Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Feb 6, 2023 at 10:04 AM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Grammer nazi's evrywher.
  2. Feb 6, 2023 at 11:29 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    At the job we had a unit heater that hadn't been used in a few years and wouldn't run.
    Taking the vertical flue pipe apart there were 7 bird nests on top of each other.
    Every nest was filled with dead baby birds. Apparently the adult could get out but the little ones couldn't.
    Kind of creepy really...
    Mr Bird says to Mrs Bird "I found a great place to build a nest, don't mind the dead ones in the basement..."
  3. Feb 6, 2023 at 12:36 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Today we're prepping for the world's largest septic tank system installation
    MarX, soundman98, RustyGreen and 9 others like this.
  4. Feb 6, 2023 at 12:44 PM
    OZ-T
    Peter North
    British Columbia
    *grammar
  5. Feb 6, 2023 at 12:45 PM
    theesotericone
    Bishop CA
    I'm taking it you missed the sarcasm. lol
  6. Feb 6, 2023 at 12:51 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Two tanks? I guess they have to do things differently around the water there. Can't even imagine the cost. A 1,000 gallon tank with a sand mound drain field sets you back $35,000 - $40,000 around here o_O
  7. Feb 6, 2023 at 12:59 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Do GO on. Details?
    RustyGreen, Drainbung and Delta09 like this.
  8. Feb 6, 2023 at 1:00 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Wait, are we actually getting slightly excited learning about different septic systems? Sheesh, is this what being an adult is like? :rofl:
  9. Feb 6, 2023 at 1:02 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Big potty humor
  10. Feb 6, 2023 at 1:02 PM
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Those are spark arrestors. They get pretty cold — especially in high wind. It’s not uncommon for them to ice up or get clogged with creosote. My liner is squeaky clean but the arrestors have a bunch of creosote on them from the cold winds hitting the hot gases.
    Drainbung, Venom[QUOTED] and Pablo8 like this.
  11. Feb 6, 2023 at 1:40 PM
    OZ-T
    Peter North
    British Columbia
    its a Type 2 system which basically means you can use the end water as irrigation water , and the reason it is a Type 2 field is our proximity to the ocean for which we are actually closer than the current general setback requirement which meant we need a septic design engineer and a siting variance from our local jurisdiction for land use . The tanks are an 1100 gal primary two chamber tank that then sends the effluent to a further 1700 gal two chamber treatment / aerator tank before pumping to essentially infiltrators on a sand mound
  12. Feb 6, 2023 at 2:30 PM
    MGMDesertTaco
    okay, butt...
    *you're going backwards
    soundman98 likes this.
  13. Feb 6, 2023 at 2:34 PM
    MGMDesertTaco
  14. Feb 6, 2023 at 3:16 PM
    OZ-T
    Peter North
    British Columbia
    grammer vs contraction bro
    conjunction junction , whats your function?
  15. Feb 6, 2023 at 3:19 PM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    The boiler rep look at the boiler, tested everything. All seems good so far. :fingerscrossed:
    RustyGreen[QUOTED] likes this.
  16. Feb 6, 2023 at 3:24 PM
    Venom
    Kevin
    Massachusetts
    The chimney guy installed the cage to keep birds out. He went with round, instead of square due to winds.
    For this area, He replied this was the best option to go with.
    truchador[QUOTED] likes this.
  17. Feb 6, 2023 at 3:27 PM
    Venom
    Kevin
    Massachusetts
    Can I get creosote build up with natural gas? I thought burning wood with create creosote build up.
  18. Feb 6, 2023 at 3:31 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Jesus, that was one helluva flash back! o_O
    916carl, soundman98 and RustyGreen like this.
  19. Feb 6, 2023 at 3:35 PM
    kmorgan3
    Kyle
    PNW
    No it's just an extra narrative to let you know the arrestors get cold relative to the liner. I have virtually no build up in my liner, but my spark arrestors and flue cap have a pretty disgusting amount of build up. It tells you there's a huge temperature differential just within a few inches of the opening. Very common.
    Venom[QUOTED] likes this.
  20. Feb 6, 2023 at 3:37 PM
    TinoTaco
    TinoTaco Well-Known Member
    Nanaimo
    2017 TRD DCSB Off-Road - White
    Sorry, I had to...
    soundman98, RustyGreen and Delta09 like this.
