Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Aug 21, 2023 at 5:02 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    shakerhood likes this.
  2. Aug 21, 2023 at 6:08 PM
    soggyBottom
    soggyBottom Well-Known Member
    daveeasa[QUOTED] likes this.
  3. Aug 21, 2023 at 6:31 PM
    soggyBottom
    My original idea was to cut a 1.5" slot in the 4x4 to fit the upper beam in it. Finally I was going to run a bolt through the side. I think you're right about the 4x4 being overkill
  4. Aug 21, 2023 at 6:52 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Plumbers!!
    Anyone good at drawing up connections to an easily accessible 4" main? I've done plenty of simple plumbing like PEx and PVC drain runs but never a connection to a main. If I post pics can someone help out? I need to connect a toilet flange to the main about 2 foot below in the basement and bathroom sink and shower drain run. Thanks!
  5. Aug 21, 2023 at 7:10 PM
    TwistedTLM4
    TwistedTLM4 Unknown Member
    Philadelphia, PA
    '05 DCSB TRD Sport
    WeatherTech Floor Mats, WeatherTech Bug Shield and Vent Visors, Audio Upgrade, RaamAudio RaamMat & Ensolite, Mr. Marv's Custom 10" Sub Enclosure, Pop N Lock Electronic Tailgate Lock, mattgecko's Bedlights, Demello Offroad Single Hoop Bumper, Marathon Seat Covers, Leer Topper, OME885s on 5100s, @Blackout14 HD Leaf Pack
    Post pics.
    stevesnj[QUOTED] likes this.
  6. Aug 21, 2023 at 7:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    we're going for a steampunk modern retro feel
    soundman98 and TinoTaco[QUOTED] like this.
  7. Aug 21, 2023 at 8:12 PM
    soggyBottom
    Do you also live in a clock?
    soundman98 and Pablo8 like this.
  8. Aug 21, 2023 at 8:39 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Do any of y’all have experience with manual J calc software? My brother in law and I are shopping around for software to run Manual J, Manual D, and possibly Manual S calcs.
    I’ve been looking at the ones that are “ACCA approved” but wasn’t sure which one to go with since we haven’t been hands on with any of them.
  9. Aug 22, 2023 at 7:01 AM
    98tacoma27
    Ben
    Not Beech Creek
    I would consider All thread (threaded rod).
  10. Aug 22, 2023 at 7:04 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    And bigass warshers.
  11. Aug 22, 2023 at 10:08 AM
    soggyBottom
    I like this idea. $2.50 for a 36" rod of 1/4" that is rated for 900lbs
    Pablo8 likes this.
  12. Aug 22, 2023 at 5:39 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Google "vertical sammys 3/8". 2400 lb rating. 3/8 isn't really needed for the weight you plan to hold but it doesn't mover as much as 1/4".
    soundman98, tacoma_ca and Pablo8 like this.
  13. Aug 22, 2023 at 10:53 PM
    MGMDesertTaco
    If I understand correctly,
    When I did mine I did a 2x4 flat flush with the ceiling with several lag screws and washers. Ran vertical 2x4's down from there and then built out the bottom and rest of the shelving. Connected to another 2x4 screwed into the studs of the wall. I can post pics, but won't be until the end of the month. I'm up in the mountains and at the lake. :drunk:
  14. Aug 22, 2023 at 10:57 PM
    MGMDesertTaco
    edit:
    really old picture, but you get the idea...
  15. Aug 23, 2023 at 10:26 AM
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Lots of progress! I made a big paper advertisement for Lowe's using the side of my building:
    Then I hung my first door that went surprisingly well. I decided against running windows along the sides of the building so that I have more wall space. This means the door(s) needed windows.
    Then I installed my 2 windows in the rear gable -- it was nice to look at something other than OSB or raw wood for a change:
    Next I started on a solo siding install. That was a major pain in the butt and I ended up phoning a friend after I did this entire side. The panels were deceivingly awkward to hang at the right height. I used CA glue and a block of wood adhered to the concrete as my helping hand. That only worked so well. After a full bottle of glue I was over it.
    With the siding on I was able to work with the electricians to get my 100A sub panel installed. It went really well; the conduit was oversized for the cable, so the 175' run was actually done by hand without a tugger or anything special.
    With the service in and the siding on, it was time for what my dad calls "fluff and buff" -- which is essentially the finish work to make all of your corner cutting look intentional. I tracked-sawed the siding to a better height in some areas (the corner caps just looked better that way), installed all of my trim on the corners, the 1x2's along the edges, and finally the garage opening.
    Today I met with the garage door guy and we ordered-up a nice 18x7 garage door that will get installed in 2 weeks to fully dry-in the shop!
    What's left:
    • Finish drain in the back of the building -- I installed my downspouts yesterday but just need to dig the drain
    • Install exterior lighting
    • Scrape-down bubbled old paint
    • Caulk (oh so much caulk)
    • Paint
    Current mood:
  16. Aug 23, 2023 at 10:56 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Your helper looks all tired out!
  17. Aug 23, 2023 at 4:28 PM
    stevesnj
    K, will do later tonight or tomorrow. This bathroom renovation stuff take up my time. lol
  18. Aug 23, 2023 at 5:53 PM
    OZ-T
    Peter North
    British Columbia
    Started cutting & prepping our 8x8 fir posts and 6x12 fir beams for our timber covered deck section Monday
    Cartolomew made an appearance
    Flew the first section in today
    Post to beam connection is a bridle joint with concealed 5/8" x 18" lag connectors
    Posts sit on custom knife plates we cast into the foundation
  19. Aug 23, 2023 at 6:06 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    I can't even imagine what those beams cost. My dumb ass would cut it 1/4" too short and I'd have to rent a really big board stretcher to fix the mistake.
  20. Aug 23, 2023 at 6:15 PM
    OZ-T
    Peter North
    British Columbia
    Timbers were about $10K CDN IIRC , but that also is for the section for the front entry we haven't done yet and 4x8 timber rafters for the section we flew in today
    I still worry about cutting something short , like basically every cut , every time lol
