Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jul 14, 2022 at 6:44 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    Downstream of the switch is disconnected & capped. Hell you may as well disconnect & cap both ends of that wire that goes from the switch to the outlet. The wire will still be in the wall but disconnected on both ends. The switch can be removed & the wall patched. Or the switch can remain & be repurposed for something else. Not sure how anything is backfeeding anywhere. The outlet is still getting power from the same "always hot" source, it's just powering both plugs once you take the switch out of the picture.
  2. Jul 14, 2022 at 8:40 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Venom, SRH, 4x4Taco2012 and 8 others like this.
  3. Jul 14, 2022 at 8:54 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I recently bought a small freezer and put it in the dining room, ran a dedicated circuit for it.
    wilcam47[QUOTED], Delta09 and Pablo8 like this.
  4. Jul 14, 2022 at 9:05 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Needs some marshmallows or hotdogs
    Venom, SRH, Fargo Taco and 2 others like this.
  5. Jul 14, 2022 at 9:49 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Just et a yuge piece of pie.....
  6. Jul 15, 2022 at 6:59 AM
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    looks great. been thinking of getting one of those Solo Stoves. i don't have the room for a nice pit like you
    wilcam47 likes this.
  7. Jul 15, 2022 at 9:26 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    And?
    :p
  8. Jul 15, 2022 at 10:43 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Sugar bomb. Not good when you are in your mid 60's. Some kind of strawberry lemonade pie.
    Delta09 and Fargo Taco[QUOTED] like this.
  9. Jul 16, 2022 at 5:07 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Did a little more electrical work today. Added a couple outlets on their own 20a circuit in the master to run my computer and a small window AC unit in case the old central AC quits. I must be getting pretty good at measuring out where I need to drill, went right to it with my pulling rods!
    Also did some outlet switching in the garage. I moved the GFCI from the outside wall to upsteam one outlet where it will be inside. Hopefully that will solve the pre-mature GFCI failures...
  10. Jul 16, 2022 at 6:12 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    Welp, that explains why my power bill was so high the last 2 months. :facepalm: Thought the $ rise was due to losing a very large tree last winter that covered the western side of the house (like the whole thing including most of roof). Noticed today that the air coming out of the ducts smelled like attic. Went up and found the return plenum disconnected. Not sure if it’s supposed to be held on by more than the aluminum tape but that was my fix unless it needs something else. Any HVAC guys care to chime in?
    58B501C2-A1FE-4D9F-BE4E-A037450CF321.jpg E57CAEA4-38FA-4FA0-BBB5-DFD242C8E163.jpg
    4x4Taco2012, SRH, shakerhood and 3 others like this.
  11. Jul 16, 2022 at 6:24 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Not an HVAC guy but seems like solid mechanical attachment would be necessary
  12. Jul 16, 2022 at 6:26 PM
    wilcam47
    Will
    Bourbon state
    Same, be easy to put sheet metal plate and some self tapping screws.
  13. Jul 16, 2022 at 6:28 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    Agreed. Tape should be secondary to seal the seams. A mechanical connection should hold the two together.
    4x4Taco2012, SRH, shakerhood and 2 others like this.
  14. Jul 16, 2022 at 6:58 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Taping directly to the unit is common with the duct board.standard practice is the build a sheet metal plenum then attach either flex duct with a metal collar or plenum box. It should be okay they way you have it but would look into getting It addressed in the future.
  15. Jul 16, 2022 at 7:06 PM
    IPNPULZ
    going to be fun!
    House 5 or 6 yrs old?
  16. Jul 16, 2022 at 7:37 PM
    theredofshaw
    less than that. built in 2019. had a guy up there doing the preventative maintenance service back in the fall.
    shakerhood likes this.
  17. Jul 16, 2022 at 8:35 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    god I hate duct board, always got a nose bleed when I worked with it
    I would look a replacing it with a metal can
    and what is the liquid stain in the overflow pan
  18. Jul 16, 2022 at 9:10 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    at least you didn't use duct tape
  19. Jul 17, 2022 at 3:53 AM
    IPNPULZ
    going to be fun!
    Looks like water stain build-up from condensation coming off the suction line.....
  20. Jul 17, 2022 at 5:28 AM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Don't forget the chocolate square with graham crackers.
    wilcam47[QUOTED] likes this.
