Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Aug 1, 2022 at 7:06 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    I guess we’ll find out tomorrow! They did our gutter’s and did a great job.
    Slashaar[QUOTED] and wilcam47 like this.
  2. Aug 1, 2022 at 7:21 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Best I got was 9k for siding. 12k with soffits and gutters added.
  3. Aug 1, 2022 at 7:30 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Its either a DPST switch like mentioned above, or theres a contactor in there (my bet, motor loads typically use these) and the light switch is just for the 120V to operate the coil. Both are perfectly safe.
    jubei, shakerhood and wilcam47 like this.
  4. Aug 1, 2022 at 7:31 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Yikes
    shakerhood and Slashaar[QUOTED] like this.
  5. Aug 1, 2022 at 4:19 PM
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    We're setting forms on Wednesday for the footings and then it should be super quick to do the framing of the walls and rafters.
    Maybe the group can help advise on something:
    The barn is currently on a crush rock floor over clay (welcome to Oregon!). We want to put a concrete floor in once we take the old wall down (maybe about a month or two from now). Just looking at the floor as it is now, I'm pretty confident I can grade this all out myself if I break it up into sections instead of hiring a contractor (one guy wanted 16K to grade and pour my floor when there's 0 form work). The current crush rock floor is already 4" below where the lowest footing will be -- let's call that the top of my proposed slab. There's a pretty big hump where the wall I'm taking down will be so that'll be kind of a pain to break up, but it's doable as it's just a sliver of the overall floor. My question is, how much 3/4 minus would you put down for a 4" concrete floor (non structural) that will just house a gym and some wood working equipment? I'll assume it's a good idea to put some 6 mil poly down over the crush rock since it's being poured on clay, yeah? Or is that overkill? I'm looking to gauge how much hand digging I'll realistically need to do. My back can probably handle removing 2-6" of clay just chipping at it after work here and there, and I can easily handle screeding and tamping the 3/4 minus. But if I'm digging to China because I need 12 feet of gravel base then I'm renting a mini excavator.
    Delta09 and RustyGreen like this.
  6. Aug 1, 2022 at 4:54 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    If you rent a mini ex or skid steer it will probably be just a few hours of work.
    As I have gotten older any time using a shovel just gets less and less attractive.
  7. Aug 1, 2022 at 4:58 PM
    kmorgan3
    Kyle
    PNW
    The more I look at it, the more my thoughts are going the same direction. I think a skid steer for a day ($300) would make pretty quick work of rough grading 6-8” below top of footing. It’s tight in there, but I think just straight in straight out would get the job done. Hmmm.
  8. Aug 1, 2022 at 5:10 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Is this building going to be heated ?
  9. Aug 1, 2022 at 5:13 PM
    kmorgan3
    Kyle
    PNW
    It won’t. Maybe a space heater here and there (I’ve got a provision for a 200A sub panel), but no plans for a dedicated heat system.
  10. Aug 1, 2022 at 5:16 PM
    OZ-T
    Peter North
    British Columbia
    I would consider some Type 2 EPS foam under the slab but bare minimum I would do 3 or 4" of compacted granular fill and lapped and taped 6 mil poly , tape the poly at all seams and up the exterior walls
  11. Aug 1, 2022 at 7:22 PM
    MGMDesertTaco
    Monsoon season means lots of downed trees and cleaning up. Got tired of renting chainsaws and bought one today. It's a Stihl MS261C with an 18" bar. I suppose it's kind of a home improvement thing. :D
  12. Aug 1, 2022 at 7:28 PM
    wilcam47
    Will
    Bourbon state
    Good saw
  13. Aug 1, 2022 at 7:30 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Do yourself a favor and run the premix non-ethanol through it. Sweet saw!
  14. Aug 1, 2022 at 7:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I like those outlet too.
    They can be back wired. They have a clamp in them that screws down and grabs the wire.
    I always screw up my hook when side wiring. And I don’t like “push in” back wiring.
    The ones show can be back wired, but hold much better.
    RustyGreen[QUOTED] likes this.
  15. Aug 1, 2022 at 7:34 PM
    TnShooter
    Deogee
    STOCK
    You picked a good one.
    MGMDesertTaco[QUOTED] likes this.
  16. Aug 2, 2022 at 2:17 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Great saw, I have the non-C version. Thing is a beast with amazing power to weight ratio.
  17. Aug 2, 2022 at 2:52 PM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    The home improvement contractor came today. He said they did a good job. The neatness of the work is normal for masonry contractor.
    I wanted the gutter on the porch roof replace he want to replace the whole front of the house gutters. I wanted to replace damage vinyl siding, he wants to replace all the vinyl siding. It pretty much got nowhere fast.
  18. Aug 2, 2022 at 2:54 PM
    wilcam47
    Will
    Bourbon state
    :annoyed::annoyed::annoyed:
    Delta09 and Venom[QUOTED] like this.
  19. Aug 2, 2022 at 2:55 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Some things you can do yourself.
    Venom[QUOTED] and FastEddy59 like this.
  20. Aug 2, 2022 at 2:56 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Was it a Lady contractor. All or nothin’ tipped me off. :argue:
    Venom[QUOTED] likes this.
