Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Oct 10, 2022 at 11:23 AM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    I was actively sipping that KoolAid this morning haha. I found a local shop that stocks their mortar
  2. Oct 10, 2022 at 11:40 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    So today was a plumbing day. I disconnected the hose from the front spigot and it was just a constant drip. Instead of just cutting off the water and worrying about it in the Spring I decided to do it now. Now this shoulda been a relatively easy swap, but having two sources of water and both going to it with valves everywhere, it was a hot mess. I decided to cut all that out and start from scratch.
    Here's kind of a look what the mess of valves and pipes. All the stuff to the right.
    So, both water sources cut off, all of it went outta there!
    Capped off a feed from the well that was going to all that mess. It was the feed going to the boiler for hot water that I no longer use. Had an interesting mix of valves too as I could feed the cistern into the hot water if I wanted to. All cut out.
    Unfortunately the well to spigot bypass I had to use a Sharkbite cap. Just no room in there to do what I wanted to do. It's all gonna get cut out one day to be replaced with 3/4 Pex anyways.
    Because of how tight it was I could not get my mini copper cutters in there to remove the copper out of the back of the sill-cock. So I pushed it as far as I could outside and just cut it in half. Put the new one on the outside.
    So in my haste I forgot to wrap tape on the threads before putting it in the hole. I use tape and dope, but due to room I just used a shittonne of dope. This is the small opening I had. Also where the oil tank sits so I had to straddle the damn tank like you're riding a Bull :rofl:
    Lines connected and ready to go!
    Had issues with the brass Pex adapter soldering so I just soldered on a copper male adapter onto the old copper and used a Pex female to adapt it to the pex.
    While the water was off I did replace the crusty washing machine valves out to 1/4 turn ones.
    Old.
    So, that's it for now. I'm not a plumber by any means, but I think I was able to clean it up a whole lot better than it was.
  3. Oct 10, 2022 at 11:55 AM
    Squatting Pigeon
    Squatting Pigeon Remember, bird watching goes both ways. Moderator
    North Texas
    TRD OR 4R | GR Corolla
    Using their mortar is safest bet for a warranty, it can get a little pricey though. All depends on where your project priorities are.
    Clark27[QUOTED] likes this.
  4. Oct 10, 2022 at 11:58 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    IMHO , for what you might save on a single bathroom install , we just follow their product recommendations
    Fargo Taco and Clark27[QUOTED] like this.
  5. Oct 10, 2022 at 12:04 PM
    Clark27
    Springfield, MA
    2015 Lexus GX460
    Well when I first started this project, I liked their product and wanted to use it. I saw most of their stuff is available at the Home Depot just down the road which was nice but then learned after the fact I can’t get the mortar from HD. I priced it online and shipping was insane because of weight. I did find a flooring place local that sticks their ALL SET Mortar so I’ll use that i think.
    Let’s be honest, their stuffs not cheap at all. I’m into this system already so I’m going to use it and I’m in agreement; why skip out on the specific mortar for a nominal savings. The warranty matters to me god forbid I have to use it.
  6. Oct 11, 2022 at 8:39 AM
    Squatting Pigeon
    North Texas
  7. Oct 11, 2022 at 8:40 AM
    StandardTaco
    StandardTaco Well-Known Member
    Nebraska
    2020 MGM TRD-OR 6MT
    Your caulk was too hard? o_O
  8. Oct 11, 2022 at 8:45 AM
    My Name is Rahl
    Looks like you need to be more gentle with your caulk!
  9. Oct 11, 2022 at 8:55 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
  10. Oct 11, 2022 at 10:08 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    You didn't listen to 38 Special's instructions.
    Just hold on loosely
    But don't let go
    If you cling too tight babe
    You're gonna loose control
  11. Oct 11, 2022 at 10:30 AM
    Squatting Pigeon
    North Texas
    I knew TW wouldn’t disappoint with the caulk jokes :rofl:
  12. Oct 11, 2022 at 12:26 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Sorry to interrupt yous alls caulk talk butt....
    Finished up the front of the house today. Cut back all what I wanted to cut back. Also there was a buildup of mulch against the brick, so I shoveled it out and spread it around.
    My burn pile has been going before 12pm :rofl:
    05Taco4x4, 907rx7, RustyGreen and 6 others like this.
  13. Oct 11, 2022 at 1:59 PM
    My Name is Rahl
    I'm surprised that you didn't join in with the talk about caulk.
    RustyGreen and Delta09[QUOTED] like this.
  14. Oct 11, 2022 at 2:11 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I was too busy doing yard work! :laugh:
  15. Oct 11, 2022 at 3:58 PM
    Squatting Pigeon
    North Texas
    Bringing the thread back on topic…
    For shame.
  16. Oct 11, 2022 at 4:15 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    :anonymous: :anonymous: :anonymous:
    Typically I derail threads, so I guess this is me evening things out :rofl:
  17. Oct 11, 2022 at 4:46 PM
    Squatting Pigeon
    North Texas
    It’s disappointing, but I do understand.
    :rofl:
  18. Oct 11, 2022 at 9:22 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    "Caulk Talk"
  19. Oct 11, 2022 at 10:44 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    He interrupted broken caulk talk to show us his trimmed bush. The house definitely looks bigger now.
    mbarbay, Sig45, theredofshaw and 8 others like this.
  20. Oct 12, 2022 at 4:32 AM
    My Name is Rahl
    I've heard trimming your bush makes the house appear bigger. Like an optical illusion of sorts.
