Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Nov 19, 2022 at 7:29 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    prob not
    MGMDesertTaco[QUOTED] likes this.
  2. Nov 19, 2022 at 7:53 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    If I was getting an Amish shed I would want it raised like an Amish barn raising
  3. Nov 20, 2022 at 5:44 AM
    My Name is Rahl
    Normally they are sold by an English or Mennonite shed place that will advertise Amish built sheds.
  4. Nov 20, 2022 at 5:52 AM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    You’d be surprised what some Amish have. They have a business to run and they appreciate the almighty $ just like everyone else.
  5. Nov 20, 2022 at 6:01 AM
    My Name is Rahl
    Ain't that the truth!
    SH7mi[QUOTED] likes this.
  6. Nov 20, 2022 at 8:21 AM
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Maybe I haven’t had enough caffeine, but the purpose of the attic vent (in the roof) is to release any moisture build up in the attic. Mine is very dry. Then the attic itself has insulation to prevent heat transfer from the house to the attic. Why would any of this create heat or moisture in the attic? Just my two cents, but the code seems right to me. Maybe it’s a PNW thing?
  7. Nov 20, 2022 at 9:27 AM
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    From my research the biggest issue with attic moisture is envelope tightness. If there is any air gap in the ceiling around light fixtures or anything else it's going to vacuum the hotter humidified air up into the attic.
    With the temperature differential you'll end up with condensation building between the air leak and insulation eventually saturating it.
    Relevant video, skip to 1:30 mark
  8. Nov 20, 2022 at 10:05 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The vapour / air barrier stops air movement between the conditioned and unconditioned spaces . If there is no barrier you are leaking the humid / heated air from inside your house to the outside
    Batt insulation does zero to stop air movement . Ever done a renovation and found all the batts are black or dirty around all the plugs , switches or pot lights? Thats from air movement drawing air in to the house when it is under negative pressure like when you have a range hood or bath fan on , you are essentially filtering your inside air that you are breathing through the batt insulation.
    Attic vents are intended to vent moisture from a vented roof system out of the the attic which is true but you want to limit the contribution to that from the conditioned space as much as possible otherwise you are essentially paying to heat your attic
    BC is also in the PNW and our code is all about air tightness and energy efficient buildings
    The beginning part of this video re the control layers is a good primer
    https://youtu.be/FXXgjvOJcYI
    truchador, RustyGreen and 907rx7 like this.
  9. Nov 20, 2022 at 11:07 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    So you ever do a simple project and it goes sideways and you have to get out the saw-zaw? Yea, that's me today...
    Old pop-up drain was rusted solid and would not separate at the top. Nasty shit slung everywhere, but it came out! :rofl:
    Everything went back ok despite almost throwing up a couple times from the smell coming from drain line...
  10. Nov 20, 2022 at 11:19 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Same miserable experience a couple weeks ago...:annoyed:
    RustyGreen and Delta09[QUOTED] like this.
  11. Nov 20, 2022 at 11:26 AM
    OZ-T
    Peter North
    British Columbia
    the classic runaway reno
  12. Nov 20, 2022 at 11:44 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    At this point if something goes right on any little thing I do I get real suspicious... :rofl:
    I'm just lucky I have many tools at my disposal to quickly solve something. Can't imagine just your average young couple doing the same thing and having to buy an expensive tool every time. Couple co-workers have just bought houses or are getting ready to and I'm probably gonna be pretty damn busy here soon. Can't let anybody struggle if I can help it...
  13. Nov 20, 2022 at 1:15 PM
    jsi
    jsi Well-Known Member
    native earthling
  14. Nov 20, 2022 at 1:21 PM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Yes, and I'm a cheap bastid that refuses to pay someone for what I can do.
  15. Nov 20, 2022 at 1:27 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yea, I'm cheap and can do it myself. That and most likely do a better job.
    I can only imagine what it would have cost an electrical company to add one circuit to a bedroom like I did last week. It took me just $200 in materials alone (needed to buy a new 250' roll of 12/2 so that was a little extra then it should have...).
  16. Nov 20, 2022 at 1:31 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    I'll pay for some things. Looking at you mud, tape and paint. Can I do those things? Yes. Do I want to? No. When my wife painted the kitchen I was on the couch. To be fair, I did everything else in the remodel. Including stripping the kitchen to the studs and redoing some of the worse electrical work I've seen. I also hung, taped and mudded the drywall.
    Who mentioned blown insulation up-thread?
    jsi, truchador, RustyGreen and 6 others like this.
  17. Nov 20, 2022 at 5:36 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Guess I’ll be installing a new fan in a week or two.
  18. Nov 20, 2022 at 6:11 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Damn, back in my my day (or currently) we just sang off of memory! :rofl:
    Actually need to upgrade my current fart fan in my bathroom. I hate to patch the ceiling, but I want to go with a Panasonic unit which is a little bit smaller in size, but can suck out the farts better!
  19. Nov 20, 2022 at 6:18 PM
    MGMDesertTaco
    I can vouch for the Panasonic whisper quiet exhaust fans. I've got them in the laundry room and both bathrooms and highly recommended them. I don't need the built in bluetooth speaker. My master bathroom already has a TV on the wall anyway. :rolleyes:
  20. Nov 20, 2022 at 6:24 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I was gonna get one with a light, but I might just for for one that is fan only. The 8 bulb vanity light provides a lot of light (don't judge me, I have a large mirror and the light fixture is actually decent looking) and I was going to add a single LED recessed fixture above the tub/shower anyways. Kinda seems strange to add more light to expose my less than attractive nude self... :rofl:
