Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Aug 14, 2022 at 7:08 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Galvanized: looks to be in great shape on the outside, rusted up on the inside.
  2. Aug 14, 2022 at 7:10 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Not good to see though
  3. Aug 14, 2022 at 7:40 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    I used Legacy Industrial stain in my shop and like it.
    308savage[QUOTED] likes this.
  4. Aug 14, 2022 at 12:33 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    Good tip thanks a lot!
  5. Aug 14, 2022 at 1:43 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Question for you. Does the 1/4" drain saddle hole really not leak once the tubing is in there? Seems like a weird design that would be prone to leaking :notsure:
  6. Aug 14, 2022 at 2:22 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Installed these this weekend
  7. Aug 14, 2022 at 2:37 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    What kind of lamp does it take. Very Nice. :thumbsup:
    IPNPULZ[QUOTED] and wilcam47 like this.
  8. Aug 14, 2022 at 2:51 PM
    Kremtok
    Gary
    Houston, TX
    You know, the more I think about this the less I think that I need a plumber. It looks like the valve assemblies are all screw on and that will make the pretty easy to replace. Anything I need to know before I try it myself?
  9. Aug 14, 2022 at 2:55 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Know where your main shut off valve is, and that's really it.
    Get yourself plenty of that plumber's tape as you'll want it for the new ball valve assemblies.
    And buckets, even if you relieve pressure by turning on faucets or running the toilet, you'll still have water in those lines you'll want to catch.
  10. Aug 14, 2022 at 2:56 PM
    Kremtok
    Gary
    Houston, TX
    Yup I found that and tested it yesterday.
    Kwikvette[QUOTED] likes this.
  11. Aug 14, 2022 at 2:56 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    you might have to cut the pvc pipe and add a coupler at reassembly to disassemble and replace your shut offs
    la0d0g, Kremtok[QUOTED] and Kwikvette like this.
  12. Aug 14, 2022 at 3:04 PM
    Kremtok
    Gary
    Houston, TX
    Hm. How come?
  13. Aug 14, 2022 at 3:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I never added my bit of home improvement recently for the small yard.
    I've never done any plumbing and related work with the exception of replacing a water heater or replacing laundry water hoses.
    Being summer (and how hot it gets here) we decided to let the grass we had left to die off and focus on running a sprinkler system.
    You can rent one of those trenchers at Home Depot for pretty cheap, just make sure to hose it off clean so you don't get charged extra.
    Here's our yard with trenching done. Rather than have the entire area covered in grass, we expect to have only half of it covered with grass (for the dogs) and the rest an extension of our covered patio.
    Had bought about seven 10' long pieces of PVC schedule 40 pipe. Originally I intended to run four sprinkler heads (one at each corner) but based on the small size and range of coverage, three would provide plenty of overlap and saturation.
    Fortunate enough to not live in an area where freezing temps are a concern; all this stuff can remain exposed outside. Removed the fixture and ran a T for my water source. Just below that, a ball valve so I can shut it off at the source in case a leak developed or my timer failed.
    What's funny is, I never intended to buy this timer but so far it's been freaking awesome! Got it at Lowe's for $10 cause it was on clearance.
    Works via bluetooth using their app, but has memory so you can set a routine watering schedule and more. Also got the first part of the water line setup going.
    Was about 110 degrees when I was setting this up, had nothing better to do. Was laying out the pvc pipe to get an idea of measurements and all.
    Laying down the first piece.
    The first bend to create the 'outer perimeter'.
    Working around the drainage, though the sprinkler pipe is sitting above in this picture I ran it below as I didn't want the weight of the dirt affecting the pipe long term.
    Setting the sprinkler body height, more or less.
    With everything laid out, just needed to tie it all in. Here's what was left.
    I'm sure there are better ways but, it was my first time.
    Measurements look good so far...
    Yep, they were good! Fortunately cause it's all getting cemented together, none of it with the exception of the sprinkler hoses and bodies are threaded.
    Let there be water! Oh and it may be hard to see but, there is a sprinkler straight ahead providing overlapping coverage in a 180 degree fashion.
    All three sprinkler heads are 180 degree.
    Criticisms welcome, first time ever doing a sprinkler system!
  14. Aug 14, 2022 at 3:18 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Because shut off valves, adapters, are not all the same size or length, etc.
  15. Aug 14, 2022 at 3:41 PM
    OZ-T
    Peter North
    British Columbia
    that threaded pvc adapter that goes into that brass tee was likely installed , then the shut offs screwed into the unit , then the pipe glued on . Just saying you may not be able to disassemble everything by unthreading it , in case you needed to get some pvc fittings and glue etc
    Kremtok[QUOTED] likes this.
  16. Aug 14, 2022 at 4:11 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    IPNPULZ and FastEddy59[QUOTED] like this.
  17. Aug 14, 2022 at 4:23 PM
    My Name is Rahl
    Don't forget to get some different nipples to replace the galvanized ones.
    Kremtok[QUOTED] and wilcam47 like this.
  18. Aug 14, 2022 at 4:27 PM
    wilcam47
    Will
    Bourbon state
    Kill power, gas, and water pressure obviously. Id teflon tape any threads
  19. Aug 14, 2022 at 4:29 PM
    Kremtok
    Gary
    Houston, TX
    I'm going to replace the assembly with the same one that's on there now.
    I see what you mean. I think I can unscrew the top and bottom of the valve assembly, then get enough room to unscrew one of the two connections on the relief valve. I'll keep the hacksaw handy as a plan B.
    Absolutely! I'm hoping they sell brass or PVC ones at Lowe's.
  20. Aug 14, 2022 at 5:35 PM
    IPNPULZ
    going to be fun!
    its one of them old time looking filament lamps A19 60W 2700K I think
