Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Nov 21, 2022 at 1:17 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I wasn't as good back then, so luckily the trim was being painted an oil based white. I used a good bit of caulk on that job :laugh:
    I have stained trim in my house now, so I gotta be more precise now.
    RustyGreen and Sig45[QUOTED] like this.
  2. Nov 21, 2022 at 1:18 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Caulking & Paint.....make you the carpenter you ain't. :D
  3. Nov 21, 2022 at 1:18 PM
    98tacoma27
    Ben
    Not Beech Creek
    It's a distraction from the smell
  4. Nov 21, 2022 at 1:21 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    That house had 2 layers of drywall everywhere so instead of making a proper jamb extender I just notched my trim. Made more work for myself and didn't realize it at the time :laugh:
  5. Nov 21, 2022 at 1:21 PM
    Sig45
    Mark
    Maine
    :lalala:
    RustyGreen and Delta09[QUOTED] like this.
  6. Nov 21, 2022 at 2:11 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    I’ll probably never use the speaker!
  7. Nov 21, 2022 at 2:30 PM
    My Name is Rahl
    :amen: and :amen:
    RustyGreen, Sig45[QUOTED] and Delta09 like this.
  8. Nov 21, 2022 at 2:42 PM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    How can I tell if I have lead water pipes or lead solder?
    City sent a letter that we have high concentrated of lead in the water.
  9. Nov 21, 2022 at 2:45 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    It's the solder. If you're concerned about it then you'll have to do a re-pipe with copper pipes soldered with lead free solder or convert to PEX. However some old towns still have lead piping out in the street so there's nothing you can do about that.
    Honestly I grew up in a house with lead soldered copper pipes and I turned out just fine... Wait, they may be onto something with that... :rofl:
  10. Nov 21, 2022 at 2:50 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    is this deck not like 10' off the ground?
  11. Nov 21, 2022 at 2:58 PM
    98tacoma27
    Ben
    Not Beech Creek
    Did they test from your spigot or was this sent as a general warning?
    Venom[QUOTED] likes this.
  12. Nov 21, 2022 at 3:10 PM
    My Name is Rahl
    You could unsweat the fittings and use crimp on copper fittings. You don't have to convert to PEX or entirely re-copper.
    Sig45 likes this.
  13. Nov 21, 2022 at 3:11 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    The way that the deck boards are laid out in the pic- they run parallel to the house.
    Not quiet that bad, but it's not just a short hop to the ground. I'm 6' and I can touch the bottom of the joists from the ground underneath. The yard slopes away from the foundation, so it looks taller on the far end of the deck vs the part that's closest to the house.
  14. Nov 21, 2022 at 3:11 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    That will get ungodly expensive though. Plus you gotta have the pro-press tool.
  15. Nov 21, 2022 at 3:12 PM
    My Name is Rahl
    Can you post a wide view photo of that end of the deck?
    JustAddMud and wilcam47 like this.
  16. Nov 21, 2022 at 3:13 PM
    My Name is Rahl
    You would save on replacing the straight runs of either material.
  17. Nov 21, 2022 at 3:15 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    This, kinda confusing only seeing a small piece of the board. I do see the gap
  18. Nov 21, 2022 at 3:19 PM
    Venom
    Kevin
    Massachusetts
    I got copper pipes coming in through the basement floor. Into another pipe, not copper, then back to copper. I don't know what's buried in the yard and tied into the city water lines.
    The water department is marking up the streets with blue arrows/lines.
    Is there away to tell if I have lead solder?
  19. Nov 21, 2022 at 3:20 PM
    Sig45
    Mark
    Maine
    Maybe it's there, but the end rim/band joist seems to be missing??
    My Name is Rahl likes this.
  20. Nov 21, 2022 at 3:21 PM
    My Name is Rahl
    I'm sure there is a test you can buy. I'm also pretty sure that before a certain year, you can almost guarantee the use of leaded solder.
