Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Nov 21, 2022 at 6:20 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    PEX is the shit! Any new plumbing I do in my house is PEX. Cut the copper and sweat on an adapter of your choice, and away you go!
    We did appropriately ground my new electrical panel right at the source of my water as my electrician knew I would be doing such. Was extra money in bare copper, but planning ahead is always cheaper in the long run.
    RustyGreen and Fargo Taco like this.
  2. Nov 21, 2022 at 6:22 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I just use the sharkbites for the first transition then crimp the rest.
    My only gripe about pex is the plastic taste/smell in the water for the first couple weeks or so.
    Delta09[QUOTED] likes this.
  3. Nov 21, 2022 at 6:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Thats exactly what I said about a week ago lol
  4. Nov 21, 2022 at 6:25 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Maybe a second opinion will make the answer that much clearer? lol
  5. Nov 21, 2022 at 6:27 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I try not to use Sharkbite's now adays if I can help it. I typically solder on a male adapter on the copper and use a female PEX adapter.
    Yes, they have solder on adapters, but the lead free brass combined with the lead free solder is a bitch to solder on so I just do it that way. I just wrap tape and dope on the connections. Eventually everything in my house will be PEX anyways.
    Venom and RustyGreen like this.
  6. Nov 21, 2022 at 6:31 PM
    theesotericone
    Bishop CA
    Use copper on the stub outs. I've run a lot of PEX but I always use copper stub outs. I can't stand it when plumbers get lazy and stub PEX out. It flops around and looks like shit.
    JEP, Drainbung, TwistedTLM4 and 4 others like this.
  7. Nov 21, 2022 at 7:28 PM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Meaning terminate all the supply lines into stub outs before attaching to fixtures?
  8. Nov 21, 2022 at 7:32 PM
    theesotericone
    Bishop CA
    Exactly.
  9. Nov 22, 2022 at 4:00 AM
    My Name is Rahl
    I think you need to put on the rim joist, raise up the joist you fvcked up to be flush, shim underneath and call it a day.
    Sig45 likes this.
  10. Nov 22, 2022 at 8:22 AM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    I appreciate the feedback, I'm just trying to avoid having a visible shim between the deck beam and the joist. I realize that the missing space needs to be made up somewhere, I'm just trying to figure out the most "invisible" solution.
  11. Nov 22, 2022 at 8:30 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Cut a long tapered shim, the entire length of the mistake, and replace what you cut off. Or just replace that piece of lumber. I’d replace it if it’s causing you this much grief. You’ll feel better in the long run!
  12. Nov 22, 2022 at 8:33 AM
    OZ-T
    Peter North
    British Columbia
    Remove the low joist and replace it with a taller one
  13. Nov 22, 2022 at 8:34 AM
    OZ-T
    Peter North
    British Columbia
    thats exactly what I said a week ago
  14. Nov 22, 2022 at 8:53 AM
    My Name is Rahl
    The most invisible option would be to replace the joist.
  15. Nov 22, 2022 at 8:59 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    100%
  16. Nov 22, 2022 at 1:26 PM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Holy cow it’s a pt deck just shim it and move on
    If you were building it for somebody else it would be a different story lol then you’d want to replace it
    wilcam47, My Name is Rahl and Sig45 like this.
  17. Nov 22, 2022 at 3:20 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    Since it's already cut to length, can you just flip it over?
    My Name is Rahl likes this.
  18. Nov 22, 2022 at 3:20 PM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Does PEX pipes leaves a funny taste to the water?
    Someone told this was the only drawback.
  19. Nov 22, 2022 at 3:29 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    For a week or two after you install it, yes. Smells like gasoline too. It goes away the more you use it.
  20. Nov 22, 2022 at 3:29 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    My water is softened well water so it taste funny anyways, so I couldn't really tell you.
