Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Sep 29, 2023 at 6:15 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    So… what did they say about it? Are they going to make it right?
    wilcam47 likes this.
  2. Sep 29, 2023 at 7:13 PM
    TwistedTLM4
    TwistedTLM4 Unknown Member
    Philadelphia, PA
    '05 DCSB TRD Sport
    WeatherTech Floor Mats, WeatherTech Bug Shield and Vent Visors, Audio Upgrade, RaamAudio RaamMat & Ensolite, Mr. Marv's Custom 10" Sub Enclosure, Pop N Lock Electronic Tailgate Lock, mattgecko's Bedlights, Demello Offroad Single Hoop Bumper, Marathon Seat Covers, Leer Topper, OME885s on 5100s, @Blackout14 HD Leaf Pack
    Yep. They are shipping out a conversion kit and refunding the extra "factory installed" charge.
  3. Sep 29, 2023 at 8:49 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    This deck just keeps fighting me.
    It wasn't like this when I finished up last night. I found it when I went outside to start cutting some treads after work.
    I'm done cutting stringers and I honestly think that I will need to re-address these in the future, so I just opted to make a "doubler" of sorts and liquid nails into the seam of the crack and some 2 1/2" sdws to hold it together.
    As a bonus, I hit multiple soft spots in the cracked stringer when trying to screw it back together.
  4. Sep 29, 2023 at 9:02 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    You'll probably be ok strengthwise.
    what is the width? 4 across, should be plenty strong.
    The broke off piece was not bearing too much of the load.
    Sig45 and 2ndhandTacoman like this.
  5. Sep 30, 2023 at 1:48 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I would say it looks like Menards lumber but you're in Maryland. Besides, Menards lumber is usually just curled, bent and twisted. Once you dig through half the stack you might find a few that are straight.
  6. Sep 30, 2023 at 1:56 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Pulling ballasts on a few older fixtures and rewiring for led, in the garage.
    Converted all the basement fixtures to led a few years back.
    I've installed Kasa wi-fi switches throughout the majority of the house.
    There's 2 single pole switches leftover that I want to run in the garage for those newly swapped led's.
    I love those switches but they enable laziness.
    Gerberdude and wilcam47 like this.
  7. Sep 30, 2023 at 7:47 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Lowes and home depot too
  8. Sep 30, 2023 at 7:49 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Yeah if was making stairs based on their lumber I would go steel or concrete.
  9. Sep 30, 2023 at 8:02 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Bagman, Scott B., shakerhood and 10 others like this.
  10. Sep 30, 2023 at 8:05 AM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Picking through a pile of lumber to get the "best" boards, and best is very relative here, is as old of a practice as framing itself is. lol
  11. Sep 30, 2023 at 8:13 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    The broked piece is just along for the ride, kinda like your sexy gf bf.
    Thinking on this I may have gone 3/4" PT plywood as the strength patch going up the riser a bit in the middle, then your cut piece. Making a 3 way sammich
  12. Sep 30, 2023 at 8:41 AM
    Gerberdude
    Gerberdude Well-Known Member
    Alex
    '22 SR5 DCLB
    I tried LEDs in my garage but the heat just ate them up. Hardly any lifespan. I switched back to t8 florescent. Hope you have better luck than I did.
  13. Sep 30, 2023 at 9:16 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I haven't noticed any issues with the basement leds. I have 5 - 4 lamp fixtures all strung together down there.
    I only have 2 lamps in ea. instead of 4.
    These are too yellow for my liking.
    Gerberdude[QUOTED] likes this.
  14. Sep 30, 2023 at 10:53 AM
    Gerberdude
    Alex
    '22 SR5 DCLB
    Yeah everywhere else for me the LEDs of various kinds have worked out great, but the garage is unconditioned so it gets HOT up by the ceiling. That heat just eats them alive. It was a few years ago since I tried them, maybe they're better now but I had to switch back.
    bkhlrTaco's[QUOTED] likes this.
  15. Sep 30, 2023 at 12:20 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    it really depends on the quality of the lights. even if you're doing direct-wire bulbs. there's cheap and there's good. main problem with the direct-wire bulbs is many use a glass tube with the strip epoxied to one side, but the glass doesn't allow the led strips to dissipate heat as much as they normally would.
    i run lithonia strip lights, wired to a relay off my garage door light, so they come on anytime the opener light kicks on. never had any problems with any of them in the past 5 years in my un-vented hotbox of a garage, even when the opener does the 'object across sensor' flashing sequence. for a while, i was getting them on sale for $70/ea...
    https://www.homedepot.com/p/Lithoni...-4000K-MNSL-L96-2LL-MVOLT-40K-80CRI/300263606
  16. Sep 30, 2023 at 3:47 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Thankfully in WI, it really only gets warm up there a couple months of the year. :) Something to keep an eye on, though. Thanks for the heads up.
    The garage is fully insulated and finished walls as of recently. Next step is a more permanent heating/cooling solution, like a split wall unit hotel rooms have. :thumbsup:
  17. Sep 30, 2023 at 5:28 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    my lumber supplier only buys primo lumber . I got my fir deck framing material delivered and the entire lift of 16' Fir 2x10 was Select Structural and the full lift of my 14's was 2 & Better J-Grade
  18. Sep 30, 2023 at 5:58 PM
    98tacoma27
    Ben
    Not Beech Creek
    That's a beautiful stove.
    I've absent mindedly down that as well. Not fun.
    MGMDesertTaco[QUOTED] likes this.
  19. Sep 30, 2023 at 6:14 PM
    2ndhandTacoman
    Walter
    Maryland
    36" overall width. I'm using the 5/4 deck boards, so I needed the 4th stringer to give proper support. I did my deck with the 5/4 boards, joists on 16" centers and I don't like the spring that I feel when I walk across the deck. I would have did 12" centers on the joists had I known the 5/4 boards would have felt the way that they do.
    The stringer 2x12 x12's came from 84 Lumber and it took some digging through the pile to get the ones that I used, the box stores had such garbage that I wouldn't have used their junk for concrete forms. There are a few commercial supplier lumber yards, they only operate M-F 7 to 4pm. I simply can't get there to buy better quality lumber. The box stores actually tell people that they can't dig through the piles, its nuts.
    Can you mail me a few of those 2x10's? Maybe we can arrange a Tacoma express delivery!
    Making some lemon aid today...
  20. Oct 1, 2023 at 5:34 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Hah, most of the lumber I used in converting my carport into a garage came from Lowe's. It was definitely a struggle putting stuff together some times. The 2x10's I need to sister some floor joist in the basement are definitely coming from a local place. I don't feel like fighting crooked lumber gluing and screwing floor joist :laugh:
