Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jul 5, 2022 at 5:42 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Can you access the moving parts? Try a good silicone spray. Works wonders.
    308savage[QUOTED] and wilcam47 like this.
  2. Jul 5, 2022 at 6:08 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    It's rubber interlocking (think puzzle piece) gym floor tiles so they're already softer than the laminate over concrete floor while providing a good stable traction surface for VR shenanigans.
    Then the middle 3x5' section has a 5/8" anti fatigue mat under it which does two things, one it's spongy enough to be kind to my already bad and abused knees and two raises that section to where I can feel the little bit of smooth drop off transition which helps me stay in the tracking and "safe" area (no punching expensive screens and such)
    The neon green contrast tape is just visible through the Head Mounted Display (HMD/ VR headset) eyebox gaps and easily seen through the pass through external camera mode same with the green spike tape X in the true middle. The gaff tape sectioning keeps the puzzle piece seams smooth so I don't catch and trip as well as allow me to feel with my feet my relative position as well.
    Edit: So long as my toe tips stay on the rubber mat my hands can't collide with anything and break the controllers or anything in the room.
  3. Jul 5, 2022 at 6:15 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    With this sort of thing or laying out pipes or electrical box cut outs in cabinets I always strike a plumb line and a level line and measure everything from those lines .
    You have a sheet on the wall that you are going to abut your next sheet to so you can use that as a reference for your plumb line . The trick to accurately laying out boxes or pipes to precut (if you don't do rotozip method mentioned previously) is to measure both sides of every box or cut out from the same reference edge , so for instance in your second pic , if that electrical box is 40"(and away) from the plywood sheet you already have on the wall , I would measure and write down 40-42" or 41 7/8" to 42 1/8" or whatever it is off your plumb reference line , do the same from your level reference line at the top , ie 48"-52" down or whatever . In my experience measuring up from the floor introduces an error potential if the floor is not perfect , same thing as trying to measure to the centre of the box and then laying out the size of the box , all those things produce compounding errors
  4. Jul 5, 2022 at 6:26 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    They are all sealed in between the panes
  5. Jul 5, 2022 at 6:28 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Yes, the latest Google/Nest AI Cameras are worth the $$$.
    My complaints are with the "Nest Secure" system (door and motion sensors) that they pulled the rug out from under.
  6. Jul 5, 2022 at 6:32 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    The garage is next in Sept
  7. Jul 5, 2022 at 6:51 PM
    IPNPULZ
    going to be fun!
    This is the design for the Garage
    907rx7 and Pablo8 like this.
  8. Jul 5, 2022 at 7:05 PM
    Key-Rei
    Key
    Florida
    :redxfall:
    wilcam47 and Toyko Joe like this.
  9. Jul 5, 2022 at 7:05 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    I think I got mine from BJs and I chose this over leather or vinyl because it breathes it’s been a great chair and for $119-129? It’s worked out well for me.
    Key-Rei[QUOTED] likes this.
  10. Jul 5, 2022 at 7:08 PM
    OZ-T
    Peter North
    British Columbia
    damnation
  11. Jul 5, 2022 at 7:08 PM
    SRH
    SRH My horns hold up my halo
    Shauna
    2018 Sport
    Earplugs….
    JK!! I’ve not given it any thought until I read your post. Mine are a bit loud too. Be curious to hear how you solve it.
  12. Jul 5, 2022 at 7:28 PM
    Key-Rei
    Key
    Florida
    That's actually another good reason why I went with it over others I was considering, it breathes so much better than any solid chair be it leather or cloth, perforated or otherwise.
    Gaming can get... Intense.
    :bananadead:
    I swear I lost 5lbs playing Metal Gear Raiden Rising, needed to keep a fan on me for that one.
    Now I have full control over the thermostat for better or worse.
    :anonymous:
  13. Jul 6, 2022 at 4:24 AM
    308savage
    Adam
    East Tennessee
    We're going to have the entire insert replaced due to the fogging issue. I'll try to remember to ask the door guys if there is a fix for the noise.
  14. Jul 6, 2022 at 5:38 AM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    Is having the door fixed less expensive than just replacing the entire door?
  15. Jul 6, 2022 at 5:53 AM
    My Name is Rahl
    That's cool!
    I don't like that they did away with that either, but the cameras have motion and noise tracking and the subscription saves 100% of the A/V for 6 months. You can even set zones so certain areas of the camera images are not sampled for alerts. This works good for my doorbell because it was constantly alerting on the motion of the street.
    X2, I'd also like to know.
    308savage likes this.
  16. Jul 6, 2022 at 10:07 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
  17. Jul 6, 2022 at 10:33 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Four plywood panels up. See pics on previous page.
    First I didn't have the right/decent router bits (added to tool list). I did a doubly thing. Cut power, removed cover plates, covered outlets with painters tape, bomb canned them with primer gray, put panel in place temporarily to mark from wet paint. Then took panel down measured 2x, drew with matching unused boxes I have laying about and drywall squares, cut, put in place and screwed down. Worked fine. But still a pain in the ADHD ass.
    EDIT: I forgot, the pain in the ass part is the floor slopes down toward the doors. Normal for a garage but just a hair of a lip on the level foundation.........hence the hammered in chainrings to rest the panel on. I should have done this from the start.
    RustyGreen, truchador and Delta09 like this.
  18. Jul 6, 2022 at 11:38 AM
    308savage
    Adam
    East Tennessee
    I'll post it as soon as I find out.
  19. Jul 6, 2022 at 12:18 PM
    Key-Rei
    Key
    Florida
    How do I stop grass growing in my gravel? I was going to spray but I don't want it to run through the dirt and kill the yard on either side.
    FastEddy59, 308savage and wilcam47 like this.
  20. Jul 6, 2022 at 12:34 PM
    My Name is Rahl
    It should only kill what it's sprayed on. The only surefire way is to put underlayment under the gravel when it's first laid down...
    wilcam47 likes this.
