Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Aug 21, 2022 at 7:59 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Attic work sucks -- especially in the summer, the last 4 times I was in the garage attic it was over 120 degrees up there and each time I told myself "...this should be the last time..." :laugh:
    For electric work I like to go big rather than go again.
    I can see loads in the game room increasing over the years as who knows what is added, would it be practical to pull a larger line and put a sub panel somewhere near by?
  2. Aug 21, 2022 at 9:14 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    A few years ago I went to change the hot water tank out and found a leak had completely destroyed the entire hallway, took me about 3 weeks to replace the bad beams and flooring.
  3. Aug 21, 2022 at 9:24 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Can't like that but it is an excellent example of water being promiscuous.
    Must have been an awful job. :pout:
  4. Aug 21, 2022 at 9:26 PM
    shakerhood
    Southern Ohio
    Yeah it sucked, the worst part was not having hot water for 3 weeks while I fixed all that. Heating water up on the stove to do dishes and bathe with was a real pain in the butt.
    RustyGreen[QUOTED] likes this.
  5. Aug 21, 2022 at 9:29 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    If it was electric you could have temporary rigged it most anywhere, gas not so easy.
    shakerhood[QUOTED] likes this.
  6. Aug 21, 2022 at 9:32 PM
    shakerhood
    Southern Ohio
    It is electric but would have been too difficult to rig anything up due to the entire area needing replaced.
  7. Aug 21, 2022 at 9:37 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I'd have a water heater in my living room with PEX pipe and #10 wire on the floor before I gave up hot morning showers.
    Sometimes in the morning I'm not even sure I'm alive before I hit the shower. :laugh:
  8. Aug 21, 2022 at 9:43 PM
    shakerhood
    Southern Ohio
    I walked across the beams for 3 weeks with no issues, and naturally the very last night before the floor was going down I slipped thru and shattered the hot water pipes, Grrr!
    Key-Rei and RustyGreen[QUOTED] like this.
  9. Aug 21, 2022 at 9:57 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I have always had trust issues with older plastic pipe for just that reason. Fortunately I haven't had any break in service but when tearing it out it shatters so easily -- terrifying to think it had 100 psi (city) water pressure on it.
    I was a big believer in copper until the prices went into orbit, it is so satisfying to craft a job neatly.
    The PEX is so fast to work with and once you invest in the tools and a good supply of fittings/rings it is a very economical system.
  10. Aug 22, 2022 at 6:41 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I cleaned up about 30 lbs of previous internet and cable runs off the side and inside of my house. Holy crap, I want to punch the AT&T guy who installed the previous owner's cable. So many holes, so many half assed ports, and wires that were run to nothing I just pulled right out the walls... They even cut a hole in the wall, realized they missed the mark, then screwed a cover plate straight into the drywall. Turns out they missed the drywall since the hole was bigger than the distance between screws, so it was just barely hanging on. :annoyed: They cut a section of carpet out in one spot to put a stupid little ethernet box instead of a wall box too.
    I don't even want to know what all is run into the attic. Even the new Xfinity guy just ran the cable around the bottom edge of the back of the house instead of going into the wall at the box, then straight up into the attic so it would be all contained...
  11. Aug 22, 2022 at 7:23 AM
    shakerhood
    Southern Ohio
    Maybe someday in the future l can look into replacing the supply lines with PEX.
    RustyGreen[QUOTED] and 308savage like this.
  12. Aug 22, 2022 at 7:28 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    A good crimper is the biggest expense, about $65 IIRC. Get a good cutter too, just makes the job easier on you.
  13. Aug 22, 2022 at 7:50 AM
    My Name is Rahl
    I found that cutting the PEX as close to perfectly straight was the hardest part to get right. A pair of ratcheting pipe cutters really eased the job.
  14. Aug 22, 2022 at 9:18 AM
    Slashaar
    Josh
    Kansas City, MO
    05Taco4x4 and MGMDesertTaco like this.
  15. Aug 22, 2022 at 9:45 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  16. Aug 22, 2022 at 9:47 AM
    Slashaar
    Josh
    Kansas City, MO
    wilcam47 and Sig45[QUOTED] like this.
  17. Aug 22, 2022 at 11:56 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
  18. Aug 22, 2022 at 5:45 PM
    MGMDesertTaco
    I think @wilcam47 posted about this in the woodworking thread. Anyway, my repair kit arrived today in a huge oversized box. Appears to be 2 screws, a new guard and some instructions. Just need to find the time to install.
  19. Aug 22, 2022 at 5:46 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Looks easy
  20. Aug 22, 2022 at 5:49 PM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Just applied for mine in the last few days. Figured it would be easier to DIY instead of trying to find a place to do the repair/fix.
