Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jul 12, 2022 at 4:32 PM
    rgvaggie11
    rgvaggie11 Well-Known Member
    2017 Quicksand TRD 4x4
    I know! I noticed it after he left. I messaged his company, should fix it tonight. :annoyed:
    wilcam47 and Drainbung[QUOTED] like this.
  2. Jul 12, 2022 at 9:49 PM
    rgvaggie11
    Update. Got it done. Next time I'll DIY the tile work for sure. Thanks everyone
  3. Jul 12, 2022 at 9:53 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    That black plastic thing is called a trim ring. It's left on until the trim is installed. Any tile guy that's ever done a shower/tub surround knows this. I'm betting this was your "tile" guys first time doing tile. lol
    wilcam47, jsi and Drainbung like this.
  4. Jul 12, 2022 at 10:13 PM
    ElGringo
    ElGringo Well-Known Member
    2019 Cement Grey
    Four months into living in "The Dream Retirement Home" aka The Money Pit, found a leak in the hot tub. Excavation has begun. Hoping they can find the source without having to drian the pool, already drained the hot tub. Due to severe drought, water trucks are out of the question to refill, and we're on a well. And it's 108F. Yay!
    MGMDesertTaco likes this.
  5. Jul 13, 2022 at 5:56 AM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Update on the porch.
    Let me know if you something wrong, Thanks.
    Work is supposed to continue today but heat might be an issue.
  6. Jul 13, 2022 at 8:36 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    MGMDesertTaco, Drainbung and wilcam47 like this.
  7. Jul 13, 2022 at 8:57 AM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    Primed and painted. Hung a ceiling fan and the wife bought some privacy screens for one side.
    Vmax88, truchador, mbarbay and 10 others like this.
  8. Jul 13, 2022 at 8:59 AM
    williams63
    chili
    nh
    2011 dblcb
    On to the next project. I love being on vacation.
  9. Jul 13, 2022 at 8:59 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Looks good
    williams63[QUOTED] likes this.
  10. Jul 13, 2022 at 9:04 AM
    williams63
    chili
    nh
    2011 dblcb
    Going to replace the lattice under the deck. Trying to get a few more years out of it. Don’t like how they just butted them up with no support behind them. The 8’ section doesn’t line up with the post.
  11. Jul 13, 2022 at 9:14 AM
    williams63
    chili
    nh
    2011 dblcb
    The first and third post go all the way down to a cement footing and are almost 10’ apart. They nailed a 2x4 under the 2nd post to attach the lattice to. I want to cut it and and picture frame it at every post but I would be cutting almost 3’ off each section of lattice. Seems like a waste. I have 6 sections on this side and 4 more on the other.
    wilcam47 and Drainbung like this.
  12. Jul 13, 2022 at 9:28 AM
    TinoTaco
    TinoTaco Well-Known Member
    Nanaimo
    2017 TRD DCSB Off-Road - White
    Nice. I probably missed it, but whatcha using for decking?
    Venom[QUOTED] and Pablo8 like this.
  13. Jul 13, 2022 at 3:20 PM
    Venom
    Kevin
    Massachusetts
    The landing and the stairs might be Granite, if not a cement landing and stairs cap. It all depends on time, weather. Once finish this porch they have a 2nd porch to work on. Then finish excavating the whole yard, hydroseeding. There's a lot work to be finish.
    TinoTaco[QUOTED] and wilcam47 like this.
  14. Jul 13, 2022 at 5:12 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Something quick and easy today. I have an outlet on the front of the garage that I use for the pressure washer or the like. It's a GFCI like you're supposed to. Well last weekend I went to wash one of the trucks. Got out the electric pressure washer and nothing. Dead. Hmm... Wouldn't even reset. Ok, well then. There's an outlet just inside the garage door so I just used that and forgot about it. Today I finally got around to it. I keep a spare GFCI hanging around so I'll do some investigating.
    Wiring was good, nothing off in the box, no water intrusion (you can see the sealant I used)...
    Reconnected it and turned the breaker back on. Yea, still dead. Well crap. So I just decided to swap GFCI's. Old on right...
    Turned the breaker back on and it works fine? Ok, well that sucks. Didn't even get 2 months use out of the other one. Got out the sealant and re-sealed the cover. Due to my siding I have to seal around it.
    If this happens again, we'll have to do something different. :annoyed:
  15. Jul 13, 2022 at 5:15 PM
    wilcam47
    Will
    Bourbon state
    i changed a few to regular plug:anonymous:
    Drainbung, Delta09[QUOTED] and Pablo8 like this.
  16. Jul 13, 2022 at 5:24 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    :eek::eek::eek:
    I contemplated this, but I'm not. If moisture is an issue there's an outlet right behind the wall that is upstream of this GFCI. I'll just move it inside. I wired the whole garage so I did leave myself some options...
    I mean technically I think every outlet in a garage needs to be GFCI protected, but I got 3 different circuits run to handle all my crap. Also don't think the GFCI would like my welder too much... :anonymous:
  17. Jul 13, 2022 at 5:34 PM
    98tacoma27
    Ben
    Not Beech Creek
  18. Jul 13, 2022 at 5:50 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I'm hoping to not have to go with something like that as it's way too bulky/gaudy right in plain sight in front of the house. :annoyed:
    wilcam47 and Pablo8 like this.
  19. Jul 13, 2022 at 5:57 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    In case you change your mind, that was the right answer.
    Delta09[QUOTED] likes this.
  20. Jul 13, 2022 at 6:16 PM
    TwistedTLM4
    TwistedTLM4 Unknown Member
    Philadelphia, PA
    '05 DCSB TRD Sport
    WeatherTech Floor Mats, WeatherTech Bug Shield and Vent Visors, Audio Upgrade, RaamAudio RaamMat & Ensolite, Mr. Marv's Custom 10" Sub Enclosure, Pop N Lock Electronic Tailgate Lock, mattgecko's Bedlights, Demello Offroad Single Hoop Bumper, Marathon Seat Covers, Leer Topper, OME885s on 5100s, @Blackout14 HD Leaf Pack
    I've used these with great success.
    http://www.aifittings.com/catalog/i...for-flat-surface-retrofit-construction/DBHR1C
    Also less gaudy.
    wilcam47 and Delta09[QUOTED] like this.
