Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Feb 15, 2023 at 11:47 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    If you can, find a real salesman who actually knows what he is selling.
    We bought one about 5 years ago, the salesman was in his 70's. He asked questions and came up with a list of ones to test out in the store.
    Ultimately he steered us towards a middle priced mattress, not the most expensive one.
    If you and your sleeping partner are of significantly different weight or softness preference it is tougher, a good salesman can help.
  2. Feb 15, 2023 at 2:22 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    My wife and I have been on a Tempur Pedic for over 15 years and we love it.
    Pablo8 and MGMDesertTaco[QUOTED] like this.
  3. Feb 15, 2023 at 3:30 PM
    jsi
    jsi Well-Known Member
    native earthling
    If I was going to start over I'd go with the clamp style. Seems like 70% of my crimps are in awkward places that the tool won't fit in. I think the clamp style might be easier to use.
    (side note - the hack plumber that did the pex in my house apparently couldn't be bothered with doing the crimps correctly. I've found crimps where 50% of the ring wasn't in the tool, crimps where the tool wasn't 90 degrees to the PEX and lord only knows what is buried in the walls, but not a single leak or problem, so far.)
    TnShooter[QUOTED] likes this.
  4. Feb 15, 2023 at 3:50 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Thanks for the info.
    The kit came with a Go/No-Go gauge.
    Which was one of the reasons I got the crimp kit over the clamp.
    The clamp just came with a clamper only.
    And of course, neither Lowes or Home Depot has the gauge to buy separately.
    I’ve been reading and studying on the proper use and installation.
    Kind of odd that all the instructions say “If the Go gauge fits at any one spot, the connection is secure.
    If yours have one spot that the gauge fits, I guess you are ok?
  5. Feb 15, 2023 at 5:46 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    well that's a relief
    Drainbung likes this.
  6. Feb 15, 2023 at 5:58 PM
    OZ-T
    Peter North
    British Columbia
    Passed our structural engineer's rebar inspection for our Phase 2 footings today , building department inspection scheduled for tomorrow , pour concrete Friday
  7. Feb 15, 2023 at 6:10 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    Damn it Peter, I can’t get people who lay concrete for a living to do it right and here you are… :bananadead:
    Sig45 likes this.
  8. Feb 16, 2023 at 9:06 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Short day. Got the fridge panel installed. First time installing just a plain 3/4" plywood panel. Others have all had a narrow face frame attached. Had to scribe for a noticeable hump in the drywall right near the switch box. Came out nice. Used the cutoff piece from the tall filler strip as a cleat along the inside edge. No studs so I used wall anchors. Hit the screw heads with a sharpie. Did get a screw in the bottom plate. Pinned the panel along the back edge with some 2" brads. Toenailed a trim-head screw in the front edge. Feels nice and secure. Also cut the back panel and corner trim for the island (I'll glue/install that tomorrow) and applied silicone (per flooring instructions) along the edges of the floor. I'll start on other limited trim tomorrow. May pre-cut all of the custom toe kicks so all surfaces can be stained. Customer stil hasn't made a decision on hardware.
    shakerhood, Delta09, Clark27 and 7 others like this.
  9. Feb 16, 2023 at 9:07 AM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    And every piece of rebar has caps on it. Even the horizontal ones. Try getting a mexican crew to do that. :facepalm:
  10. Feb 16, 2023 at 11:09 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    So, spitballing with tonered and he said I might be able to do 2x4's (I think 2x6 for the double overlaps) under each joist along that wall. Contemplating that option as I order up some stud shoes. I do appreciate your eye and @theesotericone 's help and suggestions.
    theesotericone likes this.
  11. Feb 16, 2023 at 1:17 PM
    OZ-T
    Peter North
    British Columbia
    More foundation repairs at the resurrection
    Not sure how you pour a foundation wall that goes up and down 1 5/8" but apparently its possible lol
    we've formed a level height , cut off the old anchor bolts , ground and cleaned the surface , drilled and epoxied in new redi rod for anchor bolts and seismic hold downs and are adding a grouting mixture to level for our wall sole plate
  12. Feb 16, 2023 at 1:27 PM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    What are you using for grouting your sole plate level? Ardex or something like that? Looks like your going from nothing to an 1" to 1 1/2". Just wondering what your plan is to keep it from flaking off where it gets real thin.
  13. Feb 16, 2023 at 1:29 PM
    OZ-T
    Peter North
    British Columbia
    Portland non ferrous expanding grout with a bonding agent
  14. Feb 16, 2023 at 1:34 PM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Figured there would be a bonding agent in there. Sink some tapcons and leave the heads up to 1/2" below your top of level grout as "mini rebar" anchors, helps to hold that grout in place along with your bonding agent.
  15. Feb 16, 2023 at 3:33 PM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Looking good, Mark!
    Sig45[QUOTED] likes this.
  16. Feb 16, 2023 at 5:06 PM
    daveeasa
    David
    PNW
    Mag vent looks awesome. Super beefy. Instructions say to make sure dryer is aligned but that’s my trouble. Stud in the way. Do I kingstud the mofo while I have the wall open? But electrical and now steam water are right there so kinda screwed on alignment. Floor vent for the win?
    D2BCC93B-CF3D-474B-B803-84EA9AC662FD.jpg B477EE7F-7564-431E-8759-8352DDCAE6C7.jpg
    ignore the Halloween glow sticks which subsequently spilled on the floor as I tried to retrieve them.
    shakerhood likes this.
  17. Feb 16, 2023 at 6:39 PM
    OZ-T
    Peter North
    British Columbia
    IIRC you can be up to 2" off centre with the MV-180
  18. Feb 16, 2023 at 6:54 PM
    daveeasa
    David
    PNW
    Yeah, and my setup is about 3-4" off center with a wall preventing me from moving the dryer over (unless I can convince my wife to let me demo the closet and stuff in a 4th toilet someday).
    Or maybe the dryer is 6-8" too wide, hah. Definitely true, had to take the door off to get it in the laundry room.
    I think that's the primary reason why it sticks out as much as it does, the kink in the exhaust. Hence a bottom vent might be stealthy.
  19. Feb 16, 2023 at 7:51 PM
    TwistedTLM4
    TwistedTLM4 Unknown Member
    Philadelphia, PA
    '05 DCSB TRD Sport
    WeatherTech Floor Mats, WeatherTech Bug Shield and Vent Visors, Audio Upgrade, RaamAudio RaamMat & Ensolite, Mr. Marv's Custom 10" Sub Enclosure, Pop N Lock Electronic Tailgate Lock, mattgecko's Bedlights, Demello Offroad Single Hoop Bumper, Marathon Seat Covers, Leer Topper, OME885s on 5100s, @Blackout14 HD Leaf Pack
    Do what your plumber did and just cut the stud out....:D
  20. Feb 16, 2023 at 8:30 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    and when you run for coffee later, ask the starbucks barista to confirm the joist load calculations your plumber ran.
