Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Nov 12, 2023 at 12:39 PM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    It would be mostly smaller projects. Cabinet boxes, maybe smaller tabletops, bar tops, etc.
  2. Nov 12, 2023 at 3:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The DF500 would be the one to get for that type of thing , the DF 700 is more for very large or long tenons like for interior / exterior door construction and can actually be fairly cumbersome for smaller work
    Save the extra dough by buying the DF500 and purchase a Domino assortment which gives you a bunch of assorted sized dominoes to get you started but more importantly includes all the cutter sizes for the DF500
    This link is $CDN but will give you an idea what I'm referring to
    https://www.leevalley.com/en-ca/sho...MI45jwk8y_ggMVLRKtBh16VwmMEAQYASABEgKgTPD_BwE
    I would also recommend the TSO Bigfoot
    https://www.leevalley.com/en-ca/sho...MIqaD-_8y_ggMV9Ax9Ch17PwMsEAQYASABEgKyc_D_BwE
    and as you go further down the Domino rabbit hole you could consider the Seneca Woodworking Domiplate system , one of each size seems appropriate lol
    https://www.senecawoodworking.com/products/domiplate-for-1-2-and-3-4-ply
    and Seneca Woodworking's Domino Dock and Dock Plate
    https://www.senecawoodworking.com/products/domino-dock-for-domino-df500
    TinoTaco and RustyGreen like this.
  3. Nov 12, 2023 at 3:32 PM
    4ast4orward
    4ast4orward Well-Known Member
    WA
    2014 Tacoma DCSB 4x4
    Anyone know what CBO means on this on this 1/2" pvc ball valve handle or where I could get a new one? My handle busted when I was winterizing my sprinkler system and box stores don't carry this style.
  4. Nov 13, 2023 at 3:20 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    So I cleaned out my water softener brine tank I want to say April. Everything has stayed nice and clean using pellet salt and no issues. I've only been keeping a couple bags in it at a time cause I know the time is coming to an end with this thing, but it still works. Bought a couple bags of salt and put them in last weekend. The salt pellets looked dirty, never seen that before. Too late now as I dumped them in. Well, went to change the time on the control and looked in the brine tank. Well crap...
    Ignore the copper pipes laying on the floor, I was digging through some tubing :anonymous:
    I did look and found two kinked spots on the drain line. Un-kinked them the best I could and did a forced regen. Still same level. Hooked up my little pump and drained roughly 22 gallons of water in there o_O
    Hopefully you all can see how dirty the salt looks.
    Everything cleaned out and fresh, clean salt added. I plan on replacing the softener soon, but I don't want to do it exactly this minute.
    I also have to re-work the drain setup. They have that plastic tubing run around the basement 30'-40' to the drain, with no trap. Nothing like septic gasses going up in your softener. I'm gonna run a small line overhead and dump it into a proper trap.
  5. Nov 13, 2023 at 4:18 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    I was playing with the idea of a mortise and tenon joint, I practiced on some scrap 2x6 pine and it turned out ok. It's either going to be that, or 1/2 dowels and blind screws on the bottom.
  6. Nov 14, 2023 at 3:28 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Drain finished. Still need to order an air gap, nobody seems to carry those locally, but this will work for now.
    Nothing like spraying sink and washing machine funk all over your walls with the sawzaw cutting into the copper :laugh:
    Completed.
    While I was down there I decided to remove where the old softener drain went into. It's also where the sump pump was connecting to. Why they had the sump connected to the septic was beyond me. Guess it was easy, but if there's enough water to fill the pit the drain field will already be saturated. Who doesn't love a good septic over-flow? :puke:
    You can see it was slightly pitched wrong. So we all know what happened next. A pipe full of rancid softener backwash. Luckily I had a bucket to catch most of it. Still had to bleach the floor.
    Just installed a cleanout in its spot
    So, not sure what they were doing with the sump pit, but it was full of salt crystals and rust. The sump pump was dated 2019 and already was shot...
    Right now I don't have a replacement pump. It hasn't ever turned on in my time of being here, but I can add one and pipe it out easy. Not sure what they were dumping down there or if the salt brine was seeping past the check valve.
  7. Nov 15, 2023 at 7:11 PM
    OZ-T
    Peter North
    British Columbia
    Insulation is done inside , drywall delivered today , they start boarding tomorrow
    We finally got clarity on our deck framing / railing system choices so we're back outside . Tented the deck to complete our pitched deck framing / sheeting in preparation for the torch on membrane
  8. Nov 15, 2023 at 9:16 PM
    island taco
    island taco Well-Known Member
    Vince
    victoria, canada
    White '23 LBDC TRDSport
    Kicker speakers, Key amp, Spiker hood struts, tonnueo cover, Cooper AT3 4s, Method Double Standard Bronze
    Question about the blocking on the outside row. The others are flush with the joists but not these ones. Why?
  9. Nov 15, 2023 at 10:14 PM
    OZ-T
    Peter North
    British Columbia
    The deck framing is currently level . We will have a pitched top surface by putting tapers at 16" centres perpendicular to the joists coinciding with the layout of the blocking . That all then gets sheeted with 3/4" plywood as a substrate for the torch on membrane. In between each of our structural flush beams , at that outermost narrow joist bay is an internal gutter . Those blocks are decreasing in height to slope the gutter . The closest 2 bays slope toward the camera , the 3 furthest bays slope away from the camera . All the gutters will drain into 3" round downspouts that will attach to the 6x6 posts below and then into a rainwater catchment system
    The blocking also resists an overturning moment of the stainless steel cable rail posts that will be attached to the framing later .
  10. Nov 16, 2023 at 4:23 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    I’d like some information about the torch down membrane. I’ve seen a few but they’ve always been for non traffic.
  11. Nov 16, 2023 at 6:54 AM
    OZ-T
    Peter North
    British Columbia
    The torch on membrane is just the waterproofing layer , there is hydropressed porcelain tile going over it on pedestals
  12. Nov 19, 2023 at 9:56 AM
    soggyBottom
    soggyBottom Well-Known Member
    I found this in front of my house the other day. Anyone know who may have marked this or what it could be for?
  13. Nov 19, 2023 at 10:59 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    looks like you're going to have a dirt pile for a few days
    you'll need to ask around if the're have any work done
  14. Nov 19, 2023 at 11:28 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    it means your new well needs to be installed in the middle of the sidewalk. drive it deep.
    Drainbung likes this.
  15. Nov 19, 2023 at 12:30 PM
    Toyko Joe
    My moms new age in place bathroom is almost complete.
    jubei, shakerhood, wmb67 and 15 others like this.
  16. Nov 19, 2023 at 1:47 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    Gorgeous! And that sunset peek a boo is surreal!
  17. Nov 19, 2023 at 1:51 PM
    GunSlinger116
    GunSlinger116 Well-Known Member
    Metallic Grey Tacoma
    We just spent three days (2 hours each day) sanding down our front and back door gates then another 3 hours getting some nice oil based paint on them to stop the usual rust buildup due to living near the ocean.
  18. Nov 19, 2023 at 2:52 PM
    Toyko Joe
    It’s actually a sunrise, added bonus.
  19. Nov 20, 2023 at 3:58 AM
    Charlie Too
    Charlie Too Well-Known Member
    Western PA
    2021 Army Green Tacoma TRD Off Road
    New locks on the side door.
  20. Nov 20, 2023 at 4:04 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Softener did a regen the other morning and I'm happy to report this "repair" worked. Best the water level has ever been, so it has been having drain issues since day 1. Water softener will still need replaced in the very near future.
    Drainbung, jwctaco and Fargo Taco like this.
