Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Sep 9, 2014 at 8:33 PM
    #3001
    4lo
    4lo Well-Known Member
    El Campo, TX
    2017 TRD Sport
    some stuff
    Actually could be a possibility, wondering if the setup would defeat the overall goal though.
  2. Sep 9, 2014 at 8:37 PM
    #3002
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Seriously , a cut on each side , a couple in the middle and a chisel , easy
  3. Sep 9, 2014 at 8:40 PM
    #3003
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    ..any possibility of forming what appears to be half-lap channels/pockets by way of gluing up each workpiece w/ pre-cut segments to form the channels???...
  4. Sep 9, 2014 at 8:43 PM
    #3004
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    It's not...we put 10-12 cuts in the middle, you can't chisel because the chisel is going with grain and usually under or over cuts, you can see it on the face of the beams. So we side punch and rasp out the groove. I'm sure it's crazy overkill but that's what we do.
  5. Sep 9, 2014 at 8:46 PM
    #3005
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    wut?
  6. Sep 9, 2014 at 8:47 PM
    #3006
    OZ-T
    Peter North
    British Columbia
    I cut these kind of joints in fir timbers all the time , use a razor knife to scribe the cut line and avoid tear out , use the circular saw to cut most of the waste material , clean it up with a chisel , if your chisel is following the grain in pine it's not sharp
  7. Sep 9, 2014 at 8:51 PM
    #3007
    wileyC
    Centerville, OH
    ...well i'm making some assumptions based on what was posted a few posts up in this thread, ...appeared to be half-lap joints you are cutting in some large members that you are laminating multiple 2x4 stock to make?... all i'm saying is that you can form channels, mortices, w/out having to cut them, by doing the lamination in a way that forms the desired channels as desired... an example would be the top piece that gets glued on is cut into pieces and glued in at the proper intervals to form the desired channels...
  8. Sep 9, 2014 at 8:58 PM
    #3008
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    Dude! This is how this whole thing started was my question on a better solution than running a circular saw/chisel/rasp down the beam.
  9. Sep 9, 2014 at 9:01 PM
    #3009
    OZ-T
    Peter North
    British Columbia
    I answered your question
  10. Sep 9, 2014 at 9:03 PM
    #3010
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    Yep, the Skil 117 groover is key. Thank you sir.
  11. Sep 9, 2014 at 9:10 PM
    #3011
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    I don't use glue...
  12. Sep 9, 2014 at 9:12 PM
    #3012
    OZ-T
    Peter North
    British Columbia
    Found an expired Craigslist ad for one in San Diego , guy wanted $1000
  13. Sep 9, 2014 at 9:16 PM
    #3013
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    I'd say it's worth it, you really can't kill a worm drive. I've been looking all over and can't find one anywhere.
  14. Sep 9, 2014 at 10:04 PM
    #3014
    OZ-T
    Peter North
    British Columbia
    You probably won't either
  15. Sep 10, 2014 at 5:42 AM
    #3015
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    Please let me know if anyone ever sees a groover 177 for sale. In the meantime it seems plausible to fab one out of a mag 77... Far less demonic after seeing that skil actually made one.
  16. Sep 10, 2014 at 5:49 AM
    #3016
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    Take a picture next one you do. Chisel is great for with the grain .
  17. Sep 10, 2014 at 6:02 AM
    #3017
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    Will do. We are cutting a cedar pergola tomorrow or Friday in the field depending when lumber arrives.
  18. Sep 10, 2014 at 8:24 AM
    #3018
    OZ-T
    Peter North
    British Columbia
    Yeah , lets see pics
  19. Sep 10, 2014 at 10:22 AM
    #3019
    joshua721
    16 f150 xlt v6
    Took longer to post this
  20. Sep 10, 2014 at 10:24 AM
    #3020
    medic2230
    Murph
    Bama! Roll Tide
    ^^^Does your half lap line up smooth though?
