Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Feb 14, 2023 at 10:30 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You can drill the middle third in most cases
    shakerhood likes this.
  2. Feb 14, 2023 at 10:31 PM
    OZ-T
    Peter North
    British Columbia
    is that copper supply running parallel to the abs line notched into the face of the studs ?
  3. Feb 15, 2023 at 12:46 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  4. Feb 15, 2023 at 1:25 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Supply work happens today. Not sure what the plan is for it but I’d assumed intent is through the joists or studs. Plumber bought pex so I’m betting joists since it can work around the ducting.
    supply is not currently notched, it was inside the soffit.
  5. Feb 15, 2023 at 2:38 AM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Pouring a little concrete this morning.
  6. Feb 15, 2023 at 4:31 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Holy fo shizzle
    shakerhood, Delta09 and RustyGreen like this.
  7. Feb 15, 2023 at 4:40 AM
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    I always used the crimps with good success, but have no experience with clamps but expect they work fine also
    TnShooter[QUOTED] likes this.
  8. Feb 15, 2023 at 4:46 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    I used the clamps over 10 years ago, no issues yet.
  9. Feb 15, 2023 at 7:01 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I use the clamps. They're easier to use in tighter areas, which if you're working in an old house, run in to all the time. I've used a couple Sharkbite's over the years, but prefer to solder on a fitting to transition. Reminds me, I had to use one SB 3/4 tee when I installed my water heater as nobody had 3/4" PEX tee's at the time. Still need to swap that out...
  10. Feb 15, 2023 at 7:08 AM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Going through the process of window quotes. 7 windows in the front of the house to replace. Awning style. Single pane currently and terribly inefficient. Can’t close well or seal.
    Quoted from Renewal by Andersen and Window World so far.
    Window brand preferences? Window world has their own brand and Andersen uses their product of course. Looks like Pella and Marvin are big brands local to me at least too.
  11. Feb 15, 2023 at 8:58 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Wow, what is this place? Are all those conduits getting buried in concrete?
  12. Feb 15, 2023 at 9:04 AM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    (2) 8 story apartment buildings, (1) 6 story, 1st flr retail, 5 flrs above apartments, (1) recreation building w/ pool
    They're all PT slabs so you can shove a shit ton of conduit in the slabs. Pretty crazy amount of electrical in there though, I agree.
  13. Feb 15, 2023 at 9:47 AM
    daveeasa
    David
    PNW
    Just spoked with my plumber, he's not remotely concerned about the wall. Not even a little bit.
  14. Feb 15, 2023 at 9:55 AM
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
    Square D the only way to go for me. Over 45 years of installs, not one failure for both QO and Homeline.
    jubei, shakerhood and Delta09 like this.
  15. Feb 15, 2023 at 9:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    That's because he's a plumber.
  16. Feb 15, 2023 at 9:58 AM
    daveeasa
    David
    PNW
    It's interesting how people can give no f's about stuff sometimes :)
    Anyway, I did convince him to give me a separate water hookup for the steam for my dryer, that'll simplify the rats nest of T's in the back for us.
  17. Feb 15, 2023 at 10:03 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Cool that's he is a structural, civil and materials engineer. You don't find many with PE's that are also licensed in your same state. And do plumbing.
  18. Feb 15, 2023 at 10:09 AM
    daveeasa
    David
    PNW
    Yeah, I think I have to tread lightly on this b/c he's the GC's pal and they are both super old school. Says he always goes studs over joists. I think he'll do some nailers and then what I will try to do is swap those out for stud shoes in the dark of night and assume the GC won't know the difference. And/or discuss with the GC after the fact. I just found it interesting how little concern he had after my research last night on 40% single and 60% double stud code stuff and the 2 stud rule. I think we probably should have done one more joist since they don't go the full length due the light box until the double one bay over, but what's done is done drain-wise. So I'll try to do what I can with the GC once these guys are complete with the supply stuff.
    In the meantime, 7 more quarter turn angle stops to swap out now that water is off.
    theesotericone likes this.
  19. Feb 15, 2023 at 10:13 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    PNW?
    WA - you would need a structural buy off on the plans, I would think. You or GC pulled a permit, I assume? Or all stayed at simple remodel level?
    OR - ?
    ID - ?
    Toyko Joe likes this.
  20. Feb 15, 2023 at 11:15 AM
    MGMDesertTaco
    Not sure if this qualifies as home improvement related, but I'll ask anyway. I want to replace a couple of mattresses and with Presidents Day around the corner sales should be popping up. Any recommendations or brands worth looking into? Thinking about one of those fancy ones that adjusts. :yawn:
