Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jun 14, 2023 at 7:13 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    IMG_4865.jpg IMG_4864.jpg Final coat tomorrow
  2. Jun 15, 2023 at 3:04 AM
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    I posted pics of my deck project a month or so ago. Just finished (mostly) painting everything.
  3. Jun 15, 2023 at 5:07 AM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    Black spindles look great. Was that a kit or something you did yourself? Thinking about doing something similar to my deck
  4. Jun 15, 2023 at 6:19 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    F79EAF3A-F2C5-48D3-9853-C680E73D218B.jpg 3CA1A79A-8994-456B-8AFA-0CFBD5931C87.jpg BD646DB3-55CE-4D19-8627-EBCF3B0D0ED9.jpg BD646DB3-55CE-4D19-8627-EBCF3B0D0ED9.jpg A91D96D1-F486-49E6-8DF5-6B0E22D78A7F.jpg 0FD740B7-837F-482B-8EAD-2485271D1A85.jpg 4DB61D87-E3A3-43CD-BFEA-808D3682607D.jpg E1229627-A6D3-4020-B371-39854EB4F71C.jpg F79EAF3A-F2C5-48D3-9853-C680E73D218B.jpg E1229627-A6D3-4020-B371-39854EB4F71C.jpg 4DB61D87-E3A3-43CD-BFEA-808D3682607D.jpg 0FD740B7-837F-482B-8EAD-2485271D1A85.jpg A91D96D1-F486-49E6-8DF5-6B0E22D78A7F.jpg BD646DB3-55CE-4D19-8627-EBCF3B0D0ED9.jpg 3CA1A79A-8994-456B-8AFA-0CFBD5931C87.jpg F79EAF3A-F2C5-48D3-9853-C680E73D218B.jpg E1229627-A6D3-4020-B371-39854EB4F71C.jpg 4DB61D87-E3A3-43CD-BFEA-808D3682607D.jpg 0FD740B7-837F-482B-8EAD-2485271D1A85.jpg A91D96D1-F486-49E6-8DF5-6B0E22D78A7F.jpg BD646DB3-55CE-4D19-8627-EBCF3B0D0ED9.jpg 3CA1A79A-8994-456B-8AFA-0CFBD5931C87.jpg Out with the pine straw and in with 2-4 rocks…..F79EAF3A-F2C5-48D3-9853-C680E73D218B.jpgE1229627-A6D3-4020-B371-39854EB4F71C.jpg4DB61D87-E3A3-43CD-BFEA-808D3682607D.jpg0FD740B7-837F-482B-8EAD-2485271D1A85.jpgA91D96D1-F486-49E6-8DF5-6B0E22D78A7F.jpgBD646DB3-55CE-4D19-8627-EBCF3B0D0ED9.jpg3CA1A79A-8994-456B-8AFA-0CFBD5931C87.jpg
    Sig45, MGMDesertTaco, mbarbay and 4 others like this.
  5. Jun 15, 2023 at 6:25 AM
    Bagman
    Area 51
    Did it myself. Here's the video I used that showed me how.
    https://www.youtube.com/watch?v=w62A0bW2ZoY
    Drainbung and williams63[QUOTED] like this.
  6. Jun 15, 2023 at 6:40 AM
    Bagman
    Area 51
    Another view in progress
  7. Jun 15, 2023 at 6:55 AM
    Bagman
    Area 51
    Drainbung likes this.
  8. Jun 15, 2023 at 8:45 AM
    MGMDesertTaco
    You could almost jump into the pool from up top. ;)
  9. Jun 15, 2023 at 8:50 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    My 'puter is now broked bro :D:p:dancingbacon:
  10. Jun 15, 2023 at 9:07 AM
    jsi
    jsi Well-Known Member
    native earthling
    That looks good.
    daveeasa[QUOTED] likes this.
  11. Jun 15, 2023 at 9:32 AM
    Bagman
    Area 51
    I'm way too old for that *hit...
    It would be close...
  12. Jun 15, 2023 at 9:32 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Ladder to the roof then deep end.
    MGMDesertTaco and Drainbung like this.
  13. Jun 15, 2023 at 11:29 AM
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Dirt work is done for now. We'll get the track loader back in probably next year to clean up; mess with grades, terrace our yard for more raised beds, narrow-up the gravel, re-rock, etc.
