Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Sep 17, 2023 at 11:03 AM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    The fixed side would have to come out with the entire window frame.
    241240[QUOTED] and Drainbung like this.
  2. Sep 17, 2023 at 11:30 AM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    https://www.geocelusa.com/product/1500sl-premium-self-leveling-concrete-joint-crack-sealant/
    This company makes great products
  3. Sep 17, 2023 at 11:35 AM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    More than doubled the area of our deck.
    Going to put a granite step at the bottom to raise it off the lawn and level it. Wish I did that first , but I think if I dig enough I will have plenty of room to wriggle it in.I will eventually keep adding steps down to the fire pit.
    I kind of want the steps on the opposite side but the grade seemed a PITA for leveling
  4. Sep 17, 2023 at 12:01 PM
    Denk
    Denk Well-Known Member
    PNW
    '13 Spruce TRD Sport DCSB
    Ships ladder, fun. 300' rope railing, not fun. Gonna do something different on the front side.
  5. Sep 17, 2023 at 3:47 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    How long a zip line? thats pretty awesome!
    shakerhood and Drainbung like this.
  6. Sep 17, 2023 at 5:30 PM
    island taco
    island taco Well-Known Member
    Vince
    victoria, canada
    White '23 LBDC TRDSport
    Kicker speakers, Key amp, Spiker hood struts, tonnueo cover, Cooper AT3 4s, Method Double Standard Bronze
    The fixed side is usually held in with double sided tape. You can remove it by cutting the tape from the inside and removing the decretive molding from the outside but that will still leave the interlocking T bar in the middle. You'll need to remove the whole window to get drywall through there.
    241240[QUOTED] likes this.
  7. Sep 17, 2023 at 6:26 PM
    Denk
    PNW
    About 106ft. They say you don't need a come along for a line that short. IDK what kind of hulking MFs they are, but there is absolutely NO way to get the requied tension without one. Luckily, Tacoma recovery gear to the rescue!
  8. Sep 17, 2023 at 6:36 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    You don't need a comealong but you do need to set up a mechanical advantage using simple rigging. Like a 3:1 pulley.
    Drainbung likes this.
  9. Sep 17, 2023 at 7:34 PM
    soggyBottom
    soggyBottom Well-Known Member
    My kitchen faucet has terrible water pressure even after removing the aerator. The coper lines under the sink have 1/4 turn pex valves. They are fully open.
    I have another sink 12 feet away with great water pressure.
    Any ideas?
  10. Sep 17, 2023 at 7:47 PM
    wilcam47
    Will
    Bourbon state
    how old is the faucet?
  11. Sep 17, 2023 at 7:57 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    valve in the facet
    could flow test the location, disconnect the facet and run a line from the valve to a bucket for a set amount of time
    MGMDesertTaco likes this.
  12. Sep 17, 2023 at 8:15 PM
    MGMDesertTaco
    the shutoff valves under the sink could be full of mineral buildup, but...
    this^
    You could swap in new cartridges for around $10 a piece, but I'd just replace the whole faucet.
    shakerhood likes this.
  13. Sep 18, 2023 at 12:37 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Worked like a champ. Also recommended by 2 people at a couple trusted HW stores. Not perfect (I do better with wood), but substantially better than what was there. The top corners of the opening around the flue were squared off. I just packed it in until it stopped. Probably 2" or so. The stuff is really thick and didn't sag/droop at all where I put it on thick. The old stuff was only in less than an inch. I ended up chipping all the old stuff off. I doubt if it'll ever get close to the 2000 degrees.
  14. Sep 18, 2023 at 1:09 PM
    Sig45
    Mark
    Maine
    Also. With all the deck/porch work I've been doing, I picked up the Metabo HTP 8 1/2" Sliding Miter Saw a while back (non laser version). Threw on a nice Freud blade. It'll cross cut a 4x4 (part of my criteria). It was accurate right out of the box. ACME tools recently had some savings specials, so I ordered a stand last week. It arrived today.
  15. Sep 18, 2023 at 1:36 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Soooo, you wanna drive 9 hours South to do mine? :anonymous:
  16. Sep 18, 2023 at 4:48 PM
    Tacoma Mike
    Southern Maine
    I use to use furnace cement on exhaust systems years ago. Saved a lot of money for people.
  17. Sep 18, 2023 at 6:50 PM
    theesotericone
    Bishop CA
    Good to see Metabo hasn't messed with Hitachi's design. I've got the same saw with about 18 years on it. Used mainly for paint grade MDF base and case but it's still accurate all these years later.
    Sig45[QUOTED] and Drainbung like this.
  18. Sep 18, 2023 at 7:04 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Stained the deck, this time around l would like to try to find some kind of weather sealer to put on top of it.
  19. Sep 18, 2023 at 7:42 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Realmilkpaint.com
    Real Tung Oil
    https://www.realmilkpaint.com/category/oils/
    The best.
  20. Sep 19, 2023 at 6:01 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    I'm slowly chipping away at the deck, I need more daylight after getting home from work!
    When the Kitten comes to visit with the GF, he has been starting ti look for ways to jump off of the deck. Once I get stairs in place, I'm gonna need a kitty proof-ish gate.
    Sig45, williams63, shakerhood and 4 others like this.
