Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Dec 27, 2022 at 4:29 PM
    My Name is Rahl
    Hoping one of y'all can help me out. I'm looking for a radiant floor heating product I saw once on an episode of This Old House. It installed under the subfloor, from the underneath.
    Does anyone know who makes it?
    wilcam47 likes this.
  2. Dec 27, 2022 at 4:36 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    couple links down at end article. Has electric mat and water
    https://www.thisoldhouse.com/heating-cooling/21015149/radiant-floor-heating
  3. Dec 27, 2022 at 6:31 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Grouting tile takes a lot more effort than the youtube videos make it seem. Also, why is it that the small 1 qt buckets of premix don't allow you to fit a grout float in them? Im guessing whoever marketed that product never actually installed tile. Shoulve been a square bucket vs round.
  4. Dec 27, 2022 at 6:36 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I'm so cheap I would go with the stuff you gotta mix up with water. :anonymous:
    wilcam47 and Drainbung like this.
  5. Dec 27, 2022 at 6:38 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I didnt need much, two of the 1 qt buckets was the perfect amount. First time doing it so I figured the premix wouldnt allow me to screw up the consistency.
    jsi and Delta09[QUOTED] like this.
  6. Dec 27, 2022 at 8:36 PM
    My Name is Rahl
    wilcam47[QUOTED] likes this.
  7. Dec 29, 2022 at 2:56 PM
    TVphotog97
    TVphotog97 Well-Known Member
    Codie
    Upstate South Carolina
    2019 White Tacoma SR5
    A little bit of progress made on the house. Got the vapor barrier put down and also got all the rusty galvanized and corroded copper supply pipes replaced with Uponor and new shutoff valves. Rerouted the toilet supply lines thru the floor instead of the wall. Still have a good bit to do but this is a step in the right direction.
    0FA0FFA3-C7A3-40A3-B35C-D941FB48D75C.jpg EDA85650-FE76-4416-9ECA-EA8F476014CE.jpg A8FA712A-9989-4925-875A-ABB252C597B6.jpg
  8. Dec 29, 2022 at 4:01 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Vapour barrier looks good , not sure how far you're trying to go with it but if you want it to work 100% you should tape the seams and edges
  9. Dec 29, 2022 at 4:10 PM
    svendough
    svendough Well-Known Member
    Colorado
    2020 Cement DCSB OR
    Skinny rubber, Bilstein lift, iKamper
    Nice work. I need to put a vapor barrier down in our crawl space. Which is an actual "crawl" space, so I've been putting it off forever haha. Could I ask, what barrier did you use? I know next to nothing about vapor barriers.
  10. Dec 29, 2022 at 4:12 PM
    TVphotog97
    Codie
    The seams are mostly taped up but I do intend to go back and tape the edges
    OZ-T[QUOTED] likes this.
  11. Dec 29, 2022 at 4:23 PM
    TVphotog97
    Codie
    I’ll try to get the actual info for you tomorrow. But I do know it’s a 10mil vapor barrier
    shakerhood and svendough[QUOTED] like this.
  12. Jan 1, 2023 at 4:01 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
  13. Jan 1, 2023 at 6:46 PM
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    I love mine. Have used it for multiple jobs with several different varieties of tile including mesh backed mosaic, glass, and porcelain. Well constructed. I have not used it for stone. For that I have been using a grinder with a diamond blade.
    Blue92[QUOTED] likes this.
  14. Jan 2, 2023 at 1:13 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Ever so slightly seeing the light at the end of the tunnel. Got a coat of primer on the lowers yesterday and got a coat of paint on today. Also while I had the oil primer out I primed the ceiling to cover up the years of nicotine. My house stunk pretty damn bad after all that primer :laugh: Got the first coat of ceiling paint on today as well. They definitely changed the Benjamin Moore #258-01 Muresco Ceiling White. Not near as good as it used to be. I'd'a been better off with the contractor line of Valspar (2000?) at half the price. Oh well, lesson learned earlier on.
    Also picked up another set of saw horses so no more kneeling on the ground!
    Before putting the AC vent covers back on, they needed a coat of paint. You can see how nasty they were in this side by side.
    Second coat of paint on the lower cabinets and ceiling. Next weekend I hope to prime and paint the walls.
  15. Jan 2, 2023 at 1:54 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Built some shelving to consolidate most of my tools (close to the garage door).
    From This:
    To This:
  16. Jan 2, 2023 at 1:57 PM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Looking good, Mark!
    Must be easy to find things now.
  17. Jan 2, 2023 at 2:24 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    :thumbsup:
  18. Jan 2, 2023 at 3:20 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    nothing major, just got tired of looking at the spare bedroom as a junk collector.
    only took me 4 years to clean it up, unroll the rug, build the bed frame, and put sheets on the bed...
  19. Jan 2, 2023 at 8:48 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Working on the framing of another workbench, this one will be 16 feet long when finished.
  20. Jan 3, 2023 at 6:40 AM
    jsi
    jsi Well-Known Member
    native earthling
    If you're planning on doing a lot of jobs with it I'd spend the extra and get a sliding table model like this:
    https://www.lowes.com/pd/Kobalt-7-in-1-6-Wet-Tabletop-Sliding-Table-Tile-Saw-with-Stand/1000760328
    I'd buy the Kobalt over the Ridid because of the splash protection. Also not sure how thick stacked stone is so may not be an issue. My 7" saw struggled with 2" thick pavers. There just isn't enough blade to do the job. The thing about tile saws is once you have one jobs for it just seem to pop up.
