Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Sep 12, 2022 at 9:18 AM
    TinoTaco
    TinoTaco Well-Known Member
    Nanaimo
    2017 TRD DCSB Off-Road - White
    DIY drip irrigation question for y'all. We moved into this place in the spring and the old timer that was here before us put in a hodge podge of different components, but hey it works. And it being a kit that was cobbled together the flow zig zags around the property.
    Anyways, my house sits facing East/West, and the main shutoff for the system is to the North of my driveway, and the systems seems to loop around the property counterclockwise, thru the sideyard, across the backyard, and down the southside and hopefully terminates at the street. I say hopefully, as there is a largish bush (6' in diameter) in the front that we want gone, and there is a crew working next door this week with a backhoe that offered to pull it when we were chatting about it. Hey better than hacking at it with a shovel/pickaxe etc.
    Here's the rub, that irrigation system has a drip emitter about 3-4' away from the edge of that bush, and I followed the mainline down and its running straight into the root ball of the his bush. I can't tell if it carries on past there, but the only place it could carry on is under the driveway back to start of the run (highly unlikely). Would you guys just cut & cap the system at the last dripper and let the backhoe do it's dirty work? Or would you be nervous of about that line going to anything else?
  2. Sep 12, 2022 at 9:47 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I’d personally cut and cap then test. If you still get water where you need then you are set. Leaving it could mean the backhoe pulls it out and disrupts stuff.
    wilcam47 likes this.
  3. Sep 12, 2022 at 11:08 AM
    TinoTaco
    Nanaimo
    Ya I think you're right. Inheriting stuff from a previous owner that was just kind of thrown together is a bit difficult to follow sometimes.
  4. Sep 12, 2022 at 11:12 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I had to plug lines off the main manifold because one leaked and it ran under concrete pad, and another channel half worked. I wasnt about to cut concrete or dig it all up
    Drainbung and TinoTaco[QUOTED] like this.
  5. Sep 13, 2022 at 10:07 AM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Is there a code height for the bulkhead doors foundation, from the ground to the top of foundation?
    Is it considered as a step? Since I'm stepping on it going in/out.
  6. Sep 13, 2022 at 3:01 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Well, the garage transformation has started....
    Doors/shelves/drawers/lighting/wiring goes in tomorrow along with aluminum hanging wall panels.
    2017EBF8-6118-4D09-A342-50D3FF896E41.jpg E34623FB-DB76-41DC-BD88-23A0A649202B.jpg 31817982-D65E-4265-97C9-295F9031E171.jpg 534CF76B-522E-412F-B1FB-A3A36ED77F3D.jpg 21616D7A-DEED-415A-8380-4464E54F0865.jpg 30D5F5E3-C657-4881-8AE6-68A14F51BA27.jpg 722D2132-8AE2-4FDB-B7A5-F04A18BBCBCA.jpg C4DC525C-7DB9-48E4-B2B1-9A3915941A67.jpg
    TVphotog97, mbarbay, jubei and 11 others like this.
  7. Sep 13, 2022 at 4:46 PM
    grissom
    grissom Well-Known Member
    Peter
    NorCal
    I noticed the screw in LED light fixture - Does it work well?
    Slashaar likes this.
  8. Sep 13, 2022 at 5:04 PM
    IPNPULZ
    going to be fun!
    Actually I was very pleased with them I have 2 and there rated at 8K lumen each got them at HD for like $15 on sale.....
  9. Sep 13, 2022 at 7:10 PM
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    Bought this little shed for my diesel genny. Major pita! Took like 6 hrs and I'm handy. Open floor so I laid a nice pallet down and leveled it w gravel. Nice thing was that I was able to screw down the shed to the pallet. Then I spray sealed all the seams just for the heck of it and glued baffles on strategic areas (flat areas!). I figure I just raise the lid and open the doors to run when needed. When Spring comes I'll put the genny back in the garage to protect it and annual maintenance.
  10. Sep 13, 2022 at 7:15 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    That's pretty interesting. We have HOA rules against having 'sheds' but this non-permanent storage might sneak by them.
    Where did you get it and what did it cost you?
  11. Sep 13, 2022 at 7:34 PM
    virginiamarine
    Northern Virginia
    It was Amazon and it cost $350. Warning though...major major pita to put together. I actualy put together a video for the next person to save them time!! Lol. Put it on Youtube for others to see. I think you have a legitimate point about it with hoa. It would work since it's not permanent.
    Goplus Horizontal Storage Shed Outdoor, Multi-function Storage Cabinet for Garden Yard Lawn, 6x3FT https://www.amazon.com/dp/B07WRYR4KZ
    Kremtok[QUOTED] likes this.
  12. Sep 14, 2022 at 5:10 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Those work well, but if you find yourself needing more coverage, get some GE Light fixture outlets and run a chain of leds across the ceiling. As long as the draw isn't more than your original bulb, you're good to daisy chain a bunch of them. I have about 4 led bars for each of the 2 light sockets I have in my garage. Pretty good coverage, but I'd like to add more, I just used up all of the pack I bought on Amazon. Pics in my House thread in my signature.
  13. Sep 14, 2022 at 6:57 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    My HVAC mini-split saga continues. I have had the installer back 6 times in 6th months. 4 of which were for condensate dripping inside the house because they didn't insulate the copper refrigerant lines and or didn't install the condensate fittings properly. 2 times for the unit not cooling (low refrigerant). This last phone call with the office said they won't charge me for the truck fee but might invoice me for the work... like WTF? NO you guaranteed the work for 1 year parts and labor.
    :annoyed::annoyed::annoyed::crapstorm: Looks like they won't be doing the HVAC change out at our other rental now. :frusty:
    Seriously don't know why it is so hard to find a company that does a complete job without call backs. :mad::mad::mad:
    :bananadead: Rant /done.
    MY50cal, 308savage and Drainbung like this.
  14. Sep 14, 2022 at 6:59 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    There is one in your area. At least one that is better.
    Drainbung likes this.
  15. Sep 14, 2022 at 11:14 AM
    StandardTaco
    StandardTaco Well-Known Member
    Nebraska
    2020 MGM TRD-OR 6MT
    This is kind of a silly question, sorry.
    I just bought a house, and there is no towel bar in the bathroom. The only available space is in the corner by by the toilet, which doesn't seem ideal, but if it's the only option... :notsure:
    Which is a less weird place to hang bath towels, directly over the toilet or directly next to the toilet?
    I'll post some more interesting projects in the near future hopefully.
    wilcam47 and My Name is Rahl like this.
  16. Sep 14, 2022 at 11:16 AM
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    dont hang towels by the toilet. Pee splatters like 6ft. if you dont have options. you can mount to the back of the door or get a rack that hangs from the door
    StandardTaco[QUOTED] likes this.
  17. Sep 14, 2022 at 11:17 AM
    StandardTaco
    Nebraska
    2020 MGM TRD-OR 6MT
    Right, that's what I was thinking, but I don't know what else to do.
    Pee shield? :rofl:
  18. Sep 14, 2022 at 11:21 AM
    98tacoma27
    Ben
    Not Beech Creek
    Hang it under the window. It will be behind you when you pee.
    Slashaar and StandardTaco like this.
  19. Sep 14, 2022 at 11:23 AM
    StandardTaco
    Nebraska
    2020 MGM TRD-OR 6MT
    That's not a bad idea. I'm so used to seeing towel bars at a certain height I never considered it could be hung lower under the window. Thanks
  20. Sep 14, 2022 at 12:02 PM
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    Above the toilet.