    Made a little platform with a ramp going to the platform and up to the grass for my shed I'll build next summer after the shop is done. Got the drainage right so everything slopes away from the shed and toward the woods. It's good to let the ground settle before I build that shed; give it a good year and I won't need to mess with compaction much.
    There's a little V-notch coming off the shed platform where built a solid drain pipe that is going to pump-out all of the water from behind the retaining wall. Just so everyone knows... 3" PVC is expensive as hell. You can see it sticking out closer to the camera and it comes out the other side of the hill. That piece next to the camera is going to connect to a flex pipe.
    Hey my glue job wasn't too bad! You can see in the background how the track loader put a lot of the fill against the shop; previously it was cut out waaaaay too deep. So much that the shop had exposed footings... previous owner didn't really know what he was doing. So now it's nice and braced against some earth.
    To finish up there was a lot of work to be done to get the retaining wall prepped. First had to remove 6" of soil, and then back-fill with 4" of 3/4" minus and tamp the crap out of it. Then filled another 2" of fine 1/4" minus and tamped that as well. The base is like concrete. I worked with them to get it level; it's pretty close. I'd say maybe 1/4 - 1/2" across the 85 feet of compacted footing so I'll need to throw some sand here and there under the first block course. The wall will sit 4' off the face of the foundation stem wall and will be 4' high at the tallest point.
    A keen eye can probably see the little channel dug into the back of the base; that's where my flex pipe is going to go below grade. Eventually, when the wall is finished, I will be back-filling the space between the wall and the building with another 2" of 1/4 minus to lock the wall in place, and I'll slope the rock back toward the wall a bit. That way anything that drips off the roof will run into the ground and to the drain pipe just like anything coming off of the hill will do the same thing. Typically you put those drain pipes right at grade, but with this setup we can catch water from building (if any).
    We'll put a fabric between the native soil and drape it under the drain pipe after I get the first course in, and then we'll back-fill with 3/4 clean rock and tamp it, working our way up course by course back-filling every couple of courses.
    Under the walkway is my electrical conduit I had to finish; I think I used all 360 degrees of directional changes I was allotted :bananadead:. Anyway at least it's in there. Finishing framing of the front gable today or tomorrow and then pouring concrete in the shop first thing Monday morning. While it's curing I'll have some time to stack blocks.
  14. Jun 15, 2023 at 11:57 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Finally got and appointment with Best Rooter…….July 18!
    I did ascertain a direction and it looks to go DEEP
    Could not locate on other side of sidewalk
  15. Jun 15, 2023 at 12:22 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    try buying 6" perforated pvc lol
    Nice progress
    Drainbung and kmorgan3[QUOTED] like this.
  16. Jun 15, 2023 at 5:38 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Painters, I would like your opinion. I will be getting some exterior, semi gloss for some trim.
    Lowe's has Valspar and HGTV Home by Sherwin Williams.
    Both are offered in 3 grades, I would buy the middle or top one, the Vlaspar is a bit cheaper across the board.
    Experience/opinions please.
    shakerhood likes this.
  17. Jun 15, 2023 at 5:39 PM
    MGMDesertTaco
    So, I've been shopping for a pool table the past few weeks and have been shocked by the extensive markup on these things. I wanted a slate table that had the ability to upgrade parts in the future if needed. Most local shops were $5k-$7k for something 8ft, slate, solid wood and new. Craigs Billiards in Scottsdale (Craig Connelly) builds some really awesome custom tables in any kind of style/wood/sight option you want, but they start at $16,000. :eek:
    Not wanting to spend that I started looking for used. I stumbled across this old Hugh Hefner special on craigslist for $700. It's an 8ft slate Connelly Tucson. I'm having a local shop pick it up next week, deliver it to my house and put some new felt on it. :burp:
  18. Jun 15, 2023 at 5:42 PM
    MGMDesertTaco
    I've used Sherwin Williams satin Super paint on the interior and Duration flat on the exterior. Very high quality stuff. HGTV Sherwin Williams in the garage and closets in flat, meh quality, but gets the job done. Valspar has some nice primer for not a lot a Lowes. I'd probably opt for the Valspar over the HGTV Sherwin Williams.
    The box store Sherwin Williams stuff isn't all that great tbh.
  19. Jun 15, 2023 at 5:43 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Refurbished vintage beats new in my book, you will be money ahead too. :thumbsup:
    Looks great, are you going with the traditional green felt?
  20. Jun 15, 2023 at 5:45 PM
    MGMDesertTaco
    I was leaning towards championship blue or maybe a light grey. :notsure:
