Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jun 29, 2022 at 7:50 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    You mean at the panel ? 20A (12ga)
  2. Jun 29, 2022 at 7:52 AM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    So those of you who do siding, is there a video or pictures of how you would put J channel up and over the peak of a roof? This is how they fixed my siding. Am I being to picky or is not right? Looks like shit to me.
  3. Jun 29, 2022 at 8:12 AM
    My Name is Rahl
    Well, scheisse. I got a 15a. Guess I'll have to return it and get a 20a.
    wilcam47 likes this.
  4. Jun 29, 2022 at 8:13 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Don't be surprised if you trip that 20a... Or you may get lucky. Single phase motors suck as far as startup goes.
  5. Jun 29, 2022 at 8:15 AM
    My Name is Rahl
    I think the guy I bought it off of had it on a 20a. I'll have to ask.
    wilcam47 and Delta09[QUOTED] like this.
  6. Jun 29, 2022 at 8:16 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Might be ok then. I'm use to working with 3 phase motors that are on a 30amp protectors, but only draw around 5-6 for something smaller like the one you have...
  7. Jun 29, 2022 at 8:28 AM
    bonifacio_629
    bonifacio_629 Well-Known Member
    Walther
    Virginia
    2018 Tacoma TRD Sport, 6MT 4x4 DCSB, Inferno
    Predator steps, TRD cat-back, lots of orange stickers.
    I mean, to be fair, whoever hit it looks to have crossed the center line, three feet of shoulder, and THEN hit the mailbox going the opposite direction. In (mean)spirit I'm with the guy who suggested making it tougher but doing that can really injure someone if they run into it on accident.
    A lot of the fancy homes out where I live have them encased in a 3x3 brick pillar. THAT would leave a mark. But they're up on the curb so I think that's how they get away with it.
    Delta09, 907rx7[QUOTED] and wilcam47 like this.
  8. Jun 29, 2022 at 12:42 PM
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    You need a 20 amp breaker which will be fine on the 12 gauge wire
    The startup load will not last long enough to trip the 20a breaker Breakers trip quick on a dead short but temporary overloads on startup will not cause a problem
  9. Jun 29, 2022 at 3:40 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Your going to need a min of a 30 AMP breaker you will kill that compressor motor FAST! Full Load Amps on that will most likely be 18 - 21
    How far is the run to the breaker box?
  10. Jun 29, 2022 at 3:58 PM
    IPNPULZ
    going to be fun!
    It does have a Start/run Capacitor?
    wilcam47 and My Name is Rahl like this.
  11. Jun 29, 2022 at 4:32 PM
    My Name is Rahl
    Even though it says 13.1amps on the tag? It no more than 3 feet from the outlet to the breaker.
    How do I tell? It's probably about 30 years old and is an old Craftsman.
  12. Jun 29, 2022 at 5:06 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    You can try the #12 wire on a 20 amp breaker (no larger) but I wouldn't recommend it.
    Motors need to have access to plenty of power to operate correctly, kind of like a high performance engine needing a larger fuel line than an economy engine.
    #10 wire and a 30 amp breaker would be a far superior job, you may get away with a 20 amp breaker (on the #10 wire) but it might trip on a loaded restart.
    Single phase motors have a very high start up current (inrush) about 2-3 times the running load.
    When the motor starts the additional current makes heat in the breaker, this is normal, the breaker is designed for this and the heat will dissipate in a short time.
    The normal "trip" function of a breaker is based on heat, a normal overload situation (too many watts for too long) will build heat in the breaker until it passes the design threshold and trips.
    In an over current situation (shorting hot to neutral for example) the breaker has a magnetic assist so it will trip faster.
    The issue here is in air compressor service where it will start and stop several times over a fairly short period of time, the start up heat builds up in the breaker causing the smaller size to trip.
    Delta09, la0d0g, wilcam47 and 2 others like this.
  13. Jun 29, 2022 at 5:31 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    This guy sounds smart. I’d do what he says.
  14. Jun 29, 2022 at 5:36 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Thanks, I don't know about smart but I try... :rofl:
  15. Jun 29, 2022 at 6:50 PM
    My Name is Rahl
    Thanks, Rusty! This is the best answer so far. I will only need to get a single pole breaker, right?
    He's super smart and I do pay attention to what he says.
    RustyGreen[QUOTED] and wilcam47 like this.
  16. Jun 29, 2022 at 6:52 PM
    98tacoma27
    Ben
    Not Beech Creek
    I run these two on the same circuit along with a 20" planer and 8" joiner... 12/2 plus ground on a 20A breaker for over 4 years without issue. (Not at the same time obviously)
  17. Jun 29, 2022 at 7:03 PM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Wonder if it makes a difference that u have them on a 2 pole 240v circuit?
  18. Jun 29, 2022 at 7:05 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    code here requires us to keep siding up 2" off the roof , but agree that looks pretty shitty , looks like they took a piece of j and just snipped and rolled it right over the top
    Toyko Joe and usmc2msu like this.
  19. Jun 29, 2022 at 7:06 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Of course it does.
    truchador[QUOTED] likes this.
  20. Jun 29, 2022 at 7:07 PM
    98tacoma27
    Ben
    Not Beech Creek
    That's what his will need to be on.
