Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Nov 21, 2022 at 3:24 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Any soldering done prior to January 2014 has the potential. Also brass fittings contained lead up until recently.
    Typically the city uses roll copper from the street to your meter inside the house. This will vary per locality.
  2. Nov 21, 2022 at 3:24 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Is it galvanized? Got any pics of it?
    Venom[QUOTED] likes this.
  3. Nov 21, 2022 at 3:25 PM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    The letter didn't mentioned anything about water test from the house. It mentioned, Houses built before 1986 may have lead pipes. Also water department slacking.
  4. Nov 21, 2022 at 3:27 PM
    Venom
    Kevin
    Massachusetts
    The letter mentioned 1986 and before.
    I don't remember if the pipes been re-solder with lead free solder.
  5. Nov 21, 2022 at 3:30 PM
    Venom
    Kevin
    Massachusetts
    Do you the there's copper from the sidewalk shutoff valve to the indoor meter, buried?
    Does the copper had the potential of rotting?
    Delta09[QUOTED] likes this.
  6. Nov 21, 2022 at 3:34 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I don't know what your town uses, but it's common in my area. Roll copper (or type K) is thick and durable. Last a ridiculously long time.
    However, this sounds like the city has the issue and not you since they're marking out all the water lines, and they didn't test your water specifically.
    At that point I wouldn't worry about much, even if (which you likely do) you have lead soldered water lines.
    Fargo Taco and Venom[QUOTED] like this.
  7. Nov 21, 2022 at 3:37 PM
    Venom
    Kevin
    Massachusetts
    My neighbor told me to stick a magnet to the pipe. Doesn't stick.
    The only thing that is not copper is the fitting, pipe that connect the incoming copper pipe to the meter. The rest is copper.
  8. Nov 21, 2022 at 3:40 PM
    Venom
    Kevin
    Massachusetts
    I'll see if I can get pics. I suck at getting the pics posted.
    wilcam47 likes this.
  9. Nov 21, 2022 at 3:55 PM
    Venom
    Kevin
    Massachusetts
  10. Nov 21, 2022 at 4:56 PM
    98tacoma27
    Ben
    Not Beech Creek
    Venom[QUOTED] and wilcam47 like this.
  11. Nov 21, 2022 at 5:01 PM
    Venom
    Kevin
    Massachusetts
    Do you think it will work on test the solder for lead or lead pipe?
  12. Nov 21, 2022 at 5:06 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Take a sample and send it in to a lab. There's tons of water quality labs across the US. Find one you like and send it in. Then you'll know for sure what's in your drinking water.
  13. Nov 21, 2022 at 5:09 PM
    Venom
    Kevin
    Massachusetts
    I think Home Depot sends water to the lab to be tested. I know Home Depot test for hard water.
  14. Nov 21, 2022 at 5:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    K , well I'm as picky a builder as they get and even I wouldn't be worried about s shim being visual there , especially if it was a rip of matching PT material
    Clark27 likes this.
  15. Nov 21, 2022 at 5:24 PM
    98tacoma27
    Ben
    Not Beech Creek
    I don't know but it's designed for paint not solder.
  16. Nov 21, 2022 at 5:25 PM
    98tacoma27
    Ben
    Not Beech Creek
    It does say metal on the package though. For $12 it might be worth a shot.
    Venom likes this.
  17. Nov 21, 2022 at 5:29 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    This is the best that I have ATM, I need to stand on a ladder to get high enough to take a good pic from that corner. In this pic, the upper left corner of the structure is there I'm showing the big gap and where I goofed and planed a bit too much off it the deck beam.
    Correct, the outer ( end) rim joist has not been installed yet.
  18. Nov 21, 2022 at 5:32 PM
    Venom
    Kevin
    Massachusetts
    I just found this online, Copy and paste
    3M LeadCheck Swabs. This product was "EPA-Recognized" in 2010, but for negative results only; the rate of finding false-positives is 98% (Source PDF)). This is an extremely high false-positive rate.Apr 16, 2019
    If true, It doesn't sound good.
    My Name is Rahl likes this.
  19. Nov 21, 2022 at 5:32 PM
    theesotericone
    Bishop CA
    Just shim the bottom of the joist where it sits on the beam.
    MGMDesertTaco and wilcam47 like this.
  20. Nov 21, 2022 at 5:41 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Im sorry but, laying on my back under the house unsweating fittings sounds like hell on earth. Id rather pull new pex that's less likely to freeze anyhow.
