Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Oct 2, 2023 at 3:38 PM
    soggyBottom
    soggyBottom Well-Known Member
    I have a 30 year old driveway with 1" gaps between each slab. It gets very cold where I live. The original gaps were filled with some sort of concrete that has cracked and is mostly gone. Water and freezing temperatures could move the slabs right?
    How do I fill this? Isn't this too wide for urethane caulking?
    wilcam47 likes this.
  2. Oct 2, 2023 at 4:23 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    Use backer rod and sikaflex self leveling filler for gaps up to 1.5”.
  3. Oct 3, 2023 at 11:34 AM
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    any thoughts on how to fill voids under a driveway? Im not sure how big they are, but drainage is very poorly designed where I live and any runoff from snow melt or watering runs under my driveway and pops up about half way through at the seems.
  4. Oct 3, 2023 at 5:47 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    sand jacking, though i've heard very mixed reviews that it stays.
  5. Oct 3, 2023 at 6:06 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    That sounds painful...
  6. Oct 4, 2023 at 4:07 AM
    Gerberdude
    Gerberdude Well-Known Member
    Alex
    '22 SR5 DCLB
    I've seen people use spray can insulating foam in lieu of mud jacking. IDK if it'll work if you're trying to stop water though. Water pressure is a hell of a thing and you might have better luck redirecting the water with a French drain or similar if possible.
  7. Oct 4, 2023 at 4:26 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Inlaws ask if we needed a 24" door, I said yes we do. Replaced this ugly one where the water heater is with it. Now to get some trim and a knob.
  8. Oct 4, 2023 at 3:58 PM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    What do I need to do to get paint to stick to my basement wall. It’s cinder block foundation and below grade all the way around. I’ve painted it before with dry lock and years later scrubbed it and let it dry then prime and paint but it still flakes off after a year or two. It’s only in this one spot.
  9. Oct 4, 2023 at 4:29 PM
    MGMDesertTaco
    You've definitely got some kind of moisture build up in that spot. Maybe a dehumidifier for a couples of days before painting?
    I used the dry lock textured or sanded version on the exterior foundation perimeter before I sprayed my house with Sherwin Williams Duration flat a couple of years ago. Haven't had any issues, but AZ is dryer than a popcorn fart. :popcorn:
  10. Oct 4, 2023 at 4:32 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Its prob never truely dry. When you paint it
    Drainbung likes this.
  11. Oct 4, 2023 at 4:35 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    Look up Aquafin 2k. It is great for sealing difficult leaks like that and is paintable.
  12. Oct 4, 2023 at 4:46 PM
    Charlie Too
    Charlie Too Well-Known Member
    Western PA
    2021 Army Green Tacoma TRD Off Road
    We have had a similar issue with a paint on the concrete floor. Our basement is damp so that may well be the issue.
  13. Oct 4, 2023 at 4:53 PM
    williams63
    chili
    nh
    2011 dblcb
    That one wall is against my garage. That orange oil line is level with the garage floor on the other side and that spot is in the middle. The floor has a French drain around it to a sump on the other side. Basement and the sump are bone dry. Have always had a dehumidifier down there. The wall feels dry paint seems to stick to it nice when I paint it. Just doesn’t last.
    MGMDesertTaco[QUOTED] likes this.
  14. Oct 4, 2023 at 4:57 PM
    MGMDesertTaco
    A concrete or masonry sealer might work. Home Depot has one made by Foundation Armor that has pretty good reviews.
    Charlie Too and williams63 like this.
  15. Oct 4, 2023 at 4:57 PM
    williams63
    chili
    nh
    2011 dblcb
    I’ll check that out. Wall has never been wet and never felt damp. Last time I painted it I scraped it then brushed it with a stiff brush it took what seemed like a layer of sand off the block.
    tacoma_ca[QUOTED] and wilcam47 like this.
  16. Oct 4, 2023 at 5:35 PM
    tacoma_ca
    It is what they seal cement block ponds with to hold water. Has a semi rough texture when cured that I also use for making non-slip surfaces on cement block stairs etc. Tough and inpenetrable stuff. Also sealed a roof leak from my brick chimney with a thin layer of it above the roofline, under a brown coat.
  17. Oct 4, 2023 at 6:50 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Does that wire go through to outside ?
    edit ~ just saw you following post that it is an oil line
    water could possibly follow that line and fill the block cavities below it creating a moist spot that paint doesn't love to bond to
  18. Oct 4, 2023 at 7:20 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Nice. I was gonna suggest Redgard but you can't paint over it.
    williams63 and tacoma_ca[QUOTED] like this.
  19. Oct 5, 2023 at 10:04 AM
    Gerberdude
    Alex
    '22 SR5 DCLB
    It's possible it was "contaminated" at some point in the past. It might not be moisture but maybe oil or similar was dripped or splashed there at one time many years ago. Just a thought.
    williams63[QUOTED] likes this.
  20. Oct 5, 2023 at 10:09 AM
    williams63
    chili
    nh
    2011 dblcb
    Could have been. It’s not moisture. Basement is pretty dry
    Gerberdude[QUOTED] likes this.
