Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Aug 14, 2022 at 5:45 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    So I found out my well pump emergency repair should be good to go for the long run.
    The Gates radiator hose I used is EPDM so it should be safe for the house water long term no worries about leaching chemicals, UV stable so I don't have to worry about the little bit of sun exposure it gets and it's rated for a working pressure of up to 75PSI which is 15 below my pump cut off.
    $20 fixed it permanently I suppose and saved me the $400 emergency well pump repair call that probably would have put more of that crap plastic hose that was on it before.
    I'm happy.
    :D
  2. Aug 14, 2022 at 6:25 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    this weekend i took on the project of fitting an 18" dishwasher in a 15" cabinet space... some call me a magician, i generally go by electrician.
    got a free 18" dishwasher from a customer. sorta an oddball size, so was a long shot when i started looking a few years ago.
    was going to be tricky, as none of my cabinets are a standard size. going both ways off the sink, i've got 15", 36" lazy suzan units, and finally some 37" cabinets. so no easy ride on this one. cabinet layout also sucks, but that's a different problem for a different day
    i went to the left. the plan? remove the 15" cabinet, then cut down the lazy suzan to fit.
    cabinet came out simple enough, but turns out my sink "cabinet" is just a facia front panel with a a hacked in raised floor and toekick. wasn't expecting that.
    ended up salvaging the removed cabinet side panel to make a sink panel side
    then had to pull apart the lazy susan and 're-size' it to make everything fit.
    cutting down the rotating assembly of the lazy susan, and marking out how to get the rear panel to re-wrap back around to the front
    the entire assembly would not come out-- it was designed for the center rod to move through the space where the countertop existed, and i was NOT removing the entire counter for this! so in-place cutting was the only option.
    believe it or not, did all cutting with an m18 hackzall. would've preferred a jigsaw, but it honestly wasn't likely to come out any cleaner.
    lazy susan cut down. i knew it was going to reduce my space, wasn't expecting this much! but it is what it is...
    and the finished product
    other surprise was the hollow core door, one day i'll fill it in and stain/varnish it to match. i sent the cut-off to my sister, the paint store expert, to match the stain.
    of course, no project is without it's surprises
    all-metal undersink drains, starting to rot out, the 1 is held together and not leaking only by rust/corrosion. needed to re-pipe anyways to get the dishwasher drain in, good thing too, this was already on borrowed time!
    all piped in and almost read to go! lots of crud in the old setup for some reason
    i was all set, and celebrating not having any leaks, then everything plugs up and water starts backing up the drain...
    i knocked some of the sediment somewhere loose re-piping it, it's clogged somewhere.
    so after all that, NOW i need to call a plumber this week to roto rooter out the line...
    wilcam47, Delta09, Kwikvette and 3 others like this.
  3. Aug 14, 2022 at 6:58 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Finished mudding and sanded the drywall around my new door. Came out better than I expected it to. The worst looking spot will get covered by tile so no big deal. Also hung my shades on the doors. Not bad for $40 a pop on Amazon.
    All thats left is to prime the wall, and cut/nail up some trim, caulk it it and paint it. Wall will stay just primed for awhile as it makes no sense to paint it now when it'll all be repainted within a few months.
  4. Aug 15, 2022 at 4:38 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Have you got a link to those shades? Or a brand/part #?
    wilcam47 likes this.
  5. Aug 15, 2022 at 6:26 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    ChrisDowa Light Filtering Roller Shades, with 5% Openness Solar Screen, UV Protection, Water Proof Fabric. Solar Semi Sheer Roller Blinds for Office and Home. Easy to Install.Beige,26" W x 72" H https://www.amazon.com/dp/B096FK8JHC
    They have different sizes, if screwing into a steel door I recommend some self drilling screws.
    308savage[QUOTED] and wilcam47 like this.
  6. Aug 15, 2022 at 8:45 AM
    Championsumo
    Championsumo Well-Known Member
    Tulsa, OK
    2015 DCSB 4X4 TRD Sport
    I did the same thing more or less and was constantly dealing with the timer, leaking breaking etc. I probably went through 4 of them before I gave up and installed an actual sprinkler controller and valves, still feeding off of the outside hose bib though. Good luck with your install it looks great!
    Kwikvette[QUOTED] likes this.
  7. Aug 15, 2022 at 10:50 AM
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    Ran the power cords to the Nest exterior cams. Not ideal in the Florida summer heat. I also installed an outlet in the garage ceiling so i can install a wall mounted osculating fan. Trying to figure our what size and brand to use. Looking for a 18"-20". Recommendations welcome
    Plus getting attic stairs installed this week.
    My Name is Rahl likes this.
  8. Aug 15, 2022 at 11:09 AM
    My Name is Rahl
    https://www.fastenal.com/product/details/4201115
    That one is nice, and it's made for us by TPI, Corp.
  9. Aug 15, 2022 at 11:10 AM
    gtrotter07
    gtrotter07 Well-Known Member
    2007 Tacoma reg cab 4x4 on 37's; 2021 TRD Offroad, 6 speed
    37's,lockers, bumpers, bobbed etc.
    Redoing my 1960's shed into a man cave. Insulation, skinning it out and then will build a bar/ bench.
  10. Aug 15, 2022 at 11:37 AM
    OffroadJet
    Sebastian, FL
    Fargo Taco likes this.
  11. Aug 15, 2022 at 5:29 PM
    308savage
    Adam
    East Tennessee
    Gotta call the boss man and have a chat, this ain’t up to my standards
    60363355-38F5-476D-9766-A084884552A4.jpg 5DD08CD7-3BD7-4148-A9F3-81586A84FD4F.jpg A1ABCC00-7F94-4880-B5D1-5843F04CD792.jpg 48292513-4FAE-4A52-909E-FFDEE54B2A5A.jpg
  12. Aug 15, 2022 at 5:39 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    :eek::eek::eek::eek::eek::eek::eek:
  13. Aug 15, 2022 at 5:42 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    My home improvement photos from today.
    C13A1347-D2F3-4580-84FB-E0CF55A27327.jpg CECF45DC-D8E5-414E-8106-6F7262A2A988.jpg
  14. Aug 15, 2022 at 5:44 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Yikes
    Slashaar likes this.
  15. Aug 15, 2022 at 5:44 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Caulking and paint make me the carpenter I ain't!
  16. Aug 15, 2022 at 5:44 PM
    wilcam47
    Will
    Bourbon state
    :eek:
  17. Aug 15, 2022 at 6:13 PM
    308savage
    Adam
    East Tennessee
    This company used to be known for quality work, guess something changed. They’re gonna fix this mess if they want to get paid!
  18. Aug 15, 2022 at 6:21 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    what exactly were they supposed to be doing here ? Window retrofit ?
    308savage[QUOTED] likes this.
  19. Aug 15, 2022 at 6:29 PM
    308savage
    Adam
    East Tennessee
    Encapsulating the windows, wrapping them in aluminum, so we don’t have to paint them anymore.
  20. Aug 16, 2022 at 5:40 AM
    mbarbay
    mbarbay Well-Known Member
    Baton Rouge, LA
    2016 Tacoma BBP DCSB LTD 4X4
    https://www.amazon.com/gp/product/B000MIKSPC?ie=UTF8
    If you get to pick you ladder ( and opening), do yourself a favor and get this one....huge opening, and very stable. you could walk up it like a staircase
    OffroadJet[QUOTED] likes this.
