Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Feb 11, 2023 at 6:25 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
  2. Feb 11, 2023 at 6:36 PM
    daveeasa
    David
    PNW
    Ok, rats, that mag solution rules but what it’s missing is the primary goal of pushing the dryer back towards the wall. I’ll have to do a box in the stud bay somehow. Unclear which of the two options to buy, wish they had clear photos of what each kit includes.
    Ah but only the 180 in stock anyway so we will see what that looks like. I may order an in wall recessed kit as well and see if I can marry all that up.
  3. Feb 11, 2023 at 8:10 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    the MV-90 could be in-wall mounted , where does your dryer vent go , straight through the wall behind or no ?
  4. Feb 11, 2023 at 8:11 PM
    daveeasa
    David
    PNW
  5. Feb 11, 2023 at 8:12 PM
    OZ-T
    Peter North
    British Columbia
    What route does your venting take once it exits the dryer ?
  6. Feb 11, 2023 at 8:14 PM
    daveeasa
    David
    PNW
    Down through the stud bay into the crawlspace. Across the width of the kitchen to the exterior wall through the siding just above the footing through a vent.
    we are likely removing all the ceiling drywall but don’t relish cutting 4” holes in a ton of floor joists.
    Dryer vent stud bay has no plumbing or electrical, and it’s interior so no insulation.
    I could get better photos.
  7. Feb 11, 2023 at 8:25 PM
    OZ-T
    Peter North
    British Columbia
    can you not install a 4" elbow in the wall at dryer vent height ?
  8. Feb 11, 2023 at 8:35 PM
    daveeasa
    David
    PNW
    That’s what we have. Want to stuff the dryer as close to the wall as possible. We have the XXXXL ones from LG which can fit a large bear and a few cubs.
  9. Feb 11, 2023 at 8:53 PM
    TwistedTLM4
    TwistedTLM4 Unknown Member
    Philadelphia, PA
    '05 DCSB TRD Sport
    WeatherTech Floor Mats, WeatherTech Bug Shield and Vent Visors, Audio Upgrade, RaamAudio RaamMat & Ensolite, Mr. Marv's Custom 10" Sub Enclosure, Pop N Lock Electronic Tailgate Lock, mattgecko's Bedlights, Demello Offroad Single Hoop Bumper, Marathon Seat Covers, Leer Topper, OME885s on 5100s, @Blackout14 HD Leaf Pack
    I've used this on the last couple laundry hookups. Great product.
    https://www.amazon.com/Gardus-DVME-Dryer-Vent-White/dp/B07NB8T34Y
    RustyGreen likes this.
  10. Feb 11, 2023 at 9:16 PM
    OZ-T
    Peter North
    British Columbia
    i mean have the elbow in the wall cavity , can't get much closer than flush to wall
  11. Feb 11, 2023 at 9:20 PM
    OZ-T
    Peter North
    British Columbia
    RustyGreen, truchador and dumontrider like this.
  12. Feb 11, 2023 at 9:28 PM
    daveeasa
    David
    PNW
    Doesn’t look like that helps with space between dryer and wall much. I like the magnetic coupler the best, kind of annoying to have to install an in wall for one dryer which might be off for a new dryer.
  13. Feb 11, 2023 at 9:29 PM
    daveeasa
    David
    PNW
    Yeah, exactly, just that most are set up to feed up rather than down and 2x4 can’t do 4” ducting in that cavity.
  14. Feb 11, 2023 at 9:31 PM
    daveeasa
    David
    PNW
    That looks good. I’ll confirm 14” tomorrow. It might be a slim bay. Thanks. That might still work with the mag.
  15. Feb 11, 2023 at 9:32 PM
    TwistedTLM4
    Philadelphia, PA
    '05 DCSB TRD Sport
    Perhaps you misread the instructions. This allows for the dryer to be tight to the wall. The gray piece connects to the dryer and slides inside the wall mounted apparatus/elbow.
  16. Feb 11, 2023 at 9:38 PM
    daveeasa
    David
    PNW
    Pretty big grey piece straight pipe per the video. For a 2x4 wall I don’t see how it improves much vs a short coil of flex. Would be great if their video actually showed the dryer hookup part. Kind of massive failure in that regard, leaving out the most important part.
    but more to the point, this is another up rather than down solution. Which works great for an upward vent. Mine happens to be down. Which could potentially be changed but down seems preferable as crawlspace access is good.
    also, I’ll add that this specific solution kills the add / remove of pedestal. Not really ideal to future proof for the next dryer one might buy. Sub optimal in terms of flexibility down the road.
    thinking more about my specific situation, the other side of the wall is a double oven which I assume will have a drawer below it. I may be able to have the flange in the stud bay and elbow through the floor on the kitchen side of the wall. Then just block it out and drywall the box. I’ll have to locate and inspect the oven cabinet to see how much room I have to play with.
    Not sure there is any code in the way of this plan. Seems above board.
  17. Feb 11, 2023 at 9:53 PM
    OZ-T
    Peter North
    British Columbia
    you can get round to oval elbows
  18. Feb 11, 2023 at 10:00 PM
    daveeasa
    David
    PNW
    Yeah, just tight w downward vent. Not much room for an elbow without a pedestal and we don’t currently have those. Could do a side 90 but 16” for two 90’s is tight.
    The mag is killer, I have hopes of being able to use that. Great idea.
    shakerhood likes this.
  19. Feb 11, 2023 at 10:06 PM
    OZ-T
    Peter North
    British Columbia
    The Mag Vent is awesome , not sure you will be able to combine a MV-180 with s Dryerbox though
  20. Feb 11, 2023 at 10:17 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
