Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Nov 14, 2022 at 10:28 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Is conduit not needed? I'll be using 12/2, so if I can get by with a smaller diameter hole that's even better. I think I've still got some Tapcon's.
  2. Nov 14, 2022 at 10:29 AM
    308savage
    Adam
    East Tennessee
    It'll be caulked on both sides.
  3. Nov 14, 2022 at 10:34 AM
    98tacoma27
    Ben
    Not Beech Creek
    Might be a local code thing. I would at least use a piece as a bushing to protect the jacket from the brick/block.
  4. Nov 14, 2022 at 11:10 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    12-2 will probably be a little tight through a 3/8" hole - it should fit though.
    As for conduit, it depends. Will any Romex be exposed, or will it all be inside a wall? Conduit if exposed, not needed if in a wall.
    308savage[QUOTED] likes this.
  5. Nov 14, 2022 at 12:24 PM
    308savage
    Adam
    East Tennessee
    Through the block/brick, weatherproof box will be mounted directly to the outside wall.
  6. Nov 14, 2022 at 12:44 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Done! Customer is still shopping for solar light post caps. They added the gate for the dog.
  7. Nov 14, 2022 at 1:02 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Something I've always wanted to do since moving in, but never did it. I finally removed the old clunky shower door and put up a regular shower curtain and liner.
    Yes, I know the tile is severely outdated and the grout looks nasty. The tile is staying, but will get re-grouted here eventually.
    Also bought a new vanity faucet to install tomorrow. The one on there now has had a slow drip for a while, but now is dripping every 10 seconds or so. Could I have put in another seat and spring, yea, but it's some crappy builder grade faucet. For the replacement I went with another Moen in the same finish to match the kitchen faucet. Didn't want to dive into it today as I need to replace the pop-up drain and that's gonna turn into a shit show. Also need to re-caulk the tub, but want to do that earlier on in the day. Says 4 hours to be able to get wet, but I want to let it set longer than that.
  8. Nov 14, 2022 at 1:23 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I hate those slider doors, i ripped the ones out on last place, just seems to open the bathroom more. And the doors are a pain to clean
  9. Nov 14, 2022 at 1:28 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Since the glass is the way it is I had a quick method for cleaning those. I used a fine scotch brite and the liquid version of Bar Keepers Friend. Cleaned all the residue off of it quickly. Since I have a water softener it didn't get a build up frequently.
    There was supposed to be a gasket on the bottom, but it was missing. Their solution was a thick bead of caulk. No wonder there's a spot in the floor where it had been leaking at one time.
    Drainbung, Sig45 and wilcam47[QUOTED] like this.
  10. Nov 14, 2022 at 3:35 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    I stopped by Lowe's today but didn't see anything that looks like it might be a replacement part. Where would you suggest I look for it next?
    Drainbung likes this.
  11. Nov 14, 2022 at 4:01 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Drill a few small holes and chisel out the big stuff. Goes easy once you get started.
    Edit. Ignore this, I thought you were mounting the box inside the brick.
  12. Nov 14, 2022 at 4:08 PM
    BiscuitNaBasket
    BiscuitNaBasket Active Member
    Sam
    Central Indiana
    2019 DCSB OR
    Moderate speed High drag
    Couple recent things. Replacing a Joist and subfloor, replacing a collapsed sewer line to the main, and replacing some sub floor/carpet with a cheap ass linoleum entry way. Replaced all the hose spigots with updated frost proof ones but I didn't take any pictures. I was just happy to be done with that.
  13. Nov 14, 2022 at 5:57 PM
    MGMDesertTaco
    When I did my ring floodlight camera I tapped into an existing outlet in the garage and ran romex over the attic and through the front of the garage into this junction box. I got a few plugs at Lowes or HD (can't remember which) to close off the extra knockout holes. I used a small piece of conduit only where the romex pokes through the house and into the box, but the rest of the romex was just stapled along the way. I also used those blue tap con screws to hold the junction box to the front of the garage. Zero issues since installing it a few years back.
    https://www.amazon.com/Sigma-Electric-143854BR-2-Inch-Bronze/dp/B00BVB66F0
  14. Nov 14, 2022 at 6:15 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    Hi guys/gals.
    I have been posting up tidbits of my deck rebuild in the +50 thread, lots of knowledge in there but I'm at a point, trying to fix a mistake that I made recently. It was suggested that I post it up in the 'home improvement' thread so here it goes.
    Long story shortened up- I removed a bit too much material on the very end of the deck beam with my new power planer. I ended up taking a bit more then 1/8" of material off, all in an attempt to get the outside joist to sit flush across the double 2x10 deck beam. I took a bit too much off.
    The paint stirring stick is .140 thick, so in-between 1/8" and 3/16". This leads to the next issue.
    5/4 deck plank has about a 5/16" gap above the joist.. It's way too much to drawn down with the deck screws that I intend to use to anchor the deck boards.
    Eyeing down the joists, the 3rd one down is higher ( wider ) then the ones around it, so I could take it down a tiny bit with the planner but I'm not convinced that it would be enough. The joist material ( and general lumber quality) that I have around me is shit at best. I've seen lumber at a commercial yard that looked worse then the garbage that is sold at Lowes and HD.
    My questions are- how do I un-fuck this, or at least get it very close to "right" and not be an eye sore? This outer joist will have the stairs attaching to it, so it's out in plain site. MY first thought was to add some sort of shim under the bottom of the joist to raise it up a bit. Another was some sort of shim under the deck beams until I get to the mid section of the joist where things are on a much better plane.
    I had thought of getting a 2x10 and ripping it in a fashion so that I get the lost height back at the end where I need it.
    A buddy suggested using shim, but then adding a trim board up tight against the bottom of the deck planks to visually hide the shim.
    I don't know, I'm open for suggestions, short of removing all of the joists and building another deck beam.
  15. Nov 14, 2022 at 6:20 PM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Home Depot had a Black Friday sale for the PEX expansion tool by Milwaukee and I’m invested in the system now. Should be a great long term investment
  16. Nov 14, 2022 at 6:26 PM
    wilcam47
    Will
    Bourbon state
    Id cut a shim to size and put it under the joist if you worried about it rotting use a piece of trex or plastic to lift it, trim the other high joist down
    Sig45 and la0d0g like this.
  17. Nov 14, 2022 at 9:13 PM
    island taco
    island taco Well-Known Member
    Vince
    victoria, canada
    White '23 LBDC TRDSport
    Kicker speakers, Key amp, Spiker hood struts, tonnueo cover, Cooper AT3 4s, Method Double Standard Bronze
    Take the piece to the original manufacturer or a local window shop. Each manufacturer uses different sizes
    Kremtok[QUOTED] likes this.
  18. Nov 15, 2022 at 4:23 AM
    308savage
    Adam
    East Tennessee
    I guess this was my main concern. From what the internet says (cause it's always true), you should drill through the mortar for lightweight items and through the brick for heavy items. I think I'm going to try to line up the box so that the holes will all be through the mortar.
  19. Nov 15, 2022 at 4:37 AM
    Sig45
    Mark
    Maine
    This ^^
    Or a plastic shim. If you haven't planned on it, I'd also recommend joist tape on the joists.
  20. Nov 15, 2022 at 4:49 AM
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    I only paid $60 for mine, but if you are doing this more than once (drilling masonary), I highly recommend. I have a cordless hammerdrill, which is nice, but it's no replacement. This is $ well spent if you can get a coupon/etc and get it for $70.
