Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Aug 9, 2023 at 10:37 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Thanks.
    No cares for the "lawn". Ima try. If cracks - well then will redo. 4 feet down and mucho wide by hand, doable but damn
    You are a long ass way away :D, no worries full state height of WA plus.
    daveeasa likes this.
  2. Aug 9, 2023 at 7:56 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I foresee oval ASTM 4" PVC pipe and Fernco fittings in your future lol
  3. Aug 9, 2023 at 8:31 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Unknown until four feet down!
    shakerhood likes this.
  4. Aug 13, 2023 at 8:00 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have a question if anyone can share the knowledge. Needing to run a wire through cinder blocks, is it better to drill the hole through the mortar or through the block?
  5. Aug 13, 2023 at 8:04 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Id go through block.
    shakerhood[QUOTED] likes this.
  6. Aug 13, 2023 at 8:07 PM
    shakerhood
    Southern Ohio
    That is my plan, but figured it was smart to ask beforehand.
    wilcam47[QUOTED] likes this.
  7. Aug 13, 2023 at 8:27 PM
    MGMDesertTaco
    Milwaukee "hammer shockwave" masonry drill bits work well for that.
  8. Aug 13, 2023 at 8:57 PM
    tuktoyaktuktoyota
    tuktoyaktuktoyota Well-Known Member
    Jim
    NE Alberta
    04Silverado
    Quick easy project finished today. I live in a small 60yr old house, no handrail on stairs. Never been an issue until my Mom who hasn't traveled much since before covid agreed to come for a visit. She's 90 and insisted in sleeping in a basement bedroom!
  9. Aug 13, 2023 at 9:23 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    Nice clean lines! Has the home ever been sold with the missing handrails? Down here in the States I don’t think very many of the 50 states would allow that to be sold without an essential safety item (I’m not sure but there’s probably some southern states that DGAF).
  10. Aug 14, 2023 at 7:11 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Wyoming doesnt care lol. The home we bought, the two stairs didn't really have handrails. Downstairs none at all...upstairs has one for like half of it. The inspector noted it as a "not to current code but code at time of building" pretty much
  11. Aug 14, 2023 at 8:09 PM
    tuktoyaktuktoyota
    Jim
    NE Alberta
    04Silverado
    Thanks! I bought the house 38 years ago, pretty sure it wasn't inspected then. It would probably fail inspection today with no handrail in Alberta.
    dumontrider[QUOTED] likes this.
  12. Aug 19, 2023 at 4:55 PM
    OZ-T
    Peter North
    British Columbia
    Plumber is almost done his rough in work , electricians start Mon
    We're starting timber work for covered deck this week
    Going to be a nice kitchen / dining / living space
  13. Aug 20, 2023 at 7:24 AM
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    Agreed. I would fill the void with spray can expanding foam before running the pipe thru it
  14. Aug 20, 2023 at 7:29 AM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    I’m guessing with regulations they can drop that single tree in their view line?
  15. Aug 20, 2023 at 9:49 AM
    OZ-T
    Peter North
    British Columbia
    No , part of the siting variance and the geotechnical report is retain all natural vegetation in the area between the house and natural boundary of the ocean
    there are more trees to the right of that pic too , none of them hurt the view in my opinion
    MGMDesertTaco, wmb67 and Pablo8 like this.
  16. Aug 21, 2023 at 9:14 AM
    TinoTaco
    TinoTaco Well-Known Member
    Nanaimo
    2017 TRD DCSB Off-Road - White
    I like how you're so forward thinking you've already installed the custom kitchen island garbage can. Nice modern industrial vibe to it :D
  17. Aug 21, 2023 at 10:01 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Hahaha
    I was just thinking about throwing a rough slab across there and having a drink!
    Delta09, Drainbung and shakerhood like this.
  18. Aug 21, 2023 at 10:58 AM
    soggyBottom
    soggyBottom Well-Known Member
    I'm adding some shelfs in the garage. I would rather hang them than use posts sitting on the ground or 45deg braces on the wall behind them. The black arrow is pointing to 1 of the 2x4 beams in the ceiling. What is a decent way to attach the vertical 4x4 to that beam? I can brace the beam if needed but I don't think it will be since it's so close to the end.
    The small gap between them is for the 5/8" ceiling drywall.
    shakerhood and Pablo8 like this.
  19. Aug 21, 2023 at 4:28 PM
    TinoTaco
    Nanaimo
    If you're willing to cut into the drywall, I'd try notching the 4x4 so you have more surface area to glue/screw the 4x4 to the rafter. That should make a pretty strong connection. It's probably not to code, and I wouldn't be putting spare transmissions on it but it should be pretty strong.
    soggyBottom[QUOTED] and daveeasa like this.
  20. Aug 21, 2023 at 4:37 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    How much mass on the shelves?
    At my last house I did nearly the same but with chains instead of 4x4's - to hold up the hanging mass so to speak. I'm not sure why you would need 4x4s unless you are storing your tungsten stash up there.
    EDIT PS I first put up a strong 2x ledger double lagged to every stud, then made and attached the structure for my shelving. I attached that to the ledger and it was actually pretty strong cantilevered, so I covered it with 3/4 plywood, then finally put the chains up (stout chain) in eye bolts through doubled up 2x6 laying over the rafters. Stored ALL our seasonal garbage up there. Christmas lights were the only thing with much mass.
