker?
  19. Jun 29, 2022 at 7:46 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    On a 13 amp motor startup will be killer, might actually need a 30 amp breaker and 10 ga wire. That's what most home 220 air compressors are on. Soon as it kicks on it'll likely trip that 15amp breaker.
  20. Jun 29, 2022 at 7:46 AM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    Not an electrician but pretty sure 20amp breaker for 12 and 15amp for 14.
